Question about Durabrand 5.1 Surround Sound Computer Speakers
Can get power to dvd player and tv but no sound in rear speakers
  • 59 Answers
You have to switch to 5.1 mode to enable the rear speakers
Posted on Nov 14, 2008
SOURCE:
No sound from rear speakers with TV and DVD player
You also have to connect a SPDIF coax or optical from both the DVD player and from the STBox into the digital inputs on the rear of the receiver. And select them with the remote control.
Apr 13, 2010 | Yamaha Rx-v365 A/V Home Theater Receiver
When on 5.1 dvd ther is no sound from rear speakers,but i can run the test tone ok
check to see that the dvd player sound setting is set to BITSTREAM and not pcm. pcm is only 2 channel. Then check to see that the volume setting for the rear speakers in dvd is up, most sony receivers hold different settings for different applications, (vid 1, sat/tv, dvd) and remember when you switch between them. Rear surround should be up all the way , I believe for your receiver that is +10 also make sure you enable the rear speakers in the setup menu for surround sound.
Nov 28, 2009 | Sony STR-DE525
I have a VR 615 receiver. All 6 surround sound
It all depends on the processing the receiver is doing when recreating the sound. Change the surround mode to Dolby Digital or THX if it's on there. When it is receiving a Left/Right signal only, it does some processing but pretty much spits it out of all the speakers, fronts being the loudest. That's why you always hear them. When it is getting a Digital signal, the receiver does a much better job of processing the audio to the correct speaker, but unless there is a lot of background noise, there might not be any signal going to the speaker.
Also, check to make sure that the "size" of the speaker on the rear channels is set correctly. There is a setting on most receivers to tell the receiver how big the speaker is on that channel. This sets the power level on the output to accomodate the size of the speaker.
Oct 25, 2009 | Kenwood Audio Players & Recorders
Yamaha HTR-6130 sound only from centre, rear or front speakers
its not how there connected its in your settings. rehook up all your speaker connections properly,then make sure you proram the reciever to recieve fiber optic,hdmi,digital coax etc in the reciver.
May 18, 2009 | Yamaha HTR-6130 Receiver
No sound out of right main when watching DVR/TV or VHS
When watching TV or VHS the sound should be stereo and therefor come out of the the 2 front speakers. I suspect you now have sound out of the left front and the center speaker which indicates you connected the center speaker to the right front speakerterminal and the right front to the center terminal.
Just check if all speakers are connected to the correspondent speakerterminal.
If this is correct and the problem persists, try to connect another speaker to the right front terminal to see of the terminal or speaker is not working properly. If another speaker does work on the same connection, your right speaker might be damaged which might not be heard when listening to 5.1 because of the surround sound.
Mar 15, 2009 | Yamaha RX-V663 Receiver
Sony Model DAV ? SB 500W Home Theatre System
Please check at rear of TV for Digital Optical IN port as home theater should have optical out port at rear. If you got any optical in port in TV, just connect optical wire between TV and home theater.
2nd option is check Line Out pins at rear of home theater system, if found, hook red-white RCA cable there and put it to same input in TV where you hooked Video (composite or component) cable.
Let me know the results to help you more.
Jan 07, 2009 | Sony DAV-SB500W System
Rear speakers
Well,i will be the judge of that.Please tell me how do you have your system hook up?Be details...ex. TV connected to receiver with HDMI cable..DVD player connected to receiver...
What component that you are having trouble with the rear speakers?EX. dvd player?Directv box?Both?
solutiondoct
Nov 16, 2008 | Onkyo TX-SR804 7.1 Channels Receiver
Partial theft
As far as replacing the dvd any dvd player will work, as far as your LCR speakers go ( left, center, right ) it would be best to replace them with the same ones that came with the whole system, at least you want them to be same in size, power, and manufacture relative to the 2 rear speakers, at the very least the replacements should be same in size and power relative to the originals even if not from same manufacturer so as to attain relative level balance with the rear speakers, at the very very least any LCR replacement speakers will do really. The main point is keeping the relative balance between the LCR and rear speakers, the sub can be adjusted on its own. Sorry to hear about your theft by the way, that sucks.
Aug 04, 2008 | Bose Lifestyle 28 System
Feedback from spekers
suggest,checking pwr point earth,power leads, try a different antenna,unplug any external connections not needed to recieve broardcast,shift position of tv by 3 mtrs. Regards Chook.
Apr 01, 2007 | LG DVD 5253 DVD Player
Durabrand 5.1 Surround Sound Computer Speakers Logo
Top Durabrand Audio Players & Recorders Experts
Steve Allison
Steve Allison
antoniorojas
 Grubhead
Grubhead
Are you a Durabrand Audio Player and Recorder Expert? Answer questions, earn points and help others
