Question about Canon NP 6551 Black and White Copier
Canon 6025 This machine is old but still working, I have a few things.... First, it will not pull paper from the letter tray I have to put it in the bypass tray. Also the copies come out with lots of streaks on the top and bottom of the page at first it was almost covering the whole page but I dumbed out the waste toner and now it's better but still not great. I cleaned every part I could get too. But I noticed where the orange and black roller is on top of it is that white fabric and that has a lot of black streaks on it. So what part do I need to replace? What is it called? The drum is clean...
  • Harmonious Apr 09, 2008
    I haven't had a chance to try it yet but I will :)
  • 82 Answers
Okay, for starters, it sounds like your machine has been properly service in along time. typically on this machine every 6-12 months. anyway turn off and unplug the machine. it will need the optics cleaned for starters( you must remove the guide plates and then remove the glass and be very careful but slide the scanner out and clean the 3 mirrors with glass cleaner and a very soft cloth. then reassemble. slide out the transfer unit and inspect but do not touch the drum, the machine should have come with a corona wire cleaner, clean them, very careful not to break them. reinstall. the cleaning web you are refering to is okay for one roller to be dirty but there are two, one that is new felt and the other is where the used or dirty felt is. then there are the orange and black rollers which should stay clean without any real marks if your cleaning web is working properly. then as far as all the rollers except the drum(never touch, ever.) you can use rubbing alcohol moistened cloth to wipe and turn, wipe and turn. your paper pick up tires are propably very dirty causing your machine to misfeed. so clean them all. they are right over where the paper drawer sits. Good Luck, Don't break anything. if you very careful you will be able to fix this machine.
Thank You,
Mikey
Posted on Apr 06, 2008
Canon Inkjet, Not Printing?
Hi Rosa,
There was a paper jam and you cleared the jam, however you missed out to do one other thing. Cleaning the Rollers.
If the Paper Feed Roller is dirty or paper powder is attached to it, paper may not be fed properly.
In this case, clean the Paper Feed Roller. Cleaning will wear out the Paper Feed Roller, so perform this only when necessary.
You need to prepare: three sheets of A4 or Letter-sized plain paper
1.Make sure that the power is turned on, and remove any paper from the Rear Tray.
2.Open the Paper Output Tray gently, and open the Output Tray Extension.
3.Clean the Paper Feed Roller without paper.
(1) Press the g0081065_tcm14-774017.jpg (Maintenance) button repeatedly until b appears.
(2) Press the Black or Color button.
The Paper Feed Roller will rotate as it is cleaned.
4.Clean the Paper Feed Roller with paper.
(1) Make sure that the Paper Feed Roller has stopped rotating, and load three sheets of A4 or Letter-sized plain paper in the Rear Tray.
(2) Make sure that b appears on the LED, then press the Black or Color button.
The machine starts cleaning. The cleaning will be completed after the paper is ejected.
This should fix the issue
Regards,Suhail
Nov 03, 2011 | Canon PIXMA MP495 InkJet Printer
Canon imageRUNNER 2200 paper tray 1 shows empty when it is full. Using letter paper with portrait orientation. Dial is set correctly for letter (LTR). (tray 2 is letter in landscape orientation. Dial is...
Please check that there isn't any paper jam behind the tray in the machine, this will block the connection from the tray to machine and prevent the paper lift mechanism from raising up into proper position. Hope this helps.
Oct 14, 2011 | Canon imageRUNNER 2200
Digital replacement for Canon NP 6025
"No" is the answer to all of those questions, and even if it were "yes", purchasing a good quality refurbished digital machine from a reputable supplier, would still be a far cheaper option than all of that.
Not in or around Toronto, are you?
Mar 12, 2009 | Canon NP 6551 Black and White Copier
Jamming paper
you have to replace paper pick up roller set
Dec 14, 2008 | Canon NP 6551 Black and White Copier
We have a Canon Laser Class 700 series fax machine. When it runs out of paper in cassette tray 1 it doesn't automatically begin to use paper from cassette tray 2. Both cassettes have plain white letter...
Swap cassettes.. The side guides on one of them may not be tight against the paper.
Only put paper in the lower cassette and try to print a journal.
Print out a configuration page or parameter list to see if the machine knows you have two trays.
Oct 30, 2008 | Canon Office Equipment & Supplies
Printer will not print: Canon imageCLASS D320
The paper size selected in the menu system must match the paper size in the rec. (recording) paper tray. If you have 'letter' size paper in the tray and the menu system is set for 'A4' paper you will get this message. Either put A4 size paper in the tray, or change the paper size in the menu system to 'letter'.
Oct 15, 2008 | Canon imageCLASS D320 All-In-One Laser...
Canon np6025
I have a NP 6025 that is jamming from the letter tray top not multi purpose tray. I cleaned the rollers that did not help. its making a grinding noise (best way to describe it) The paper gets jammed at various stages in the input unit I can open the right door and see the paper. Wondering if anybody has any ideas on how to fix this problem....
Sean
Feb 16, 2008 | Canon NP 6551 Black and White Copier
Paper tray selection
Go to Paper Menu > Paper Size > Tray 1 - note what the Auto setting states (Letter, A4, Legal, etc.) Pull the tray out to set what it is configured for. Then reinsert it & pull it out a few times, noting what the display show the Auto size show. It should match the tray's settings.
If the Display indicates otherwise, it means one of two things:
1) The "auto size sensing" board on the left may be defective. The left side of the tray has a matrix of 3 plastic tabs that stick out in certain order depending on the tray setting. If this board fails, it may show Executive or A4 when the tray is set for letter.
2) The tray may be in-between two settings. Try to readjust the tray length setting between sizes. (You will notice the plastic tabs will change order.) The last time you loaded paper it may have pushed it just enough so that it is no longer seen as letter by the auto sensing board.
I hope this helps...
Nov 28, 2007 | Lexmark Optra T610 Laser Printer
NP 6030 paper jam
It may be this simple:
1- as silly as it may seem, are you sure the size  is correct, if it is a letter size paper and it says legal, it will jam. open the paper tray and make sure the guides are snug againgst the paper,
does it say letter (or legal) for the tray you are going to use, if they do not correspond then look behind the tray inside the machine, is there a paper jammed in the back?
Or not so easy
2-You are having a sensor problem, take a look at the duplex tray,
pull it out and look at the sensors ( black little levers that stick out) are there any pieces of paper, can you move them and they spring back into place?
Oct 22, 2007 | Canon imageCLASS D761 Copier
Paper Jams on letter tray
The paper pickup rollers are dirty and needs cleaning. take out trays and give it a wipe with damp cloth, if problem remains than need to replace the rollers
Oct 12, 2007 | Canon imageRUNNER 3300 All-In-One Laser...
Canon NP 6551 Black and White Copier Logo
96 people viewed this question
old marine
old marine
