Question about Mitsubishi WS-55807 TV
Mitsubishi model No. WS-55807 - In need of schematic please
I have a Mitsubishi WS-55807 HD TV and I'm in need of a schematic.
If anyone out there has one could you please share it with me.
I would greatly appreciate it.
Thanks much..
MEB
  • rmacvette Aug 05, 2008
    I have a 55807 purchased wii systems, played for 3 hours, now no picture, prior to losing picture color was in and out.
    Need schematic and advise.
    Also now besides having no picture, when I turn set on no sound
    Please send any information to be at bob@idea2life.com
I have a WS-55807 that will not power up. When the power button is pressed I hear a click from the back of the set, the timer light comes on and 3 seconds later I hear a click from the back of the set, and the timer light goes off. I started checking power to the unit with a voltmeter. For those intersted I have attached scematics: I verified that the PCB main fuse is good and there is 120V at point PT. Mitsubishi model No. WS-55807 - In need of schemat - 9f453c1.jpg
From what I can tell is happening, the power button is pressed and the P-ON transistor is given a signal to conduct which causes K9A50 to close. K9A50 opens after about 3 seconds.
I am looking for other troubleshootinng steps. I have checked fuses F9A01 and F9A06, both are good. What are some other things to check for? Where does the P-ON signal come from?
In the switched supplies regulator circuitry I found fuses F9A04 and F9A05 blown (denoted by red lines thru components). I jumpered around F9A04 and F9A05 with good 5A fuses and the TV powered on. However when the set was plugged into an outlet there was a huge power draw (sparks from the outlet).
After jumpering around the blown fuses, the TV stayed powered on for about 30 sec and then powered down. I pressed the power button a few more times and the same result. The TV stayed on for only 30 sec.
I pulled the middle PCB whichs holds these circuits and I found the
D9A60 diode open and IC8C02, one of the convergence IC's fried. I don't know if these were like this before or after jumpering.
I replaced all bad components and I am back to square one. The K9A50 relay stays closed for 3 sec and the set does not power on any further.
Comment by TV_ITGuy, posted on Dec 19, 2007 Thanks for the advice ctf1800. I have read several posts that speak of the DM unit. I have looked in the back of my set and the DM unit isMitsubishi model No. WS-55807 - In need of schemat - dcb8806.jpg location shown in the pictures. dcb8806.jpg
As I hope you can see in this picture, there is no DM unit to the far left, just open space. Also the service manual for the V17 chasiss does not speak of a DM module.
I checked the reisitors on the output of IC8C02 which are a couple of 3.9 ohm resistors in parallel. When I test them I get approximately 1.9 ohms, which is what it should be with them being in parallel.
Please let me know if I am off base on any of this. Thanks Comment by TV_ITGuy, posted on Dec 19, 200Mitsubishi model No. WS-55807 - In need of schemat - postsolution.gifreplaced both of the Convergence IC's when I replaced the Mitsubishi model No. WS-55807 - In need of schemat - addwq.gif diode. Post Solution
addwq.gif Work Queue -->sameproblem.gif Have the same problem? --> Have the same problem? Click Here
ctf1800
Rank:wizard_s.gif Wiz
Rating: 84%, 2716 votes
first off you should replace both convergance IC and check the resisters coming off the output if any of the resisters are bad it will trash the ic on trying to power up.
i would also replace the caps in the DM section
http://www.jeremyburns.com/Mitsubishi-Green-Blinking-Light-Fix.pdf
http://chrisandnat.com/projects/blinkingtv/blink.htm
Comment by ctf1800, posted on Dec 20, 2007 there are six fusible return resistors ranging from 1.5, 1.8, 2.2, 2.7, 3.3, 3.9 Ohms. I would lift one side of the resister out.
check for any caps that look puffy and check the horz. out put transistor.
Rating Locked! (?) TV_ITGuy has rated this solution as Thanks for Trying
Hope this helps fortuna55@aol.com
Posted on May 29, 2008
Mitsubishi WS-55807 Error Code 24 Vertical Deflection Failure. 5.
Hi. The service manual is in more than one part.
Schematics are in part 2 here:
Download Service Manuals for free
Jul 30, 2016 | Mitsubishi WS-55807 TV
I turn on the tv and it shuts off after a couple seconds
if you unlpug your tv and plug back is the green ligth blinks for one minute?
let me know so i csn help you
Jul 29, 2009 | Mitsubishi WS-55807 TV
High Definition--WS-55807
IF the MITS has 3 component inputs blue red yellow RCA jacks on the back then yes at 480 or 720p, you'll need to attach 2 audio cables for sound. If it has a HDMI input then absolutely.
please rate!
Mar 11, 2009 | Mitsubishi WS-55807 TV
Tv doesn't come on
Mitsubishi WS-55807 Manual
I think that the solution that you are seeking is on page 63 of the manual.
Feb 12, 2009 | Mitsubishi WS-55807 TV
I just subscribed to HD service, But my mitsubishi 55807 tv wont display 1080 it stays on 480. the server is comcast. can you help?
IYou have to have your comcast box tuned to a channel that is broadcast in HD. On your Comcast remote hit menu. This will bring up several icons, one is HD. Select that icon and it will bring up the TV Guide for just HD channels. Select one and tune to that channel. Once your on that channel use your original remote and hit menu, then advance features, then go down to video display and change it from 480 to 980 or 1080. Let me know if this helps.
Dec 15, 2008 | Mitsubishi WS-55807 TV
I need the V-Chip code for an HD 1080 series TV.
delete characters by pressing cancel for each character
Dec 14, 2008 | Mitsubishi WS-55807 TV
My mitsubishi 1080 WS-55807 has lost the picture
Unplug the set, remove all other audio/video components, go open front door, and roll it out to the curb.
Nov 24, 2008 | Mitsubishi WS-55807 TV
Mitsubishi WS-55807 TV won't turn on
It s a Power supply problem.If you are not familiar with electronic repairs take it to an authorized repair shop.
To get a service manual see link
Download Mitsubishi WS-55807, WS-65807, WT-46807, WS-55857, WS-65857, WS-55907, WS-65907, WS-73907 Service Manuallockmanualsdnw_en.gif
Login or Register to get access all drivers database.
Please be sure to enable cookies.
Feb 21, 2008 | Mitsubishi WS-55807 TV
MITSUBISHI BLINKING GREEN LIGHT
I've got the blinking lights also. Model # WS-55613. Does anyone know what the problem is?
Dec 27, 2007 | Mitsubishi WS-55807 TV
Mitsubishi tv
I NEED SCHEMATIC
Oct 16, 2007 | Mitsubishi WS-55807 TV
Mitsubishi WS-55807 TV Logo
5,726 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
