Question about Whirlpool ED2SHAXM Side by Side Refrigerator
Refrigerator door will not stay closed
You can shut the door but it will come back open about 3 inches
  • Anonymous Mar 17, 2014
    My woodmode cabinets have self-closing doors with hidden hinges. Some of the doors bounce back about 1/4 to 1/2 inch when they are shut, instead of staying flush with the cabinet.
  • 725 Answers
Check you crisper drawer it may be hit it ...let me know
Posted on Apr 05, 2008
My GE TFX22Z has served me well over the years. Recently, I noticed that the refrigerator side door has lowered about 3/4 of an inch when compared to the freezer side door. In other words, they no longer...
from the description given I came up with;
possibly the screws are lose on the top door hinge, the top or bottom hinge is worn, the door is warped or damaged.
Aug 21, 2011 | GE (PSS26MSRSS) Side by Side Refrigerator
Cold storage door will not stay shut
all of the refrigerator has a spring if there has no spring it will not open and close!
Apr 14, 2010 | Whirlpool Gold White-on-White 21.9 cu. ft....
Refrigerator door will not stay shut.
IF NOTHING IS OBSTRUCTING IT FROM INSIDE AND THE CRISPERS ARE IN THE RIGHT SPOT, THERE IS A SPACER ON THE BOTTOM HINGE THAT MAY HAVE SPLIT.YOU SHOULD SEE THIS BETWEEN THE DOOR AND HINGE
Jan 13, 2010 | Whirlpool GS5SHAXN Side by Side...
Refrigerator door does not stay closed. There is nothing on the shelves that sticks out and puts pressure on the door from the inside. The refrigerator is about seven years old.
is there a sllight tip to the unit 1/4 of an inch towards the back to assist in closing the doors and keeping them shut.
Apr 05, 2009 | Refrigerators
I have a side by side Viking refrigerator and after leaving the door open a little too long the lights went out in both the refrigerator and freezer. I figured that they would go back on automaticlly after...
Remove the center grill of the top grill and shut the power off and back on, the lights should reset
When the lights are working open the Ref door then close the freezer drawer, watching to see if the light in the freezer shuts off. It should shut off when the freezer is about 1" from closing. If it stays on until the door is fully closed then there is a problem with the light switch in the freezer.
Normally when you leave the doors open until the lights shut off, it should reset when both doors are closed
Mar 06, 2009 | Viking DDBB363 Bottom Freezer Refrigerator
Freezer door won't stay shut
This indicates that you do not have good airflow and return airflow between your freezer and refrigerator sections. That is why the pressure from closing one door is causing the other one to pop open.
Check the drain tube on the back of the machine to make sure it is not clogged or blocked with frozen water inside. Also check any return air flow vents inside the unit for clear ice.
Jan 18, 2009 | Refrigerators
Door on Monogram ZIR36N won't pull closed and stay shut
The spring is actually a door closure , are the wheels that the bar closure mechanism goes through and attaches to the spring moving freely? It is entirely possible that a bin in the fridge is keeping the door open.
Nov 14, 2008 | GE ZICS360NMRH Monogram® 36" Built-In...
Kenmore - over under
Adjust the feet to raise the front of the frige, which should be higher than the back. Therefore the weight of the door will keep it shut or at least cause it to shut itself if it pops open.
Jul 08, 2008 | Kenmore 62832 / 62834 / 62839 Bottom...
Freezer Door Won't Stay Shut
OK LOOSEN THE HINGE THAT SUPPORTS THE FREEZER DOOR.IT'S ON TOP AND HAS 3 SCREWS .JUST LOOSEN AND NOT REMOVE THEM.NOW LIFT UP THE DOOR UNTIL IT LINES UP EVEN WITH THE OTHER DOOR.AT THE SAME TIME TIGHTEN ALL 3 SCREWS. YOUR DONE!!!
PLEASE RATE THIS. THANX!!
Jun 06, 2008 | GE GSS25QSTSS Stainless Steel
Whirlpool ED2SHAXM Side by Side Refrigerator Logo
60 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
