Question about Gateway Belkin 54g Wireless DSL/Cable Router (DHF5D72304)
Deafualt gateway appears offline
I can access the internet but random sites and not msn i get the message "default router appears to be offline"
  • 1 more comment
  • Anonymous May 05, 2008
    lost key
  • Rik89 Aug 21, 2008
    hey, my router stopped working completely this morning, then i messed around with it, now i can access normal internet pages, google, bebo etc... but i can't sign into msn or the PS Network on my Playstation 3 , can anyone help?
    thank you.
  • barnsyboy1 Nov 07, 2008
    I have the same problem. My Belkin worked fine and one day for no reason it just started going wierd.I log on to the router and it says that internet is connected and nothing seems wrong with it at all. However it will only load certain sites such as google, Apple home page e.t.c. It will not upload others however, such as facebook msn e.t.c. There is no relation between the sites it will and will not load they are just random. On some sites it will half open them then give up. There are alot more sites it will not let me on that it will let me on, its frustrating. The lights on the front of my modem all light up one by one as usual back when it did work, but once they are all lit up the phone line connection and web connection lights go out then slowly come back on again until the internet finally connects (with this problem). My xbox 360 wont connect to the internet either.
    It comes up with this when I try to get on some websites.
    Proxy ErrorThe proxy server received an invalid response from an upstream server.
    The proxy server could not handle the request GET (whatever site i want to get on to).
    Reason: Error reading from remote server
    Please note I use a Mac not a PC. However I do have a PC that uses wireless to connect to the modem.
Como me conecto con el puerto serial para ver la configuracion que tiene y cambiarla
ya tengo conectado el cable estoy probando a velocidad de 9600 y otros y no me da coneccion
Posted on Dec 01, 2008
    Problem Solver:
  • 10 Answers
Hi srini here
The site could have been blocked in the router.
Check it out.
Posted on Apr 25, 2008
SOURCE:
MSN disconnects me from the internet
Please access your router default page and disable WPS(WIFI protected system) option. And then once your done disabling the above option, and if you still have any problems,
                                       OR
Try uninstalling messenger and reinstall it again or try using windows messenger the default one which windows provide and try using that and see if you can work on it with no hastle.
Regards,
Yateesh, Bangalore.
Nov 02, 2009 | Microsoft Windows Live Messanger
My internet is not working. When MSN messenger checked for basic conductivity it said that the "Default Gateway appears to be offline." Is this a problem with my computer or with my whole...
-that is stating that there is an issue between the gateway AKA your router and the internet.
-try restarting computer first, if that fails to give you an actively working connection. if that fails try the following and that should clear up any issues you may have unless the internet is down for whatever reason, unpayed bill etc...
-so if there is a modem and a router unplug all devices from each other and unplug the router and modems power cords. restart computer. after windows boots up plug in ethernet cords back appropriately (telephone looking cables) to each other. plug the power cord to modem first then the router's power cord and your internet should be restored.
Nov 15, 2008 | Computers & Internet
THE MODEM HAS A BUILT IN FIREWALL TURN IT OFF ACCESS IT TIPE 192.168.0.1 INTO YOUR BOWER ON FIREFOX OR NORMAL INTERNET EXPLORER THEN UR USER ID IS ADMIN THEN PASSWORD IS MOTOROLA ONLY WORKS FROM YOUR MODEM ONLY AND INTERNET SERVICE ONLY
Jun 26, 2008 | Arris SB5100 SURFboard DOCSIS 2.0 Cable...
Gate way offline
Hi Srini here,
Try the following steps :
1-Log in to ur router by typing 192.168.2.1 in to address bar of ur internet explorer.
2-select "Virtual Servers" tab under firewall & select MSN Messenger option in the combo box on the top & apply.
It may fix your problem.
Mar 27, 2008 | Gateway Belkin 54g Wireless DSL/Cable...
Access to my settings
make sure that is your default gateway. go to your command prompt and type in 'ipconfig'. Use your default gateway to access your configuration settings.
Feb 07, 2008 | Zyxel Prestige 660HW Wireless Router...
It is best to use the reset button on the router to start over.
if it then connects you will have to reset all the passwords and setting you had previously.
Jan 26, 2008 | Gateway Belkin 54g Wireless DSL/Cable...
Static IP on machine, no outside access
Double check that the Default Gateway in TCP/IP properties is the routers LAN IP address (By default this is 192.168.1.1) Without a gateway installed, there will be no Internet access. After verifying this go to Start>Run and when the "Run" window appears type command into the "Open" Field, then click OK Once the Command prompt appears type in: ping 207.69.188.185. If you don't get a reply, the gateway is not installed. If there is a gateway already installed, check for any third party firewalls that may be installed on your computer. These can sometimes block Internet access. For more information please see the related article on assigning a static IP address behind the router. If still having problems, contact Linksys Technical Support.
Feb 16, 2006 | Linksys EtherFast Cable/DSL and Voice...
Feb 16, 2006 | Linksys BEFSR11 Router
Feb 16, 2006 | Linksys EtherFast Cable/DSL Router
Feb 16, 2006 | Linksys WRT51AB Wireless Router
Gateway Belkin 54g Wireless DSL/Cable Router (DHF5D72304) Logo
151 people viewed this question
Top Gateway Computers & Internet Experts
Ekse
Prashant M
Prashant M
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
