Question about Broksonic CTGV-5463TCT TV
Help I have a television that will not work. It does nothing. What can I do to fix this myself?
  • cjneedhelp Jun 11, 2008
    I can't get a picture, the horazonial hold has the picture all crossed up, I can't get a clear picture.
  • Anonymous Jul 03, 2008
    MY 13" TV KEEPS BLOWING FUSES. WHAT DO YOU THINK COULD BE SHORTED OUT? THE POWER CABLE?
BUY A NEW TV
Posted on Jun 18, 2008
SOURCE:
Broken GE HDTV - Need Help To Fix
The deflection board needs replacement. The chirping is indicating the deflection circuit has an issue. You can get a replacement deflection board from www.tvrepairworld.com which includes instructions on how to remove and replace the board.
May 26, 2010 | GE D52GW12 52" Rear Projection HDTV-Ready...
My Toshiba 53H71 has no sound at all. Great
With a little background electronic knowledge and luck you may be able to do it. If all selections from the menu are correct and volume is not stuck in min its generally it due to broken wires or loose connections. The speakers are in front behind the front grill. remove it and checkout wires and connections. If all these are good and speakers are okay, the repairs would require professional help. down load the manual from tech support from this site and follow the flow chart for no audio fault. You will reach apoint where its solved or you have enough leads to decide in favor of professional help.
Mar 24, 2010 | Toshiba 53H71 53 in. Rear Projection...
Will not turn on
Go to the following blog site for detailed instructions on how to fix the TV yourself for around 2 dollars! I fixed mine myself this weekend and I know nothing about TV's. Thanks to this site, I saved hundreds of dollars.
http://brentlavelle.blogspot.com/2007/12/i-fixed-my-jvc-av-36980.html
Good Luck...............Kim
Oct 13, 2009 | JVC AV-36950 TV
RCA 32V550T Nothing happens when you press Power. NOTHING.
This set needs a flyback transformer p/n 262342, and a horizontal output IC, location number on the board is q14401 and crosses to NTE2353. When you're in there too touch up any bad solder joints you can find. Fixed several of these with the same problem.
May 25, 2009 | RCA 32V550T 32" TV
Panasonic rear projection TV won't power up
i have the same thing going on email me if you find out how to fix [email protected]
it had a blue bow but now nothing help
Jan 30, 2009 | Panasonic PT-43LC14 43" Rear Projection...
CONVERGENCE OUTPUT I.C.
Nextag and eBay are turning up nothing for this model. In comparison to other manufacturer's prices, the quoted price is not "unreasonable." Projection TV repairs are certainly not cheap. Sorry.
May 24, 2008 | Samsung HCN653W 65" Rear Projection...
HITACHI 43UWX10B Color Convergence
Good Day,
Sounds like the TV's convergence circuit has failed:
*Call an Authorized Service Center and them give you an estimate cost of the repair, or
*Repair it your self; get KIT 10 locally or B&D Enterprises
1-800-458-6053; www.bdent.com.
Good luck, big IRISH.
Apr 28, 2008 | Hitachi 43UWX10B 43" Rear Projection...
RCA P46921. Just changed flyback.
if nothing has been tampered with ie. focus controls, lens focus, I would check to make sure the high voltage lead is seated correctly.
Mar 16, 2008 | RCA P46921 46" Rear Projection Television
Phillips hd 1080 60 inch rear projection
if your colors are off i fixed it myself they wanted alot of money to fix it so i did it myself......here's my email if you need my help....
[email protected]
Jan 23, 2008 | Philips 60PP9202 60" Rear Projection...
Won't turn on
take to shop
Sep 26, 2007 | Zenith Z32H41D TV
Broksonic CTGV-5463TCT TV Logo
35 people viewed this question
Top Broksonic Televison & Video Experts
Marvin
Marvin
Are you a Broksonic Televison and Video Expert? Answer questions, earn points and help others
