Question about Panasonic DVD-LS50 Portable DVD Player
Panasonic portable dvd player - error code HO3
  • 2 more comments
  • albet Apr 11, 2008
    i have the same error code HO3, pls help me how to rectify it.
  • flyleaf Jun 09, 2008
    whenever i put a cd it says loading but then i have this error code:HO3 hoe can i fix it?
  • mssrosemary Jan 11, 2009
    my dvd player reads the disc and then a couple sec. later on the top it says code ho3
  • Anonymous Feb 28, 2009
    Hey i have a LS50 and I played a new DVD Disc 1 all went well then i put in the disc 2. it read it and then Coded me the H03. So if it was the issue stated abouve then why does it read the 1st disc. It does fine with disc 1. Please help
    -Dez
    Brigadier General:
  • 6,966 Answers
On most Panasonic, error code HO3 indicates a mechanical problem, more specifically, the cradle that supports the laser eye could not traverse along its path. Corrective action requires opening the unit, cleaning the slider bar, plastic cogs, worm gear/drive. It may help to use a can of compressed air and re-lubricate appropriate parts. Since the unit is open and expectantly dust would be swirling after the use of the compressed air, it may be to your advantage to swab/clean the lens itself prior to closing.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Posted on Aug 18, 2008
SOURCE: Panasonic Portable Player DVD-LS53
Check this site out, I helped me.
http://www.pechorin.com/m/2007/07/05/panasonic_dvd_ls91_error_code_H03-296059.html
chemguy
Posted on Jul 27, 2008
Benimur
  • 6966 Answers
SOURCE: Error code HO3
Benimur
  • 6966 Answers
On most Panasonic, error code HO3 indicates a mechanical problem, more specifically, the cradle that supports the laser eye could not traverse along its patch. Corrective action requires opening the unit, cleaning the slider bar, plastic cogs, worm gear/drive. It may help to use a can of compressed air and re-lubricate appropriate parts. Since the unit is open and expectantly dust would be swirling after the use of the compressed air, it may be to your advantage to swab/clean the lens itself prior to closing.
Benimur
  • 6966 Answers
SOURCE: Panasonic portable DVD player
SOURCE: HO3 error panasonic DVD-LS80 disc will not play?
como hacer funcional el lente del equipo, tengo un error h03 VDV-LS80
Posted on Feb 25, 2011
Player does not read disc-code HO3
I followed a few, of the already suggested answers. The first one I tried was to open up the back and use compressed air to blow out lint, food crumbs and dog hair that had found there way into the machine. This seem to have worked just fine. Now the machine is working, much to my daughters delight.
Sep 29, 2009 | Panasonic DVD-LS90 Portable DVD Player
Panasonic dvd player, wont play error code HO3 keeps coming up, took it back to shop they wont help as cant find receipt
On my DVD-LV50, I was able to re-initialize and fix a different error (error code H05). It might work for you, too.
With no disk in the player, press and hold these buttons for 4 seconds:
  1. Back skip -- [ |<< ]
  2. Pause -- [ || ]
  3. Play -- [ > ]
The screen will go blank, then say "Initialized."
After that, it worked like new.
I hope that helps.
Oct 17, 2008 | Panasonic DVD-LV50 Portable DVD Player...
Error code HO3
Aug 18, 2008 | Panasonic DVD-LS90 Portable DVD Player
Error code HO3
Aug 04, 2008 | Panasonic DVD-LS90 Portable DVD Player
Mar 29, 2008 | Panasonic DVD-LS90 Portable DVD Player
Code h03
Hi the code HO3 relates to their being a problem with the laser you could try using a lense cleaner and see if its just dust or something like that failing that its going to be getting the laser replaced let me know if you need further assistance.
If you type in your search box this
DVD-LS90 Portable DVD Player with screen HO3
then search this will then list a load of sites that cover your dvd player and will also tell you what that error code means have a look and if you was getting it repaired then their should be a few sites that are selling the parts you need ok
Mar 19, 2008 | Panasonic DVD-LS90 Portable DVD Player
Code ho3
Jan 05, 2008 | Panasonic DVD-LS90 Portable DVD Player
HO3
See my post on this http://www.fixya.com/support/t160505-hd03_error
Jul 28, 2007 | Panasonic DVD-LS5 Portable DVD Player with...
CODE HO3
check my response here http://www.fixya.com/support/t160505-hd03_error
Feb 20, 2007 | Panasonic DVD-LS5 Portable DVD Player with...
Panasonic DVD-LS50 Portable DVD Player Logo
2,318 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
