Question about Adobe Photoshop 7.0 for PC
1995 Ford Escort LX Brake lines
The brake line has a hole in it right under the drivers door, I can not find connections, Do I have to replace it from the master cylinder all the way back or is there connections that i cant find
  • Anonymous Oct 14, 2008
    brake line leaks and service station says its too time consuming a job to bother. is it that complex?
The last comment about how to splice is dangerous and illegal in canada. The compression union is not a strong enough to support the pressure and maintain support through the constant use of the brakes. It is legal however to splice the line with a union block. You would have to cut out the bad section, and install new fittings on the existing good line. You will have to double flare the lines the same as original. You can purchase a ready made piece of steel line already flared that you can install between the two existing lines using 2 junction blocks. This is the only safe way to splice the line. Depending on the vehicle it's not that difficult to replace the entire line, just time consuming. Bending is an art, and flaring the lines would have to be done anyway.
Posted on Sep 05, 2009
  • 265 Answers
A piece of steel brake line can be spliced into the broken line, but you'll need to make a clean cut at both ends of the place you choose to remove the damaged line, using an 'Imp' pipe-cutter, then use compression fittings (available where you purchase replacement brake line) and make sure they're tightened properly. Not too loose, not too tight. Just enough to crimp the brass fitting onto the steel line to hold the pressure. Try NAPA or a local auto parts supply store.
Posted on Jun 09, 2008
SOURCE:
1996 Ford Thunderbird - What is this sagging cable?
It is your e-brake cable. e-brakes are mechanical, not hydraulic, therefore it has nothing to do with your master cylinder. adjust the cable at the e-brake itself or re-hang the cable to its rightful resting place.
Jan 21, 2013 | 1996 Ford Thunderbird LX
My 97 escort lx has a rusted right rear brake line how can i fix this and roughly how much will it cost?
Hi, brake lines are not expensive but they require special tools. Any brake shop can repair a line for about $100.
Sep 15, 2011 | 1997 Ford Escort
Replace or or repair brake lines
replace dont play with brakes
May 10, 2010 | 1995 Ford Escort
How do i tighten the parking brake on my 1997 ford escort LX
If you can locate the Parking brake cable under the chassis, there should be a clevis that tensions two cables together, at this point you should be able to adjust the cables toward each other to tighten connections.
Jan 04, 2010 | 1997 Ford Escort
I have a 1995 ford escort lx the air conditioner does
you either have a clogged ac line or you have a vacuum problem that will prevent the correct vent doors to open to allow the air to enter
Jul 07, 2009 | 1995 Ford Escort
Can I replace a brake hose front and back on 95 escort easily???
Not a good idea, if vehichle has abs then you can't blead it properly and even if it did'nt without bleading system, air in lines can cause brake failure.
Apr 26, 2009 | 1995 Ford Escort
Leaking brake line from drivers side front under frame by door
sounds like master cylinder is leaking fluid.
Feb 23, 2009 | 1999 Ford Taurus
Brake pedal stuck 1995 crown vic lx
did you bleed the brakes and get the air out of the lines and also if you have shoes on the back did you put the little shoe in the front and the largest in the back? and if you replaced the wheel cylinder or had any lines opened you have to bleed the brakes
Jan 15, 2009 | 1995 Ford Crown Victoria
1995 ford escort lx fan relay locations
right hand side under bonnet on the wing or at the back by the battery depending on model build
Nov 10, 2008 | 1995 Ford Escort
Brake line for a ford taurus gl 3.0 v-6
most brake lines are 1/8"(0.125) suprised parts store couldnt cross reference for you generally you can buy the line prefab with all fittings the right bends and length alot easier to install hope this helps
Aug 31, 2008 | 1996 Ford Taurus
Adobe Photoshop 7.0 for PC Logo
636 people viewed this question
Top Adobe Computers & Internet Experts
Peter Dragonetti
Ekse
Alun Cox
Are you an Adobe Computer and Internet Expert? Answer questions, earn points and help others
