Question about Kenmore 24.8 cu. ft. TRIO Bottom Freezer Refrigerator
Ice build up and loud noice when fan comes on
The refrig is about 2 years old. Ice is building up on the back and when the fan comes on, it makes a loud buzzing noise. Any suggestions on what is wrong and how to fix?
  • Anonymous Jul 16, 2008
    Hi, I have a Kenmore bottom freezer model 795.75283402 and for the last 3 weeks or so ice has been building on the back wall behind the ice maker. What could be the problem.
    Thanks
  • 770 Answers
You have a defrost proble you will need to acess the timer and advance it to defrost post the model number so i can direct you most likely your heater is out in the evaprator
Posted on Apr 05, 2008
SOURCE:
Loud "clattering" noise from freezer area when refrigerator runs
There is a fan in the back of the freezer that runs when the compressor is running. It sounds like you have ice build up around the fan.
You could have one of these problems: (Sorted by most likely to least likely)
1) Auto Defrost timer, defrost bi-metal or defrost heater is defective - the unit will go into auto defrost about twice a day, if this fails you will have lots of ice built up around the cooling fins and sometimes on the fan. Pull the back off the inside of the freezer and check for ice build up around the cooling fins, there should be none or very little if its running normal.
2) Bad door gasket - if the freezer door is leaking warm moist air inside the freezer it could be condensing around the fan causing ice (you will also see ice build up on things inside your freezer too).
3) Plugged drain - the drain leads from the freezer down to the drain pain under the fridge. If this is plugged ice will build up on the bottom of the freezer and potentially around the fan.
Apr 01, 2013 | Kenmore Refrigerators
The freezer fan makes a very loud noise
it probably has ice build up around i. Try manually defrosting it. Unpluggit and let it thaw out.
Apr 30, 2010 | Samsung RS2630SH Side by Side Refrigerator
Whirlpool model ED5FHAXSLOO refrig 3 years old very noisy
If it is cooing fine, then the noise is probably your evaporator fan (the one inside your freezer). This can be cause by one of several things. The motor on this fan may be going bad, or, more likely, you may have a build up of ice around the blades that are touching the fan. This may be caused by a defrost circuit that has gone bad, or, the freezer may have been open alot lately and there is an excess of frost that hasn't melted away yet. If you can, manually defrost the freezer and see if it goes away. If it doesn't, it's probably the fan motor. If it does, and then comes back, it's probably the defrost circuit. Hope this helps!
Dec 06, 2009 | Whirlpool ED5FHEXMQ Side by Side...
GSH25JFRFWW evaporator fan makes loud deep noise at times
GE refrigerators have a faulty design, and so don't defrost completely, so ice builds up in the evaporator coils and on and in the evap. fan motor. Melting the ice will make the fridge more efficient, and the fan quiet again.
The slow, easy way to fix is take out all the food, unplug the fridge, leave doors open all day. Ice will melt, and all will be fine ... for a few months, until the ice builds up again. The fast way is here.
Nov 15, 2009 | GE Refrigerators
Suddenly there are loud weird noices coming from
check evaporator fan for free operation and defrost heater for proper operation if no operation it will build up ice and hit fan blades!!! :)
Jul 08, 2009 | Refrigerators
Loud noise from refrig.
The defrost timer is faulty. replace it asap.
Jun 25, 2009 | Roper RS22AQXKQ Side by Side Refrigerator
Refrig/Freezer not cooling
"compressor not functioning". You Probably need a New Compressor. I have a Family Member whos Refrig/Freezer Compressor had to be replaced under Warranty when it was only 2 years Old.
May 12, 2009 | Refrigerators
Ice is forming around fan in back of freezer compartment
The defrost system is not doing it's job. I bet if you took the panel off below the fan you will see more ice on the cooling coils. There should be a light coat of frost on the coils but not a heavy ice build up. There is a heating element at the bottom area of these coils which should be defrosting all this ice.
1. A defrost timer turns this heating element on.
2. The heating element melts the ice.
3. A thermo disc attached to the coils will turn the heater off.
One or more of these are not doing it's job.
Dec 16, 2008 | Frigidaire Refrigerators
Admiral refrig
thats the fan hitting ice. sounds like a defrost problem. does the back of the freezer panel have any frosty ice build up?
Aug 18, 2008 | Maytag MZD2766GES Side by Side...
LG LRFC22750 Bottom freezer french door refrigerator
6343ed3.jpg The problem is ice build up on the back wall. The noise you hear is the fan blades hitting the ice. On the back wall water gets trapped, it then builds up over time, and a big ball of ice forms and blocks the fan. Take off the back wall, defrost the build up and cut the insulation off as above. The water will no longer get trapped and the problem will not come back.
Sgt 48
Feb 13, 2008 | LG LRFD25850 French Door Refrigerator
Kenmore 24.8 cu. ft. TRIO Bottom Freezer Refrigerator Logo
273 people viewed this question
Top Kenmore Refrigerators Experts
Fred Sops
Audrey Messer
Audrey Messer
John Tripp
John Tripp
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
