Question about Compaq Presario 700 470024-192 Notebook
Downloading windows i have a notebook trying to download windows but having a hard time i get a message that says cant find hard disk drive
  • fatss Apr 13, 2008
    i ran cd again i still get meaasge that states setup did not find any hard disk drivers installed in your computer. it says make sure any hard disk drives are powered pm and properly connected to your computer. and that disk relate hardware configuratiion is correct. this may involve running a manufacuturer supplied diag or setup program.
  • 520 Answers
On startup go into bios and select default values and then save and exit then restart.
at the very least we want to see a message saying no operating system found then you can install os.(hd detected)
Posted on Apr 08, 2008
Hard disk 1 (3f1) error
Hp says it is a potential problem with your external hard drive.Download Hard Disc Sentinel,the free version will give you enough info on the HDD status to determine if it has an issue.The other alternative would be to unplug the drive before you bootup to avoid the message - plug it back in when Windows has loaded and check the drive for errors or problems by clicking on: My Computer - right click E drive or whatever letter the drive has - click on Properties at the bottom of the options panel - click on Tools which opens check disk options.Good Luck
Jan 04, 2014 | HP Hewlett Packard 2000-410US 15.6"...
1720 smart hard drive detects imminent failure failing attr 05
go to hp website and download the latest firmware for your notebook
Nov 23, 2013 | HP 530 Notebook
I have a panasonic sdr h85 i cant download my videos to my computer i do not have a software disk could that be the problem if so how could i get a software
-Are you using a memory card? Check "my computer" for removable drive and look for folder(s)
-Are you direct connecting via usb connection?
May need to wait for driver(s) to load to enable viewing.
What windows are you using?
Try this page: http://www.megaupload.com/?d=2U85KF1Y
Click on "Regular Download"
It's a .rar file so you'll need winrar to decompress it. Send me a personal message if you need help.
Jan 11, 2012 | Panasonic SDR-H85 Silver 80GB Hard Disk...
I have an acer aspire one aoa110, when i turn it on, the acer intro comes, followed by the windows intro and then a light blue screen appears stating that says "checking file system c: the type of...
Your hard disk is problem, there is two possible things that make you get that message. First your hard disk is full and there is a problem that windows cannot find specific file, that file maybe damaged or erased or moved to other location. Second your hard disk is about to die :). When and if your successfully finish repairing itself, try to download form the Internet program : " Hard disk sentinel", that program is free of charge. When you finish downloading install it and run. The program will show you in what kind of shape is your drive or drive's if you have more than one. In the filed on top find configuration and than preferences open and click on the " Load at windows startup", uncheck it. When program shows the shape of your hard drive or drives it will also show you estimated time when is predicted it will die. If you have BAD Sectors and program shows you a lot of red fields its time to backup your file and replace that drive.
Oct 13, 2017 | Acer Aspire One AOA110-1588 Notebook
I have an HP Pavilion dv6500, and while I was working on my laptop it suddenly shut down by itself and restarted. When it rebooted, a message came up saying "Operating System not found". I...
Your hard drive may have failed.
I suggest you remove your hard drive and re-connect it to your laptop to make sure it is make proper connection. Boot up and go into the BIOS to see if the hard disk is detected.
If the hard disk is not detected then most likely the hard disk has failed.
To get your laptop working, you will need to purchase a new hard disk and install Windows on the new hard disk plus the Pavilion device drivers and your programs,
You can download the device drivers from the Compaq/HP WEBsupport/download page. Make sure you select your model laptop and the XP orVista Windows version of the drivers you require and install them. Click onthis link to download the drivers: -
http://welcome.hp.com/country/au/en/cs/support.html
Dec 18, 2010 | HP Pavilion dv6000z Notebook
Setup did not find any hard disk drivers installed on your...
dear friend
you need to goto bios and search for and option "sata native support"
set it to disabled
if you cant find that , then you need to splitstream sata drivers into windows xp cd, if this is the case please ask me to tell you the method
thanks
Apr 10, 2009 | Toshiba Satellite M205-S7452 Notebook
How do I install windows XP on Compaq CQ40 327TU laptop
Try downloading Hiren Boot CD and run you can resize the Harddisk accordingly.
Mar 31, 2009 | Computers & Internet
WHATS UP WITH MY LAPTOP 3623
This issue normally means that your hard drive is bad. What the computer is trying to tell you is that it attempted to locate Windows, but it can no longer be found. The Hard drive is normally the case for this message. If you want to be sure its the hard drive I would suggest downloading http://www.knopper.net/knoppix/index-en.html and boot from this CD try and access the hard drive with this cd, if you cant the Hard Drive is toast. If you can the OS became corrupt and could still mean the Hard Drive is close to being toast. Either way throw the toast in the trash and buy a new Hard drive. http://www.newegg.com/
Have a great week,
ArmyMason
Feb 24, 2009 | Acer Aspire 3623WXMi Notebook
SUDDEN SHUTDOWN
I am Vikram Kumar Thumu from India-Hyderabad. I would like to provide you my suggestions on this issue for you...
Well, this issue could happen only due to below three reasons....
1. If the Hard Disk Drive is bad.
2. If RAM card is not working properly.
3. If there is an error with Operating system...
However, to isolate and to resolve the issue I recommend you to perform below solutions and try out. I hope that this should resolve the issue for you.
Solution 1: BIOS UPDATE OR BIOS FLASH
Note**--- THIS BIOS UPDATE IS APPLICABLE IF YOU ARE USING WINDOWS XP.
NOTE**-- If you are ready to perform BIOS update, please connect the Notebook with Ac Adapter and make sure that Battery is also installed for Notebook.
Please open below link in the new Internet Explorer web page...
The web page titles as " WinFlash Utility for HP Notebook System BIOS; Windows-Based"
Link is:
http://h10025.www1.hp.com/ewfrf/wc/softwareDownloadIndex?softwareitem=ob-39816-1&lc=en&cc=us&dlc=en&product=435618&os=228&lang=en
Once if you open the web page, please click on the option " Download Only" and then try to save the download file on Desktop and run the file after download is completed.
This should successfully install the BIOS Update. However, if the issue still persists then please perform next solution
Solution 2:
In this solution we will check the functionality of Hard Disk Drive...
Please restart the Notebook, while it tries to boot up please press F10 key, this should get into BIOS screen or ( SETUP UTILITY ) screen.
In the BIOS screen please locate to the Tools or Advanced Menu, and then select the option HARD DRIVE SELF TEST. and go ahead with testing the HARD DRIVE SELF TEST.
Once if test is completed, it reports a message of the status on Condition of Hard Disk Drive. If you receive error message then it confirms that this is an issue with hard Disk Drive. then you need to replace the Hard Disk Drive for your Notebook.
Else if it reports success, then it confirms that Hard Drive Drive is perfectly alright..
Then only possibility that is left is " Error with Operating system"..
if you found that it is an issue with Operating System then please go ahead with reinstall of the Operating System for your Notebook PC.
This should resolve the issue for you...
If you need any further assistance on this issue, you can mail me at thumuvikram@rediffmail.com , I'll be glad to help you further on this issue.
Bye..
Nov 08, 2007 | HP Pavilion dv1000 Notebook
Compaq Presario 700 470024-192 Notebook Logo
26 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
