REPLACE BELT HOW TO REPLACE A BELT ON A WASHER WHIRLPOOL 5700
  • 3 more comments
  • LOOKY Apr 07, 2008
    I HAVE A LA5700XK WHIRLPOOL WASHER THE HAS BROKE AND I NEED TO REPLACE IT I HAVE THE OLD BELT OFF BUT IT LOOKS LIKE YOU WOULD HAVE TO TAKE THE HOLE THING APART TO GET THE NEW ONE ON THERE MUST BE AN EASIER WAY?
    I AM GETTING THIS INFO FOR MY FATHER WHO WILL BE WORKING ON THE WASHER FOR ME. COULD I PLEASE MORE DETAILS ON HOW TO DO THIS FOR HIM. THANKS
    I NEED MORE DETAILS ON HOW TO GET THE BELT ON THE GEARS AND AROUND THE PUMP
    OK WE ARE WORKING ON THIS TODAY AND SOME OF YOUR DICERTIONS AREN,T MAKING SINCE. YOU SAY TO TAKE OFF THE FRONT PANEL THERE ISN,T A FRONT PANEL, ITS ALL ONE CABNET ALL AROUND. THIS IS A OLDER WASHER SO THAT MIGHT MAKE DIFFERANCE
    WE GOT IT THANKS
  • 3,037 Answers
Disconnect the power.....PLEASE!
Look under each side if the control panel on the bottom. There you will find 2 1/4 inch screws....unscrew these about 6 full turns...this lowers the hooks that hold control panel in place...it is hinged and will flip down...sometimes you have to pry it down gently!
Once the panel is down you disconnect the white wire connector going to the door switch and remove the 2 screws holding the front cover on....then carefully lift up on the front cover to unhook it from the 2 hooks on top...kind of slides up and out. The tub is going to stay inside and drop down...the front cover supports the tub. At this time you can remove the tub and clean out all the lint...(recommended)
Putting the front cover back on is a little tricky...you have get it attached on the top hooks and then pick up on the tub to put it on the bearing ring in the front cover ..then put the 2 screws back in...3 hands are nice to have now.
Let me know if you need any further help. Thank you and have a good day.
Posted on Apr 07, 2008
  • 2 more comments
  • Benjamin Patri
    Benjamin Patri Apr 07, 2008
    no easier way, this isn't too bad, There are less than 10 screws when you do this and basically it is just a bunch of big pieces
  • Benjamin Patri
    They are pretty simple machines, it is basically a frame with panels on the outside and some parts on the inside. very basic, what kind of details are you looking for?
  • Benjamin Patri
    to get the belt on, you just need to wind it on which I mean by that get the belt started around a pulley and turn the pulley and you should be able to pry it on, a screwdriver may help but it shouldn't be too difficult
  • Benjamin Patri
    were you able to get it repaired? If it is all one panel then it all needs to come off, some models there is more than one panel
    thank you
SOURCE:
How to fix a broken belt of motor of whirpool wash ultimate care 2
  • Replacing the Belt in a Whirlpool Ultimate Care II ' Home ... homeguides.sfgate.com > ... > Mortgage-Backed Securities Replacing the Belt in a Whirlpool Ultimate Care II by Rogue Parrish. Email; ... The Ultimate Care II washer, ... it may have a broken belt.
  • Whirlpool Washer: Ulitimate Care II - YouTube www.youtube.com/watch?v=bVmjmSzMXHE
    • BY CHERRY HILL
    • 3 MIN
    • 36K VIEWS
    2012-05-30 · Video embedded · Whirlpool Ultimate Care II: ... This is fully funcational washer. Direct Motor Drive works perfectly through each ... Whirlpool Washer: Ulitimate Care II
  • How to replace a broken dryer belt. Whirlpool Ultimate ... www.youtube.com/watch?v=PU8QZeDRl_0
    • BY BAILSOFSTEEL
    • 5 MIN
    • 3.5K VIEWS
    2015-04-04 · Video embedded · This video shows me replacing a belt in a Whirlpool Ultimate Care II ... a broken dryer belt. ... Whirlpool ultimate care II clothes washing
  • http://www.bing.com/videos/search?q=broken+belt+of+motor+of+whirpool+wash+ultimate+care+2&FORM=HDRSC3
    Jul 15, 2016 | Washing Machines
    Tip
    Drive Belt Installation on a Whirlpool Front Loading Washer
    This advice is on how to replace the drive belt on Whirlpool Duet and Kenmore Elite front loader washing machines. To replace the drive belt on a Whirlpool Duet washer, follow these steps:
    1. Unplug the washer and turn the washing machine around so you can access the back panel. Remove the rear panel by locating and loosening the screws around the perimeter of the panel.
    2. Loop the drive belt on the drive motor pulley with the ribbed side on the pulley. Leave a one-groove gap between the belt and the end of the pulley.
    3. Take both hands and pull straight up on the belt and place on the drum pulley beginning on the left hand side.
    4. Hold the belt firmly in place and slowly turn the drum pulley to the right while holding the belt in place. The belt will eventually align and hold in place on the drum pulley.
    NOTE: This may require some effort to get the belt in place.
    If you have any questions, or are uncertain if these steps apply to your washer (some newer model Maytag front loaders are now manufactured by Whirlpool) please provide me with a model number and I can let you know if these steps apply. I hope this information is helpful.
    on Dec 10, 2009 | Washing Machines
    Tip
    Drive Belt Installation on a Whirlpool Duet or Kenmore Elite Front Loader
    on Sep 30, 2009 | Whirlpool Duet GHW9150P Front Load Washer
    How do you replace the belt
    This youtube video will show ya how to replace the belt. The washer shown is a different brand but the process of how to replace the belt on your washer is exacly the same
    http://www.youtube.com/user/RepairClinic?v=a8jRgOn1wGY&feature=pyv&ad=8842436861&kw=belt
    Sep 18, 2011 | Whirlpool Duet GHW9150P Front Load Washer
    How do you replace the drive belt on the whirlpool DUET
    The following link explains step-by-step how to replace the drive belt on a Whirlpool Duet washer:
    http://www.fixya.com/support/r3059652-drive_belt_installation_whirlpool_duet
    This is a very simple procedure, but if you experience any difficulties, please post back and let me know. I hope this helps you.
    Nov 27, 2009 | Dishwashers
    How to replace the belt on a whirlpool duet washer
    1. Unplug the washer and remove the rear panel.
    2. Place the drive belt on the drive motor pulley with the ribbed side on the drive motor pulley. Leave a one-groove gap between the belt and the end of the pulley.
    4. Hold the belt firmly in place and slowly turn the pulley to the right while holding the belt in place. The belt will eventually align and hold in place on the drum pulley.
    If you have any questions, please let me know. I hope this helps you.
    Sep 28, 2009 | Whirlpool Duet 3.8 cu. ft. Front Load...
    The tub on my kenmore model no.44052401 front loader won't turn
    Always remember Electricity is dangerous and should be treated with respect.
    Please pick a topic of your  problem by clicking ...hope you find this helpful :-)
    1. Automatic dispenser information
    2. How a washer works, good to read this first: Click here
    3. Has Kenmore or Whirlpool ever had a off-balance switch.....
    4. Help for storing an appliance
    5. How does the agitator come off my washer ??
    6. How to prevent socks from getting into your pump
    7. Inglis, Whirlpool and Kenmore belt washers - common problems Like timers, pumping problems, leaking, spinning, agitating and spinning/agitating at the same time.
    8. Inglis, Whirlpool & Kenmore belt drive washers How to take washer apart and how the washer works.
    9. Inglis, Whirlpool & Kenmore style washers which style do I have ?
    10. Inglis, Whirlpool & Kenmore - how to replace the belt
    11. Inglis, Whirlpool & Kenmore - how to tighten the belt
    12. Inglis, Whirlpool and Kenmore - how to replace a pump
    13. Inglis, Whirlpool and Kenmore - how to replace or check the wig/wag solenoid assembly from American appliance
    14. Inglis, Whirlpool & Kenmore - How to remove inner basket
    15. Inglis, Whirlpool, Kenmore belt drive washer - parts breakdowns
    16. Inglis portable washer belt change help From our friend Lee )
    17. Important disclaimer
    18. Missing cycles or timer stalls in middle of cycle
    19. My clothes have a whiting on them that looks like lint.
    20. My washer has a funky odor
    21. Slow water fills
    22. Washer Basics: Filling with water problems
    23. Washer belts: If your belt on any washer looks like this, replace the belt(s).
    24. Washer sample wiring diagrams
    25. Whirlpool newer style apt size newer washer
    May 06, 2009 | Kenmore Washing Machines
    Oil leaking underneath washer. Whirlpool
    Your washer does not have a belt. Your gearcase is the trouble, part # 3360629. Hope this helps!
    Feb 26, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
    Washer does not spin
    Hi, There are several causes for this problem. Check these.
    • No spin at all: the lid switch is fried. You test it with your meter.                                  There will be a motor which spins the washing machine's drum.                                              If you don't hear the motor running, then its the lid switch which would have been broken and needs replacing. A bad lid switch wil interrupt the spin cycle.
    • In the Whirlpool washers, a common problem is that the lid plunger stops making contact with the lid switch. Use a pen to manually press the lid switch actuator (with the lid up, duh). If the washer spins...well, you know the rest.
    • Older (belt-drive) Whirlpool: the spin solenoid is burned out or has cut wires. Ohm out that solenoid (20-30 ohms) and test with a test cord. Make sure the wires are intact by giving them a little tug. If this is OK, you may need to adjust/replace the basket drive.
    • Timer is fried. On older timers, it's sometimes possible to run an external jumper to replace the bad internal contacts. Usually, however, the entire timer must be replaced. The only way to confirm is to use your meter and wiring diagram.
    These are the causes that have to be inspected. You can also visit this site www.whirlpool.com/custserv/index.jsp
    Hope my info solves your problem, Thanx for using fixya, Good luck.
    Sep 29, 2008 | Whirlpool CAM2752KQ Top Load Washer
    Washing Machines Logo
    43 people viewed this question
    Top Washing Machines Experts
    Gerry Harvey
    Gerry Harvey
    Marvin
    Marvin
