Question about Mitsubishi VS-45607 45" Rear Projection Television
TV keeps shutting off
My Mitsubishi VS-45607 manufactured Oct 2000 keeps shutting off while I'm watching TV. When I try to turn it back on it won't go back on. I have to wait about an hour and then it will go back on. Could you please tell me what is wrong and how to fix it?
  • 4 more comments
  • JeanJ40 Apr 06, 2008
    Dear Slinteriors, I did what you requested and after the flash the two digit code is 2 4 Can you help me understand the the code means. thank you......
    Thank you so very much for your help. I'm very impressed and I appreciate your help. Do you have any idea how much this will cost me?
    Thank you very much again. I am going to look behind the TV and see if there is any milky residule and see if I can tell by looking at it what the problem is. I did visit your web site and I think I may buy the service manual. When I need help in trying to do this myself, will I be able to request your help? I sorta feel a bond here..... :)
    ok. I have to leave for a while so I'll get back with you sometime tonight. I will go back to your website and order the manual I need. I will want your help. I'm not sure if I can do this, I'm a little scared of the voltage. But, I will try. Thanks again.
  • JeanJ40 Apr 07, 2008
    Hi, I ordered the manual by paypal so, when I get the manual I'll contact you again. Thanks again. Talk to ya soon.
  • JeanJ40 Apr 09, 2008
    Hello again I just looked at the CRT's and I did not see any leakage, or any milkly looking film. So waht do I need to look for now. Could you please help.
    Thank you
  • Mitsubishi Master
  • 8,617 Answers
Push the menu and inputs buttons on the set in both together and hold for 8 seconds this should make the led flash a two digit code. Let me know what happens after doing this test.
Posted on Apr 05, 2008
  • 4 more comments
  • Sonny Berry
    Sonny Berry Apr 06, 2008
    24 means your set has shut down due to vertical deflection failure. This model has had some issues with bad solder. as well as the CRT coolant dripping on the area of the vertical output IC detroying the solder and corroding the IC. Check for signs of a milky residule in the area of the vertical IC which will indicate a leaky CRT seal. If residule is found,a new CRT seal and coolant change will be needed then, Cean that area and resolder the components in that area especially the vertical IC. If no residule is found try resoldering the Vertical IC, and the Vertical yoke plugs and see if this helps if not your vertical output IC may be faulty and need replacing.
  • Sonny Berry
    If its just a solder issue you can do this yourself with no cost. The IC if that needs replacing is under 20.00 for the part. and even the seal is relatively inexpensive around 10.00 for the seal and another 20.00 for new coolant if the crt has leaked. However if you have the repair done at a repair shop they will inform you that you need a new CRT and new board and will probably put the charge at about 700 to 800 dollars. Sad but true. But if you are handy I will post a link where you can actually get the service manual at a reduced cost emailed to you and they will provide free tech support to actually walk you through the repair step by step. The site belongs to me and two other techs that have been doing repairs for 25 years and we decided to start this service a few years ago as a way to genuinely help people do these type of repairs themselves. Most repairs can be handeld by the consumer as long as they have the service information at hand and an experienced tech that will point out the cautions and the proper way to perform the repairs. Here is the link if you want to save your set without it costing you an astronomical fee.
    http://servicemanuals.vstore.ca/
  • Sonny Berry
    Yes and if you do get the manual you can request that I be your tech for the free support or you can continue posting here to me as well. Thanks slinteriors
  • Sonny Berry
    I will walk you through it, and I will point out anything that could be dangerous. Which are capacitors but when they are discharged properly which is easy with instruction there is really little to worry about. I have had many people tell me that its a great feeling when they have never touched a set before and then actually repaired the set themselves.
  • Sonny Berry
    Sonny Berry Apr 07, 2008
    ok, just let me know if you need any help
  • Sonny Berry
    Sonny Berry Apr 10, 2008
    Check the vertical output IC solder. try resoldering that and the yoke plug thats the first thing with this chassis. They are both located on the main bd.
SOURCE:
Mitsubishi VS-45607 turns off immediately when I try to power up
STK ICS replace Both of them STK393-570 big black ICs will have STK on them Call mats for parts 1-800-628-1118
Dec 20, 2009 | Mitsubishi VS-45607 45" Rear Projection...
TV will not turn on
you either have leaky capacitors near the voltage regulators, cooling fluid leaking on the boards, and/or bad solder connections on the yoke plugs. this model is known for all 3 problems, but you probably need a qualified tv repairman to fix this right.
Sep 17, 2009 | Mitsubishi VS-45607 45" Rear Projection...
Black horizontal lines. Looks like I am looking through venetian blinds
OK this problem is caused by a failing electrolytic capacitor back in the power supply. It's job is to filter AC interfence from that voltage source. Locating the correct capacitor is something not for a do-it-yourselfer. A respectable tv shop experienced with Mitsubishi tv's can usually repair this problem in your home. Average repair cost would be between $200 and $300.
Apr 27, 2009 | Mitsubishi VS-45607 45" Rear Projection...
Mitsubishi VS-5046
i have a 50in mitsubishi tv model vs5046 the screen protector is crack the tv works fine but need to know where can i purchase a protector or its there a number. also how much will this cost.
Oct 30, 2008 | Mitsubishi VS-45607 45" Rear Projection...
Mitsubishi VS-45607
there is a protection circut that will shut down the tv when it detects a failure in one of the components , when components heat up to much they go into thermal breakdown, the part that is heating up and failing is getting worse , so it will need to be test to determine which one
Oct 09, 2008 | Mitsubishi VS-45607 45" Rear Projection...
Vs-45607
Good Day, chefkenny;
This the fix ya you are looking for;
CHECK C2P05 100 UFD 16 V OFF PIN 3 OF IC2P01 AND IC2P01 PART # 270P466020 (9-VOLT REGULATOR). BOTH ARE ON THE SIGNAL PCB.
Good Luck, big IRISH.
Aug 07, 2008 | Mitsubishi VS-45607 45" Rear Projection...
VS-45607 Rear Projection Television
Resoldered connector DY on the yokes and check caps C411, 2200uf/35v and C412, 10uf/50v on main pc board.
Bill
May 04, 2008 | Mitsubishi VS-45607 45" Rear Projection...
Mitsubishi Big Screen VS-45607
probaly bad wiring or shorts in the wires or something is intefearing with your tv if it is wiring it might be a fire hazard
Feb 13, 2008 | Mitsubishi VS-45607 45" Rear Projection...
Mitsubishi VS-45607
Do self test first goto www.ctechnicians.com
Dec 08, 2007 | Mitsubishi VS-45607 45" Rear Projection...
Mitsubishi VS-45607 45" Rear Projection Television Logo
400 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
