I can send faxes, but not receive them. When I dial my fax phone number, it just rings. Set up to answer after two (2) rings. Turned off and restarted again, unplugged power line, unplugged phone line. Sent faxes to three other machines successfully, but then could not receive from those same machines.
check to see if your phone line is plugged in the " L" or line slot on your fax machine if it is then press the speaker or monitor key and listen for dial tone. then you put a document into the feeder and dial your cell phone number and press send, when your cell phone rings answer and listen if you are getting a high pitched squeel. if you are then it should be working. try it the other way too by dialing from your cell and listen again for the squeel. if you still don't get the squeel you have a defective modem.
Thank You,
Mikey
Thank You,
Mikey
Was this solution helpful? Show your Appreciation by rating it:
