Question about Sony KP-61HS10 61" Rear Projection Television
Convergence Settings Hi, How do I access these convergence settings? Mine is blurry when it is turned on and then clears up with a red line shadow. Any ideas? Thanks!!
    Sergeant:
    Champion:
  • 319 Answers
Setting the convergence is not a user servicable item. Such adjustments need specialized equipment for proper alignment. Have unit serviced by pro/tech
Posted on May 12, 2008
My picture is doubled on my toshiba TN50V71 as if there is a shadow behind everything? Please help!
hi, sounds like a convergence issue. try this...
  • Look through your manual. Your manual will always give you the most specific directions for your particular model. Look for an "adjusting convergence" or "set manual convergence" section.
  • Enter the menu on your TV. Use the remote control and bring up the menu.
  • Choose "Convergence." This may be under "Picture Settings," "Function" or "Advanced Options."
  • Select a color. You will have red, green and blue to choose from. Do each one, starting with red.
  • Press "Enter." A crosshair pattern will appear on your screen.
  • Adjust vertically. If there is a horizontal red line visible, press the up or down arrow keys (or channel up or down) to adjust the convergence until the line is superimposed on the horizontal-center line of the white crosshair.
  • Adjust horizontally. If there is a vertical red line visible, press left or right (or volume up or down) to adjust horizontally. Do this until the line is superimposed on the vertical line of the white crosshair.
  • Save settings. It is important to save your settings when you are done, instead of simply exiting the menu.
  • Repeat these steps for all colors.
    good luck!
  • Feb 02, 2011 | Toshiba TN50V71 50" Rear Projection...
    Magic focus blue is fine, green and red are really blurry, tv picture is almost black and white. all bulbs are on.
    Tv have a problems known as a convergence problems,it dead.Any colors lines R,G,B mis alignment,have colors shadows pictures or 3D pictures.The tv convergence board,the 2 STK convergence ICS and some or all it resistors are dead.These parts,must be replaced on the convergence board,to solved the convergence problems.The shop,will cost u $300-350 for parts and labors.
    Sep 13, 2010 | Hitachi 53UDX10B 53" Rear Projection...
    I have red color behind words people on screen, blurry screen, like things don't line up.
    The tv have a problems known as a convergence problems,it dead.Very common problems on DLP projection tv.R,G,B colors lines mis alignment,colors shadows and 3D pictures.The problems is the convergence board parts the 2 STK convergence ICS and some or all of it resistors are dead.These parts must be replaced on the convergencce board to solved convergence problems.The shop will cost u $300-350 for parts and labors.
    Sep 03, 2010 | Televison & Video
    My Hitachi 43fdx01B went from a perfectly clear picture to one with red "ghosts" and very blurry. I my TV toast?
    No,ur tv have a problems,known as a convergence problems,it dead.Very common problems on the DLP tvs design flaw.Most commom problems are R,G,B mis alignment,will not align,Colors shadows pictures,3D pictured and blurry?The tv convergence board require changing the 2 STK convergence ICS and some or all it resistors are dead,must changes to solved convergence problems.The shop will cost u $300-350 for parts and labors.
    Jul 26, 2010 | Hitachi 43FDX01B TV
    Blue shadow
    Your TV most likely has a convergence failure. ( common problem )
    Here are some of the most common symptoms and example photos of a convergence problem
    • Screen looks 3D
    • Colors don't line up
    • One or more colors can't be adjusted when using the convergence menu.
    • Screen is bowed or warped.
    Here are some photos of convergence problems.
    Here is a quick test....
    Using your original remote go-to the tv settings then goto the convergence section.
    Try to adjust the red and then the blue convergence.
    You should be able to move them up, down, left, and right.
    If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
    0667c5f.pngSOLUTION
    You will need to replace the convergence chips and possibly some convergence resistors and pico fuses. Its a fairly easy DIY job or you can call in a pro. If you want to do the repair yourself check the site www.TvRepairKits.com. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, thermal paste, email/phone support, etc.
    Jun 20, 2009 | Hitachi UltraVision CineForm 55VG825 55"...
    Sony KP-51WS500 Rear Projection TV colors are distorted.
    • Screen looks 3D
    2c07611.pngSolution #1
    You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
    Mar 05, 2009 | Sony KP-51WS500 51" Rear Projection...
    Poor picture quality on Hitachi model # 53fdx01b
    Do not adjust any knobs as instucted in the previous thread if you TV have a convergence problem. Doing so will only make things worse. The blog does however show you how to fix other common problems with these sets.
    • Screen looks 3D
    Jan 20, 2009 | Hitachi 53FDX01B 53" Rear Projection...
    Mitsubishi rear projection tv
    replace vertical IC and shadows/ghosting the problem is either electrolytic capcitor or video IC or convergence adjustment
    Aug 18, 2008 | Mitsubishi WS-65809 65" Rear Projection...
    Blue is blurry
    take it apart turn blue lamp until it is clear. A napkin over the green and red lights during this step is very helpful
    Oct 27, 2007 | Philips Magnavox 51MP392H Rear Projection...
    Hitachi Big Screen TV 46 inch Problem
    • Screen looks 3D
    Sep 06, 2007 | Hitachi 46BX01B 46" Rear Projection...
    Sony KP-61HS10 61" Rear Projection Television Logo
    81 people viewed this question
    Top Sony Televison & Video Experts
    Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
