Question about ViewSonic VA720 17" LCD Flat Panel Monitor
Viewsonc VA720 Flickers On and Off Continuously
I have a Viewsonic VA720 LCD monitor which will flicker on just for an instant, then will go dark. After sitting a moment, it will do this again, and continously, about every 7 seconds. Green power light is mostly on, but goes out for a second or two every time the brief image goes dark. Seems like the monitor is booting, outputs a brief image, then turns off and restarts, continuously. I took the back off and probed the output of the main unshielded switching supply on the left, and found its outputs are at 12V most of the time, but drop to 2V or so when the monitor seems to be rebooting. Do you think this supply board needs to be replaced?
Thanks.
-Frustrated.-
  • lubar3 Apr 19, 2008
    I have the same problem. Monitor works well but to start one I have to push button many times (8-10) bacuse after short blink monitor is dark. Thank you in advance.
I checked capacitors visually, found bubbled one (3300 uf) and replaced it. Now monitor is OK.
Posted on Jun 26, 2008
It's a common problem with this monitor. A little Google searching will turn up inverter boards for sale that are supposed to fix things (for those who don't have the skill/knowledge to replace a single capacitor).
Mark in Seattle
    Scholar:
  • 186 Answers
Take a look at the capacitors and see if you have any weak one. An obvious way to spot one would be one bubbled up on top. A bad cap won't always be bubbled up. The monitor probably can operate until the voltage drops under 8 volts. Also possible if power supply check out good would be a weak backlight inverter.
Posted on Apr 27, 2008
SOURCE:
Out of range box on my screen
Your PC video resoliton is set too high for the monitor to display, it shoulde be set to the native resoltion of this monitor: 1280 x 1024 @60Hz.
http://www.fixya.com/support/r4873371-fixing_out_range_format_not_supported
http://www.viewsonic.com.au/product_pdfs/lcd/17/E-VA720-10142003.pdf
Unless the monitor has the problem inside:
http://s807.photobucket.com/albums/yy352/budm/Viewsonic%20VA721/
Oct 10, 2010 | ViewSonic VA720 17" LCD Flat Panel Monitor
Need ac adaptor for viewsonic lcd monitor VA720
Best is to approach the Viewsonic dealer and get the recommended adapter than to get one which is universal or matching.
Sep 26, 2010 | ViewSonic VA720 17" LCD Flat Panel Monitor
LCD monitor (viewsonic va720) "No signal"
You will need to disconnect the VGA cord that is connecting the monitor to the hard drive. Once you have that disconnected, try attaching another cord to determine if the cord is the issue. If you dont have another cord to test, then you will have to purchase another one from your local computer parts store and attach to determine if that is the issue you are having.
If the cord does not work, then you will have to take your monitor into a repair shop as there maybe an issue with the receiving port on the monitor.
I hope this was helpful and thanks for asking the experts.
Jan 05, 2010 | ViewSonic VA720 17" LCD Flat Panel Monitor
Viewsonic va720 monitor flickers / goes a little dim. wiggling the power cord often helps.
then change the power cord...there may ba loose connection...or the pins int he cable is not getting full power
Dec 26, 2009 | ViewSonic VA720 17" LCD Flat Panel Monitor
What voltage do i need for my ViewSonic VA720
Monitors and PCs (amongst other things) use a fairly standard power cable. You should not need to worry about the specifics as there is generally no transformer needed for a monitor.
Oct 26, 2009 | ViewSonic VA720 17" LCD Flat Panel Monitor
1962wm screen has no display, flickers then goes b;acl
The backlight inverter has burned out.
Search eBay for LCD backlight inverter repair services.
Sep 05, 2009 | ViewSonic VX1962wm LCD Monitor
Display on mac mini only shows no signal and turns black
his step-by-step guide describers how to obtain and install ViewSonic VA720 drivers for Mac.
1. Define your ViewSonic Monitor device model.
2. Define your operating system to install your ViewSonic Monitor device. Note: Update Drivers in Mac
3. Browse Monitor Drivers.
4. Find ViewSonic Monitor Drivers.
5. Select ViewSonic VA720.
6. Download ViewSonic VA720. Note: you can update all Drivers automatically with RadarSync (Freeware) or Driver Detective (Shareware).
7. Install ViewSonic VA720.
8. Restart or reboot your computer to finish your driver installation. Note: you can backup your computer drivers before updating.
May 03, 2009 | ViewSonic VA720 17" LCD Flat Panel Monitor
Viewsonic VA720 monitor has small blinking light, won't turn on
When turning on the computer we get analog auto save, and don't get as far as the desktop, how can I solve this problem
Debi
Missing cables and plugs
can you tell me your location so i can help you find the nearest store where you can buy the cable. or you may check this link http://www.amazon.com/Viewsonic-VA720-17-LCD-Monitor/dp/B000099SKU it sells for $9.99
Jun 16, 2008 | ViewSonic VA720 17" LCD Flat Panel Monitor
ViewSonic VA720 17" LCD Flat Panel Monitor Logo
261 people viewed this question
Top ViewSonic Computers & Internet Experts
Steve Allison
Steve Allison
Ekse
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
