Question about Kenmore 24 in. 15173 Stainless Steel Built-in Dishwasher
Kenmore Elite I replaced most of my appliances 3 years ago with Kenmore Elite and I've had problems intermittently while the appliances were under warranty, but when the repair person arrives, no problem is detected. Once the appliance is no longer under warranty, the problem becomes persistent. At one point when I explained the difficulty, the technical support person said something to the effect of, "Oh that's an easy one to fix. All you need to do is...Oh wait, the warranty expired on the 3rd. I can't provide you with technical support. Would you like to schedule for a repair technician?" Once I pay for repair, the appliance works like a dream, but a little customer service goes a long way. I will never purchase another appliance from Sears. Now that I'm done venting - My Kenmore Elite Stainless Steel dishwasher isn't getting the dishes clean. The door is grungy looking after a wash cycle, and the residual water is cloudy. Also, the cycles are extremely long. I assume part of the problem is the typical Sears appliance 'quality', but there is a filter somewhere that needs to be cleaned? Any ideas?
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 113 Answers
Hmm, I'll start at the top :->. Well, first thing is that Kenmore doesn't manufacture any appliances. The only thing Sears has is the name recognition, therefore, they have GE, LG, Whirlpool, and others to make appliances for them and Kenmore slaps on their label. On with the problems though :-> 1. Door is grungy looking. Make sure your air-gap ( if you have one) is clear and not clogged. If you don't have one, make sure the drain hose is mounted to the underside of the counter, under the sink. This will prevent Gookus from backfilling into your dw. 2. There are 3 main things to check when repairing dw - Circulation, Heat, and Drainage. There's not much else. Here are some tips to address each one. a) Make sure all spray arms are turning. Put in one position, close door, run, open, and verifiy they moved. If not, clean holes in spray arms, or, remove filter and clean around impeller or chopper. I find clogs all the time. b) Heat. Make sure you are running your hot water in the sink until max hot water is reached. This is very important and should be listed in the users manual. Most dw's run several cycles before the heater element is energized. Water must be 120F when entering dw. c) Hard Water buildup. Use Lemon Shine, available from Walmart. This will clean the dw and prevent buildup on dishes. d) drainage. Addressed above. I've seen countless times where food and other gookus goes right down garbage disposal and into the dw drain line, where it recirculates on to dishes. Make sure air-gap is clear or that hose is secured to underside of countertop. e) Make sure the element is working. Once easy way to check is to verify dishes are dry at the end of the cycle. If not, call a service tech and get fixed. I've found black mold (splatter) on inside of dishwasher due to heater element bad. Hope this help!
Posted on Jul 23, 2010
SOURCE:
Kenmore elite 5 burner grill manual
Kenmore Gas Grills Manual - Sears
https://www.sears.com/search=kenmore%20gas%20grills%20manual Items 1 - 37 of 37 - Kenmore Elite 5-Burner Dual Fuel Gas Grill with Motorized ... Star Manufacturing Star - 848MA - Ultra-Max® 48 in Manual Gas Griddle.
Kenmore Elite 5-Burner Dual Fuel Gas Grill with Motorized Rotisserie Kit
https://www.kenmore.com/.../kenmore-elite-kenmore-elite-5-burner-stainless-steel-gas... The Kenmore Elite 5-Burner with Rotisserie Kit: A Reliable Cookout Staple Play host to the perfect outdoors party with ... Play host to the perfect outdoors party with your Kenmore dual fuel gas grill. ... Assembly, Minimal Assembly Required ...
[PDF]Owner's Manual - The Grill Services Corporation
www.grillservices.com/manual-downloads/720-0286.pdf Kenmore Elite Warranty ... Burners: 5 Years. Flame Tamers: 3 Years. Cast Iron Cooking Grids: 3 Years ... grill. The gas regulator assembly supplied with your gas.
Kenmore elite 5 burner grill manual Google Search
Jul 28, 2018 | Kenmore Grilling
I have a xbox 360 that i got through bell 3 years ago.. Last week it got 3 red rings of death what should i do to get my 360 fixed??
Check out the xbox website and use the warranty verification tool to see if it is still under warranty. I believe the consoles with three red rings get an additional couple of years under warranty...
Nov 22, 2010 | Microsoft Xbox 360 Elite Console
Our Kenmore Elite Oasis that we purchased over 3 years ago started to make incredible noise during the spin cycle, so loud you can barely hear yourself think. We had a repairman from a Service Company...
Yes, Sears repair just ordered one for mine. Entire tub due to bearings gone. Also just over 3 years old and ext warranty ran out in June. Final inspection before warranty was scheduled in June 2010. July the bearings are gone. Hmm wonder how they missed that? Anyway if you call for service, ask about the maintenence plan. Its way cheaper than labor and tub and u have another year for more issues with this piece of junk washer.
Dec 01, 2009 | Washing Machines
Keypad won't work on my Kenmore Elite Dryer
i know it is not an easy thing but the fact remains the same. The
keypad needs replacement, so that it will normally.
Oct 02, 2009 | Kenmore Elite HE4 Electric Dryer
Leaking Kenmore Elite at the right front of dishwasher
Sorry to hear of your plight. My advice is to ask for a new machine under the lemon law since they cannot get it fixed. You can also try calling Whirlpool who is the manufacturer but they are likely to tell you to work with Sears. They were out under warranty and it has not remained fixed so the warranty should carry through since you called for service while still in warranty. I feel for the tech because it is frustrating to have a problem that you cannot find a cure for be the tech should also have escalated it to the tech support line for resolution. (I was a Sears tech for 21 years)
Sep 14, 2009 | Kenmore 15129 Built-in Dishwasher
Kenmore elite top loader
Call or email the consumer feedback or make a complaint to Sears. I had a similar prob. Sears ending up replacing rhe washer and paying for rental. Took up to 3-6 months, calling and writing complaint letters.
Jun 03, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Kenmore elite range oven problems
hi. thanks for the question . i would replace the igniter in oven .thanks the appliance doc
Sep 26, 2008 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
Kenmore 24 in. 15173 Stainless Steel Built-in Dishwasher Logo
273 people viewed this question
Top Kenmore Dishwashers Experts
Fred Sops
vince
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
