Question about Minka Aire Ceiling Fan
Light dims up and down repeatedly
My Minka Aire ceiling fan model F705 suddenly is not responding to the wall control. the light dims up and down repeatedly on its own. Faulty wall control?
  • 2 more comments
  • ejca Jan 31, 2009
    my Minka Aire ceiling fan model F705 suddenly is not responding to the wall control. the light dims up and down...
  • Anonymous Mar 29, 2014
    what model remote will work? Will it require a custom pairing or will a new remote work with all models?
    Will a new remote require custom pairing or will the new Minka remote work with any Minka model?
    fan cowling cover
Posted on Feb 18, 2009
Newly installed Minka aire concept II ceiling fan is poorly lit. Installed in my son's bedroom and it's useless, dim.
probably not the reason for the dim light. It probably has more to do with the installation where you have wired the light before or after the fan so that power so the bulb is reduced by the resistance in the fan.
lights and fans are wired in parallel so that one doesn't affect the other
Might pay to talk with an electrician on the issue
There is a limit on the size of the bulb that can be used and a 100 watt halogen bulb will probably melt the surrounds and set fire to the fitting
get a desk lamp for his homework
May 24, 2016 | Minka Concept II Flush 44 Ceiling Fan by...
Hardwired ceiling fan turned off by itself and stopped responding to remote control, but the light turns on/off.
I've had problems with Minka Aire also. You might need a new receiver. Call Minka @ 1-800-307-3267 and talk to someone in tech dept.. Should be a one year warranty on the receiver.
Aug 17, 2015 | Minka Lavery Minka Aire F888-BNW...
Light on ceiling fan is very dim. Do not have dimmer switch. Changed bulb but light is still dim. Could something be wrong with the fan?
If it has a remote, press down on the light button and keep it pressed down until your light gets to full brightness.
Apr 25, 2015 | Minka Aire Ceiling Fan
Minka Aire model f603 reverse switch?
Not sure what model of fan or manufacture you have. Says Hunter 52" & Minka aire F603. If it's the Minka , Then push the button on the lower part of the remote (6 o'clock). If that doesn't work then you might need a new receiver.
Jul 23, 2014 | Hunter 52" Ceiling Fan With Light And...
Minka Aire Ceiling Fan light wont come on
Probably needs a new remote receiver.Contact Minka Aire @ 1-800-307-3267
Apr 30, 2013 | Minka Aire Ceiling Fan
Minka aire concpet 1 ceiling fan issue
Ceiling fans have tiny "brains" that get fuddled when one tries to combine remote control and wall switches/pull chains. If you want to be able to use remote control, redo the installation omitting the other switches.
May 30, 2017 | Minka (F517ORB) Ceiling Fan
Minka Aire remote control ceiling fan problem with dimmer.
Did you ever find a solution to your issue? I have the EXACT same problem and have been looking for an answer for about a year.
Sep 20, 2009 | Minka Aire Ceiling Fan
Minka Aire Como F603 ceiling fan - light bulb replacement
Try Googling (Minka Aire)(F603)(manual) without parens for instructions.
Jul 28, 2017 | Minka F603-WH Ceiling Fan
Fans spinning opposite directions
somethings causing your magnetic drive to atomatically reverse, its probably a defect, i suggest you bring it back and get a new one!
Aug 12, 2008 | Dryers
Minka Aire Remote control R211
You need to change the tiny DIP switch settings so each fan is set up differently. (Note that each pair of remote transmitters--the one in the fan body, held in a bracket above the light kit when you drop that down; plus the one on the wall switch or in a hand-held remote, must be set with the same combination.)
Our Minka Aire Churchill model has 4 DIP switches; I have seen Casablancas with 5.
Jun 01, 2008 | Minka RC120 Remote Control
Minka Aire Ceiling Fan Logo
870 people viewed this question
Top Minka Dryers Experts
Joseph Coppeto
Joseph Coppeto
Are you a Minka Dryer Expert? Answer questions, earn points and help others
