Question about Panasonic SC-HT900 System
No audio on some channels when using digital in. Some bell express vu channels have no audio. System flashes PCM FIx
  • sn76 Apr 20, 2009
    I have my Dish reveiver plugged into my SA-HT900 via optical and starting 2 days ago, when I watch SD tv the audio comes out of the speakers, but when I change to a HD channel, the receiver flashes PCM Fix, Panasonic tech support told me that it is not an error with their receiver but its a problem with the audio coming from the satellite receiver, its been working for 2 years and now all of a sudden it dosent work on the HD channels anymore, any ideas?
Hi, I had a similar problem. I had my cable plugged in to the HT through the optical. All of a sudden it stopped working and the receiver started flashing PCM FIX. The solution is press and hold shift and Digital IN buttons and the setting changes to AUTO from PCM FIX.
Posted on Jun 09, 2009
  • segahf Oct 16, 2010
    ??????, ? ???? ???? ??????????? ????????. ? ???? ?????? ????????? ? HT ????? ??????????. ? ????? ?? ???????? ????????, ? ???????? ????? ?????? PCM FIX
    ??????? ??????? ? ??????????? ?????? shift ? ?????? didgital ? ??????? ?????????? ?????? ??? ????????? ???????? ?? PCM FIX ? ????.
I solved the problem by shutting off the system so it would reboot. It was to do with the satelite receiver the the Panasonic system.
Posted on Apr 06, 2008
Sony TV is locked, how to unlock with the remote control
I just got off a friend an old Sony TV. I was able to hook up my bell express vu to the television, however every 3 seconds once I am on a channel, the screen goes black and a little yellow lock is in the centre of the screen. How do I stop it from doing that ?
Apr 15, 2011 | Konka K2386U 23" TV
I need 3 digit code for my Prima tv to program bell express vu
Programming an Expressvu remote control can be frustrating. There are two basic ways of doing in it. The first one involves knowing both your TV brand name and also knowing the proper code to input in your remote. The second method is doing an automatic search. The following is a step by step procedure in how to program your dish network or Expressvu remote.
1)Make sure your TV and Satellite Receiver is ON.
2)Press and hold TV button until all lights on the side of it flashes. The TV button is the second button on the Top left hand side corner of the remote control.
3) Release that button, then press & release RED Button. You will notice TV button is stays on. If, it doesn't stay ON, you must repeat step 2 & 3. Otherwise, your batteries are low, you MUST change then.
4)Press and release the UP Arrow Key on the remote until TV turns off. Notice the UP arrow key button is the button below the volume keys (Stop button for VCR.)
5)Make sure you are aiming remote control to TV while pressing and releasing UP arrow key button. When you find the right code, the TV will turn OFF.
6) Immediately after, TV turns off, press # key.
Dec 16, 2009 | Prima C2012 TV
Channels above 70
go into menu and change tv setup from attenna to cable
Feb 21, 2009 | RCA F27650 27" TV
Need codes for bell express vu satellite for innovage products jumbo remote
Press and hold tv until red light flash , press code search , press channel up until the tv goes off , then press record and your done
Feb 10, 2009 | Big Button TV Universal Remote
Getting VCR to record from Bell Express View
try this website
http://www.jascoproducts.com/support/download-files/RemoteCode-3-Digit-Old.doc
keep scrolling down in the list until you find the vcr codes.
i found the 3 digit code for my sony VCR. it gave me several codes, but i finally found the one that worked with my bell expressvu.
good luck
Jan 29, 2009 | Televison & Video
CANNOT ACCESS CHANNEL 76
Just go into ur option , u can change for what channel ur second tv need to bon on , so u can put a channels ur tv can get . I dont remberber where it is in the menu , but im sur u will find it in a few minutes , if u select air or cable whatever it is for the channels , make sure ur tv is on the same ... Hope it will work fast and it will :)
Jan 03, 2009 | RCA F27650 27" TV
Bell express vu remote codes for soyo tv
1 - Hold the clear tv buttom until all 4 light flash red
2- Press the red tv buttom
3- Press the amount of time needed on the up cursor ( around select buttom) until your tv shut down
4-When the tv goes off press the search buttom ( at the end on the right side )
5-Press record
Then u can use the red tv buttom to control ur tv and u can control the volume on satelitte mode without going back to tv mode , if u press too much time while searching the code and the tv wont light back , do the same thing but instead pressing the up cursor press the down one to go back on the code it will be faster .
Jan 02, 2009 | Soyo Crystal DYLT032B 32 in. LCD...
Need codes for jumbo universal remote for phillips tv and bell express vu
Press the tv and hold it until the red light flash , then press code search , press channel up until your tv goes off , press record and that it your done . Will work for your tv but maybe not for the express vu receiver , this way of finding code makes the remote trying them all so if it dont work on your express vu remote , no other codes will .
Dec 08, 2008 | 2006 Honda ANF125 Innova
Best Way ti connect a Denon AVR-1602 Surround Sound system with a Bell Express View Satlite reciever and Plasma TV
lets see, 3100 has no digital out, so you need analog inputs for the audio. Best picture with the 3100, use S-video. Digital input for the DVD sound and S-video in for picture. OOPS....does your TV have a S-Video input ?. If not then you have to use the RCA standard video type connector, as this particular denon doesnt do up or down conversion to or from S-video to old style RCA.
Sorry for the late response.....Rob
PS.....the HD bell wont do you any good with this receiver nbecause it doesnt have component video inputs. Enjoy Bells' superior picture with regular TV . Its way better than cable. Rob
Feb 03, 2008 | Denon AVR-1602 Receiver
Not enough channels
The history of broadcasting is one of adding more and more channels. The older the VCR, the less cable channels it will get.
Jan 01, 2008 | Toshiba W522 VHS VCR
Panasonic SC-HT900 System Logo
692 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
