Question about Nintendo Wii Console
Wii remote signal
I remember when i got my wii about a year ago when i could play bowling from about 10 feet away. Now all of a sudden it is like i am having to get closer and closer for my wii remote to get contanct with the sensor bar. Is there a way to reset the sensitivity or something to solve this. Thanks.
    Problem Solver:
  • 10 Answers
Try usin an other wiimote and is it is the same mabe u just need to buy a new one - click here
Posted on Apr 05, 2008
SOURCE:
Unresponsive Wii remote!! HELP!!
The issue is with your game unit and NOT the nunchucks and/or remote.
Jun 12, 2017 | Nintendo Controller add-on Nunchuck for...
Remote control won't work 10 feet away but if two feet away it works. What gives?
the remote uses light to send a signal to the tv. make sure there isn't anything interfering with the light signal. it could be dirty or the receiver could have dirt obstructing the light.
Mar 20, 2013 | Panasonic TC L42E50 - 42" VIERA E50 Series...
Wii controller is not working, no lights at all coming on
Try this following steps: 1. Check to make sure the Sensor Bar cord is inserted into the back of the Wii console and the Sensor Bar is centered above or below your TV screen. 2. Make sure you are using fresh batteries in the Wii Remote. 3. The Wii Remote Controller should be used between 3 to 10 feet from the TV. 4. Make sure no objects are blocking the signals between the Sensor Bar, the Wii console, and the Wii Remote. 5. Check for interference from infra-red light sources, such as candles, sunlight, fireplaces, and stoves. 6. Radio frequency interference may cause the Wii Remote to work erratically.
Mar 30, 2011 | Nintendo Wii Remote Controller
Wii remote does not have little hand/arrow
First, follow these guidelines to ensure you have set up the system properly to have the optimal environment in which to use the Wii Remote:
  • Check to make sure the Sensor Bar cord is inserted into the back of the Wii console and the Sensor Bar is centered above or below your TV screen
  • Make sure you are using fresh batteries in the Wii Remote.
  • The Wii Remote Controller should be used between 3 to 10 feet from the TV.
  • Make sure no objects are blocking the signals between the Sensor Bar, the Wii console, and the Wii Remote.
  • Check for interference from infra-red light sources, such as candles, sunlight, fireplaces, and stoves.
  • Radio frequency interference may cause the Wii Remote to work erratically. Check for wireless devices such as cordless phones, wireless computer keyboards or mice, or other similar devices, and move or turn them off.
Click here to download repair guide
Dec 26, 2010 | Nintendo Wii Console
Bought nintendo wii last xmas and had played quite frequently. then after a break in play of a few mths the remote controls dont seem to be being picked up by the sensor. i chenged the batteries and still...
Hello there
Hold the Wii Remote upside-down with the buttons facing downward.
Tap the remote firmly against the palm of your hand three times to remove any dust sitting between the buttons and the electronic circuit board inside the remote.
Turn the remote upright and press one of the buttons. If the problem continues, Open your Wii Remote's battery door
Check that your Wii Remote contains two new "AA" batteries or a charged battery pack. Check that no corrosion is present on the battery's metal elements/connectors.
Use a cotton swab to clean the remote's battery element/connectors if corrosion is present.
Check that the Sensor Bar cable is inserted firmly into the back of your Wii gaming system. The Sensor Bar needs to be centered above or below your television so the Wii Remote can transmit signals to the gaming system.
Stand three feet away from the Wii gaming system/Sensor Bar.
Aim the remote and press any button to test the device.
If the remote is not working, stand five to 10 feet away from the gaming system and try the device. The Wii Remote works best three to 10 feet away from the gaming system/Sensor Bar.
Move any objects blocking the signal from the remote to the gaming system/Sensor bar--candles, other remote controls (TV/cable box) and wireless computer devices/cellular phones.
Also, if any sunlight is coming in through a window, close the curtains or blinds to keep the light from interfering with the remote's signal.
Turn off and unplug your Wii gaming system. Leave the unit unplugged for one minute. Plug the gaming system back in.
If the remote still aint working;
Turn the Wii system on. Press and hold the red "SYNC" button for 15 seconds when the "Health and Safety" screen appears on your television. The "SYNC" button is behind the small door on the front of your Wii unit.
Release the "SYNC" button. Remove the battery cover and batteries/battery pack from the back of your Wii Remote.
Press and release the red button located under the battery compartment. The blue lights on the front of the remote will blink
Press and release the "SYNC" button on the front of your Wii gaming system. The "Player" light on the gaming system stops blinking and stays on, the resetting process is complete
Oct 01, 2010 | Nintendo Wii Console
Pokemon Battle REvolution rental can't start the game
it could be simply that the remotes are not turned on.or it could be that they are not pointing it at the motion sensor or they are standing too close.
I would advise to stand atleast 5 feet away from the screen
note that the blue pokeball is the wii remote pointer
Mar 01, 2009 | Nintendo Pokemon: Battle Revolution for...
Nintendo wii problems
Hold the Wii Remote with the button side down. Without using much force, firmly tap the button side of the remote against the palm of your other hand a few times. Doing this does not take a lot of force, so be sure not to tap the Wii Remote very hard. Check for proper response.
  • Check to make sure the Sensor Bar cord is inserted into the back of the Wii console and the Sensor Bar is centered above or below your TV screen.
I hope this fixes it for you!
Jul 08, 2008 | Nintendo Wii Console
Wii bowling
This will only happen when you are a beginner.... Once you have played a few games it will go away. If you are playing as a guest the bar will always be there.
Nov 18, 2007 | Nintendo Wii Console
Nintendo Wii Console Logo
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Ekse
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
