Question about GPX D1816 DVD Player
How do i connect my GPX dvd player to my hd tv? I have Direct TV also.
How do I connect my GPX DVD player to my HD TV that has Direct TV attached to it? Which cables do I use?
  • 3 Answers
I also have a GPS DVD Player and Direct TV. On the back of the TV there are slots for AV1 and AV2, I chose AV1. The yellow cable is your video.When placing the YELLOW in the video I noticed the pic was Black and White. After changing it to the slot marked Video Y the color came back. The white and red are audio. I put the WHITE in Audio L and the RED next to it in Audio Pr. Granted I am using a Phillips TV but the concept is the same. Hope this helps. If you don't have sound, switch the position of the Audio (red and white) cables.
Posted on May 09, 2008
How hook up dvd player to tv. what channel put tv on to see dvd pitcure
You should be connecting your DVD player to either an HD input or a composite video connection. Most modern TV SHOW will have at least 2 HD connections. On your TV setup menu there should be an HD connection to choose (probably HD-2) You will need to switch your input selection on your TV menu between HD/TV for TV and HD2 for DVD. It's hard to give specific directions without knowing the TV and DVD models.
Oct 27, 2016 | Televison & Video
Get RCA DVD Player to work.
ok on dvd player u wann use hdmi cable direct to tv ok then select input hdmi on tv remote to see picture
Feb 02, 2008 | Thomson Lyra PDP2860 Digital Media Player
Westinghouse LTV-32w4 HDC widescreen DVD Combo
Hi Mouse999. From reading a bit, it seems that there's no region free hacks for the built in dvd player in that specific model. A solution for you, would be to purchase a standalone dvd player, one that is region free or one that has a region free hack available, and to connect it to that tv. If you're in europe and your tv is pal, you also need to have a dvd player that will read both Pal and NTSC video dvd's ! If that doesn't help, please be more specific, i'll be glad to help. Thanks, cheebster.
Jul 10, 2007 | Westinghouse LTV-32w4 32.02 in. LCD HDTV
I have a Toshiba tv that is connected to Direct tv and I want to know how to connect my new Phillips dvd player to it my tv?
Flat screens normally have 3 different inputs from tv. Regular is tv coax cable, then audio/picture by using special rca cables, then last HDMI. You can use any of those inputs except hdmi because you already are using that input. You may be able to buy a hdmi splitting device that will allow both the tv and the player to input to the single hdmi input. Check Radio Shack or Wal-Mart.
May 12, 2014 | Toshiba HD-A30 HD-DVD Player
I have surroundsound. I have dish network with hd dvr. I have a sony bravia hd tv. I have a dvd player, and cd player. I have a magnavox dvd recorder. I want to record from my dvr to my dvd recorder. ...
To get the functionality you're looking for you'll need to to take the cable running from your DVR output and connect it to the input on your DVD recorder. Next you want to connect a cable from your DVD recorder output and connect it to your TV. If this is an HD set up you want to use HD Cables for all of the connections.
Daniel Busa
DISH Network Customer Service
Jan 03, 2011 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Can not install to telivision, need help with wire connections,do not know what hookups go where lost manual,have three connections on wire,red,yellow and white, where do they go on dvd player and to where...
This is very simple
First on the back of your dvd player there should be the holes with the same colors as the cable you have, yellow (video in) in the yellow, red (left audio) in the red e.t.c.
Then either on the side or the back of your tv there should be the same sorta thing, depends if you have a HD TV or a regular freeview/analog tv. With hd there should be green blue red white and yellow, just the same as the DVD player, plug the cables into the right colors as i said,
Same goes for the regular TV, just do exactly the same as you have done with the dvd player,
Switch your channel to dvi or av1/2/3 and your dvd player should be working
Jul 25, 2009 | GPX D1816 DVD Player
How to connect blue ray to philips 46" hd tv with direct tv service
Connect using hdmi or component video from dvd player to tv.
Apr 24, 2009 | Televison & Video
How do i hook dvd player to tv..i know its probably simple
The yellow and white cables hook into your tv inputs
Jan 19, 2009 | GPX D1816 DVD Player
TV connections- Wii, Direct Tv and DVD palyer
Hidden switch for output coonections on back panel of dvd player.
Dec 27, 2008 | Digital Lifestyle FA1B32Z 32 in. LCD...
I am having problems hooking it up to an HD Receiver from Direct TV
playback and record are 2 different things. playback, you connect the DVD player audio-video OUT to the audio-video IN of the TV. recording, you connect the DVD player from the audio-video IN to the audio-video OUT of the source (i.e. cable box, set-top box, etc) hope this helps!
Oct 29, 2006 | Samsung DVDR120 DVD Recorder
GPX D1816 DVD Player Logo
309 people viewed this question
Top GPX Televison & Video Experts
Jaime Hernandez
Are you a GPX Televison and Video Expert? Answer questions, earn points and help others
