Question about Dishwashers
Kenmore 665 . 1675590 dishwasher
Nothing works, stopped before the soap was dispensed, water still in the tub. I checked voltage - Is there a reset or a schematic available, Thanks
Tim
5 Suggested Answers
  • 1314 Answers
SOURCE: Dishwasher soap dispenser won't open during cycle
both have a wax motor on them that needs to be replaced you just remove the panel and replace the wax motor is what its called
Posted on Feb 16, 2008
SOURCE: Soap dispenser still has the soap in it after the dishwasher cycle has ended...
do you have a salt unit fitted. I had the same problem and the repair guy had to replace the salt unit as it was blocked up. Failing that it might be the board not opening the solenoid to allow the water to be jetted through the soap dispenser.
Posted on Mar 16, 2008
aborcass
  • 2651 Answers
SOURCE: Soap Dispenser Problem with Kenmore Elite Dishwasher
its possible to have a faulty dispenser, but i would look for other reasons first. Im a big powder user and proponent. powder just breaks down better in hot water.Have found that by using the tabs(whoch im sure the gel packs could give same issue) that they dont really fitting the dispenser as well they're a little tight to close the door and the spring action of the dispenser is sometimes not enough with te extra pressure from the tablets.also ck to make sure youre loading it correctly and nothing is blocking the water form spraying into the cup fully emptying it
Posted on Mar 23, 2008
landsend
  • 1066 Answers
SOURCE: sears dishwasher soap dispenser door wont open-loose spring
with new parts ...yes.
Posted on Mar 13, 2009
jonniewalker
  • 1029 Answers
SOURCE: Dishwasher does not clean dishes, soap does not fully go away
Water Inlet Valve
A dishwasher's water inlet valve is its most common part to fail. When your dishes are not being fully cleaned, quite often a faulty water inlet valve is to blame. Test your dishwasher's water inlet valve, and if it is no longer functioning as it should, you will have to replace it.
Heating Element
Water temperature is a key element in achieving clean dishes. A dishwasher's heating element is not designed to heat the water that enters it. Rather, the heating element is designed to maintain the heat of the water that enters the dishwasher. Its a good idea to run the hot water in your sink for a couple of minutes before you run the dishwasher. Just to make sure the water is nice and hot before it enters the dishwasher. If the water is unable to stay hot, it can adversely affect your dishwasher's cleaning ability.
Filter/Drain Grate
There is a filter in your dishwasher. Its function is to keep large particles of food and foreign objects away from the pump. Many of the newly-manufactured dishwashers have self-cleaning filters, and routine cleaning isn't a concern. However, some other dishw ashers need to have the filter removed and cleaned regularly. If the filter or grate is clogged or blocked with debris, it may interfere with the normal functioning of your dishwasher. Consult your owner's manual for specific directions for removing your dishwasher's filter and cleaning it.
  • filter
  • . Detergent or Detergent Cup
    It could just be that you aren't using enough soap to completely wash your dishes. Your dishwasher may be designed to dispense soap at two different times during the wash cycle. If you don't fill all of the detergent cups, then the diswasher will lose a cleaning cycle. Also, if you use a gel-type detergent, try switching to a powered kind. Powders tend to dissolve better in hot water. And don't buy in bulk. Detergents are most effective in the first two weeks. After that, they decrease in potency.
    Alternatively, your dishwasher's detergent cup could be defective in some way. It is possible that it is gunked up full of built up detergent, and a thorough cleaning may be enough to get it working again. If that doesn't do the trick, you probably need to replace the entire detergent cup assembly. If your cup isn't even opening, My dishwasher detergent cup won't open.
    Cycle Selector Switch
    Sometimes a dishwasher's cycle selector switch is the reason why dishes are not coming completely clean. Test your selector switch to determine whether or not it has become defective. If it has, replace it.
    Posted on Mar 29, 2009
    Hi, I have a Fisher Paykel DD603I (integrated) dishdrawer unit. The bottom drawer soap dispenser has water in it after it runs (and leftover soap), and there is a small amount of water sitting in the...
    Hi
    Dishwashers use Bi-Metal strip to allow the dispenser to open/close. This strip when heat up causes the soap door spring to open up the dispenser. If this strip is not heated doesn't allow the door to open. The strip may not be getting 120V or maybe disconnected. Newer (plastic liner) dishwashers use a wax motor to open the soap dispenser. The plunger inside the wax motor slowly moves and pushes the plunger and door open. And, if this wax motor doesn't receive 120 volts, then it'll not work. Please check the voltage to the wax motor/Bi-metal strip; also inspect the connections to these. Hope this helps...
    Daniel
    Jan 16, 2011 | Fisher and Paykel Dishwashers
    The soap dispenser won't open during the cycle on my 15782 model Kenmore Dishwasher. I am using gel pack soap...so I do not have old soap caked in the receptical. Any thoughts?
    Hi
    Dishwashers use Bi-Metal strip to allow the dispenser to open/close. This strip when heat up causes the soap door spring to open up the dispenser. If this strip is not heated doesn't allow the door to open. The strip may not be getting 120V or maybe disconnected. Newer (plastic liner) Maytag dishwashers use a wax motor to open the soap dispenser. The plunger inside the wax motor slowly moves and pushes the plunger and door open. And, if this wax motor doesn't receive 120 volts, then it'll not work. Please check the voltage to the wax motor/Bi-metal strip; also inspect the connections to these. Hope this helps...
    Daniel
    Oct 26, 2010 | Kenmore 24 in. 15782 / 15784 / 15789...
    Soap dispenser doesn't always open and the tub doesn't always pump out the last rinse.
    check the supply voltage going to soap dispenser and inlet solenoid valve, if no voltage replaced the timer
    Jun 04, 2010 | Dishwashers
    Soap stays in disperser. Water is 142 degrees, dispenser opens.Not overloaded and filter under bottom wand is clean. Model is 16342
    Either:
    1. check if the bottom rack is inserted correctly. Try turning it 180 degrees and run the cycle. Make sure nothing obstructs the dispenser.
    2. the water does not get into the dishwasher open the dishwasher 3-4 times during cycle, if you don't see any water at least once - check water valve, water level float and water pressure.
    3. the pump is clogged - there is water, the motor will run but no water is circulated. Check pump filters, check chopper and impeller.
    4. motor in main pump is not working - could be caused by something stuck on the impeller or chopper or could be a problem with the motor itself or control board. Check if line voltage is coming to the motor during wash/rinse cycle.
    Good luck,
    Vlad
    First Choice Appliance
    Feb 16, 2010 | Kenmore 24 in. 16352 / 16354 / 16359...
    Kenmore Dishwasher doesn't rinse? It sounds to be working fine, however, at end of cycle, dishes are still dirty, and the front door on the inside is still dirty. Obviously there is a problem here...
    try opening the dishwasher during the wash cycle stop it and open it if water is in the bottom it is filling whn you open do 1 or 2 times to check to see if spry arms are spinning if they are check to see if soap dispenser is working also use dishwasher cleaner once a month available wherever tou shop for groceries in the dish soap dept. directions are on label
    Dec 15, 2009 | Kenmore Dishwashers
    The soap isn't coming out of the soap dispenser during the wash cycle. when i open the dishwasher door the dispenser opens with all of its contents still sitting there!
    I had the same problem once. Make sure nothing is stacked in front of the soap dispenser when you close the door. Slowly close the door and follow the soap dispenser to make sure it has enough clearance to open.
    Let me know how it goes.
    Regards,
    Jul 19, 2009 | Electrolux Kenmore 24 in. Built-In...
    GE profile PDW7880J Soap left on dishes and soap left in dispenser
    Dishwasher - Soap Stuck in Cup If you have dishwasher detergent stuck in the soap cup after a full cycle, please check for the following conditions:
    • The water temperature should be at 120 degrees (140 degrees if your dishwasher has water heating capability). Check your water temperature Check your water temperature.
    • Make sure the soap cup is not blocked by anything.
    • Allow the dishwasher to fill and make sure it is getting a proper amount of water. The dishwasher should fill for about 90 seconds. On permatuf models, the water should measure 3/8" above the island near the center of the tub. On all other models, the water should measure about 1/2" below the heating element.
    • Check the lower spray arm for any blockage in spray holes or items that would restrict its turning.
    • Make sure the soap cup has opened at the end of the cycle.
    • Check the sump area inside the dishwasher for any restrictions.
    Apr 09, 2009 | Maytag 24 in. MDBH950AWS Built-in...
    Our dish soap is not dispensing from the flip container.
    sounds like you have a water circulaton issue, make sure your getting enough water in machine, and nothing is blocking the dispensor eform getting hit with the waster stream
    Jan 11, 2009 | Kenmore 24 in. 15932 Built-in Dishwasher
    Soap dispensing problems on a kenmore dishwasher elite 577-0
    is your soap door open when this happens if it is then make sure there's no water or other liquids in the dispenser from loading the washer one tablespoon of water in there will clump up the soap and it won't drop when it pops open
    Dec 25, 2008 | Kenmore 24 in. 15252 / 15254 / 15259...
    Soap is not leaving soap dispenser
    sounds like your washing dishes without water. baked on dirt!!!! check under sink make sure water supply is on, next look on bottom of d/w inside tub, theres a mushroom shaped float, grab it and push up and downa few times, if its stuck in up position d/w will be tricked into thinkin its already filled with water
    Feb 10, 2008 | Kenmore 15522 Built-in Dishwasher
    Dishwashers Logo
    48 people viewed this question
    Top Dishwashers Experts
    Mike Cairns
    Mike Cairns
