Question about Canon ImageClass D880 Copier
Canon D880 fuser
We have a paper jam in the fuser bad enough I need to remove it, but I am not sure how. Could someone give me instructions on how to remove it or where I can get a manual that tells me how?
  • jeff heightchew
    jeff heightchew May 11, 2010
    Hello rolltideO,
    I have placed this correspondence in the "additional info" field because unfortunately a fuser jam in that machine can be a nightmare. I am "trained" on your machine and have the service manual for it, but FREDDY KRUGER disturbs me less than the procedure for replacing the fusing unit or even doing minor repairs. The company I work for has placed alot of these machines in the field anf I dread he day I have to do serious work on the fuser.They are nice machines. But suffice it to say that you must turn the machine upside down and remove the power supply (after having removed all the covers) before you you can begin to see how to remove the fuser. I wish I could be of more help. Perhaps I actually have been of help.Just knowing that it IS as bad as it looks makes it easier to bite the bullet and start ripping @#&% out. Take care.
  • 42 Answers
With an offset #2 phillips screwdriver and some patience you can do this- we have been fixing PLENTY of fusers on the imageclass series-you can get the fuser out thru the exit side of the copier.
1. UNPLUG COPIER , pull platen to left with grey lever
2.remove one screw for upper plastic cover cover pulls down and out
3.remove 2 screws on lower exit cover this comes up and out
4.remove small plastic cover on left side of exit assembly as you face end of copier.
5.pull back black plastic sheet to expose 3 connectors one plugs into circuit board two plug into heater or fuser assembly. unplug these
6.with your offset driver remove 3 screws holding fuser to frame of copier -these will be pointing up.
7. lift fuser up and carefully work out of copier.
check for stuck papers or damaged fuser film sleeve.
To reseat fuser and replace panels go slow and easy the panels fit back in kinda funky it takes a bit of tinkering.
We do not turn the copier upside down to remove the fuser and have replaced about 20 of the fusers or installed a new fuser sleeve.
Good luck and ask all ya want if more assistance is required.
Posted on Apr 23, 2008
  • 22 Answers
An option we use is to take something like a drivers license or some thicker stock paper and remove the cartridge and try to push it through this works about 90% of the time. Good Luck
Posted on Apr 22, 2008
I have a Canon imageclass D880 multifunction, error"Paper Jam, slide platen..." I can see the paper deep within the machine ( fuser?) but cannot get to it to get it out.
Hi marcbachm177,
Please follow the steps below on how to remove paper jams inside printers in hard-to-reach places, a pair of medical forceps is often useful.
1. Take off 3 plastic covers one above exit area-slide top to left to access screw. Remove lower exit cover and side cover -unsnaps with 2 pins and there is one more cover I think over the fan that needs to come off.
2.Locate black plastic sheet covering a circuit board carefully pull this back-disconnect 3 plastic connectors that lead from the heater to the circuit board.
3. Using a offset phillips #2 screwdriver remove 3 screws that hold the fuser to the frame.
4. Carefully lift fuser up and out toward the exit area.
5. Pop off black cover remove 2 screws from top of fuser, disengage cover lid locks with a small screwdriver, lift upper fuser heater - be careful NOT to damage plastic heater membrane. remove paper jam and reassemble.
Hope it helps.
Thank you for using FixYa.
Aug 17, 2011 | Office Equipment & Supplies
Paper jam on a Cannon D760 copier
A technician who knows what he is doing is required to access the Canon fuser.
However, If you remove the glass on some later models there is an access hole wear you can get a long shank screwdriver down to the screw that holds the fuser in place. On some older models I have actually drilled a hole through the optics area to access the screw. You can get it with a stubby, but it is not fun. Getting the covers off is like working a rubics cube, good luck...
Jun 02, 2010 | Canon ImageClass D880 Copier
Paper jam and can not find paper; useless guide book that came with printer is no help
remove left panels switch on fuser mech becareful its hheld on by a very little spring and breaks very easy
May 18, 2010 | Canon imageCLASS D880 All-In-One Laser...
Paper jam internal, can't access. accordian at exit tray
more the likely it is in the fuser unit of the copier .
May 04, 2010 | Canon ImageClass D880 Copier
Paper jam in canon d880, Have tried every way to get paper out, but can't. Need to know what to do?
Make sure to blow off the optical device near the print head.
It may not have a paper jam at all.
Apr 07, 2010 | Canon imageCLASS D880 All-In-One Laser...
Jamming
its a very big teardown to remove the fuser assembly
Jan 16, 2009 | Canon imageCLASS D880 All-In-One Laser...
Squeeking
The squeeking sound usually is in the fuser area
open the fuser roller area( clear paper jam the rollers are hot wait until it cools down get some spray silicone(similar to wd 40 with a plastic tube to reach small areas spray small amount on any e
xposed gears(plastic ) do not spray the fuser rollers
if you see nay other moving parts give them a light spray
turn back on and see if sound has stopped
If not try to determine when squeeking starts
then spary appropriate area
Dec 29, 2008 | Canon ImageClass D880 Copier
Canon D880 Printer/Fax
remove lower exit cover and side cover -unsnaps with 2 pins and there is one more cover I think over the fan that needs to come off.
3. using a offset phillips #2 screwdriver remove 3 screws that hold the fuser to the frame. carefully lift fuser up and out toward the exit area.
4. pop off black cover remove 2 screws from top of fuser, disengage cover lid locks with a small screwdriver, lift upper fuser heater-be careful NOT to damage
Nov 15, 2008 | Canon imageCLASS D880 All-In-One Laser...
Jammed paper
Pper jams are removed from right hand side of copier-remove cartridge and lift green tab, check for paper there.
Paper jams in the fuser section are a real problem with this model the fuser unit has to be removed.
Jun 07, 2008 | Canon ImageClass D880 Copier
Canon ImageClass D880 Copier Logo
1,271 people viewed this question
old marine
old marine
