Question about GPS
Tomtom one, file access error/unable to store settings after selecting voice type. Tried restoring backups etc, but can't get beyond this. Bought it off ebay and the sd card is not an original. Contacted the seller and he said he lost the original!
  • 515 Answers
SOURCE:
Fully charged will not turn on or reset unit is not damaged had been working fine. turned it off and now nothing.GO 2535 WTE
Restoring your Favorites and personal settingsIf you reset factory settings or update your map you can restore your favorites from a device Backup.Your Favorites are located inside your map folder, stored in the file MapSettings.cfg. This file consists of the following:Home addressRecent destinations Favorites Connect your Tom tom to the computer and select the option below that best fits your situation:If you are going to be installing a new map to your TomTom or you plan to perform a factory (hard) reset on your device, choose Backup and restore Favorites from your TomTom. If you have already installed a new map or performed a factory (hard) reset, choose Restore your Favorites from a previous backup.Restoring Favorites from a previous backup can only be done if you have previously performed a backup of your Tom Tom device.
Aug 18, 2011 | Tomtom GPS
Voice frequently not working. this problem intermittent. what do i need to do to ensure voice always works? Turning sound off and on again sometimes works. Turning on before using sometimes gets voice...
Are you using a synth voice, or a sampled voice? If the latter, one of the voice files might be damaged, and in that case, as soon as the Tomtom accesses it, the whole voice function will shut down.
Try changing the voice and see what happens. The synth voice does not access any sample files and should always work (or never at all).
To restore the functionality, download again the voice files, or try restoring from the PC backup. At least, this worked for me when I had the same problem (but MY file was damaged at the end, so I was able to notice that the last thing the Tomtom said was always "In sevent*". The damaged file was, I suppose, the one with the word "seventy".
May 29, 2010 | Tomtom GO 910 GPS Receiver
It shows a 'X' mark
the other users who faced the same error tried this instructions and solved the problem as follows:-- We have a result!
After calling the helpline to find it was number unobtainable! I returned the unit to Halfords who called another helpline number. They took my e-mail address and when I returned home an e-mail was waiting with the following instructions which worked.
I now have a fully functioning TomTom! Thanks for the advice fellas:
Thank you for contacting TomTom Customer Support.
In this email you will find the solution for the error on your TomTom. This solution can be used in the following situations:
• The device hangs in the start screen (splash screen)
• An SD-card with a red cross is displayed on the screen
• A picture with a red dot and white cross is displayed
• The device can’t be turned off
If you haven't already done so, please download and Install TomTom Home from http://www.tomtom.com/7602
If you don’t have a full backup of your TomTom yet we advise you to make one before continuing with the steps in this email. You can make a backup by following the steps below:
1. Reset your TomTom device: http://www.tomtom.com/6965 and connect it to your computer.
2. Click on 'Backup and Restore -> Backup' in TomTom Home 2.0
3. Enter a name for the backup and click [OK]
• IMPORTANT: When the software is asking to delete parts from the backup click [NO]
After the backup is made you delete the files from the root directory of the TomTom. Follow the steps below to do this:
2. Open My Computer in Windows, or Finder in Macintosh from your desktop and turn on your TomTom device.
3. On your screen a new removable disk appears, this is your TomTom device, click on the disk to open it.
4. You will see a list of folders and a list of loose files
5. Delete all of the loose files. IMPORTANT: The folders with their content must NOT be deleted.
5. Close the window when all files are deleted by clicking on the [x].
Next we will reinstall the application via TomTom HOME.
1. Start TomTom HOME on your computer
• TomTom Home should automatically check for updates and prompt you to install them, if not:-
2. Click on 'Update my device'. If you get the message 'No Items Available', or there is not an application to download, click on 'Add Maps, Traffic, Voices etc -> Items on my computer', select the application and click on 'Add'.
3. Select the Application update.
4. Click on 'Device -> Disconnect Device', then turn off your device when it is done installing and disconnect it from your computer.
5. On a PC, in the System Tray by the computer clock, click on the 'Safely Remove Hardware' icon and disconnect the TomTom also in this way.
When switching on the device it should boot as normal again.
Nov 03, 2009 | Tomtom GO 720 GPS Receiver
Can not use computer voices on my tomtom 520t
On your device you may have a corrupt file that is causing the noise distortion when you use the computer voices. The solution to this is to completely remove the software from your device and reinstall it again as described in the steps below. Please ensure that you have the latest TomTom Home software installed on your computer:-
You can download and install the latest version of TomTom HOME from the following link:
http://www.tomtom.com/home
Once you have the latest version of TomTom Home installed, please follow these steps:-
STEP 1. Creating a Manual backup of your TomTom
• Charge your unit for at least two hours (preferably via the home charger)
• Perform a reset on your device (see: http://www.tomtom.com/6965 )
If you have not made a backup yet you can do so by making a manual backup of your TomTom. To do this, please look at the following web page:-
http://www.tomtom.com/3171#backup
• Connect your TomTom to the computer
• Open My Computer, you should see the TomTom as a removable drive, double click into it. (on a mac you will see the TomTom as a disk drive on your desktop)
• You will see a list of files and folders.
• Copy all of the folders on the TomTom, one by one to the backup folder. DO NOT copy the 'Loquendo' folder.
• This can take up to 1 hour to complete depending on the device.
• If you get any error messages while copying, move on to the next folder and copy that to the backup folder.
• If possible, please make a note of any error message that occur while copying the folders, and make a note of which folder causes the error message.
IMPORTANT: We advise you to follow the next steps ONLY if you have made a successful backup of your device as described in step 1. If you are unable to complete step 1, please reply back with a list of yellow folders that you have managed to successfully copy to your PC and also reply back with any error messages that you receive at this point.
STEP 2. Format the hard-disk,
• Open 'My Computer'
• Right click on the TomTom icon (the device should be seen in drive E,F,G,H,I etc) and select 'Format'.
• Do a full format by selecting FAT 32 and click on Start, do not select 'quick format'. The TomTom is now formatted.
• Disconnect the TomTom from the computer and switch it on. It will load up with a red cross on the screen.
• Reset the TomTom with a paperclip in the reset hole for 30 seconds, see http://www.tomtom.com/6965 in how to do this.
• Once Reset, switch the TomTom off, disconnect it from the computer and then switch it back on again, it will still show a red cross on the screen.
STEP 3. Restore the Folders to the TomTom
• Connect your TomTom back to the computer and make sure it is switched on
• Go to your backup folder on your desktop, double left click into it. You will see all of your backup folders.
• Copy the folders one by one to the TomTom by right clicking on the folder, select copy then open My Computer, double left click onto the TomTom drive and choose paste.
• Turn the device off (with the on/off switch) and disconnect it from the computer.
• Switch the TomTom back on.
STEP 4. Update your device
• Open TomTom Home
• Connect your device to the PC
• A list of updates should appear, if not, click on Update my Go
• Select only the program application update.
• Click on Update and Install.
• Once Installed, open TomTom Home
• Click on 'Device -> Disconnect Device'.
• Switch your TomTom On to complete the installation.
The Application is now installed, and your TomTom should now be working.
STEP 5. Run the Clear Flash Tool
• Close TomTom Home. (on a PC, make sure you close TomTom Home from the system tray in the bottom right hand corner of your screen by the computer clock)
• Download and run the clear flash tool from : http://www.tomtom.com/updates/clear_flash/clear_flash.exe Make sure your TomTom is connected to the computer and switched on when you do this.
STEP 6. Install a computer voice
• Open TomTom Home
• Click on 'Add maps, traffic and voices -> computer voices
• select the voice of Kate and install it.
The Computer voice is now installed, and your TomTom should now be working.
Dec 06, 2008 | Tomtom GO 910 GPS Receiver
Tom tom go 300 ''unable to store settings'' ''file access error'
You might have the switch on SD card set to "read only" , This would stop your tomtom being able to write to the SD card ... hence , " unable to store settings " message . .... OR ... the folder where your tomtom wants to store the settings is corrupted ( on your SD card ) so it can't store them.... or similarly , the file is corrupted on the SD card ( maybe the card is damaged ) so the existing file cannot be overwritten . Check out all these possibilities before suspecting any hardware fault on your tomtom ..... GOOD LUCK
Nov 24, 2008 | Tomtom GO 300 GPS Receiver
There are no speaking directions on my TomTom GO720 e.g. for 'turn left' or 'take the next exit' or 'continue for 3 miles'. It only beeps for speed cameras etc. We have ticked all the boxes on the sound...
Hi there
As the TomTom is making beeping sounds, its a good indication that its not a hardware fault, it sounds to me its a software issue.
What you could do is try to reinstall the voices on your device. To do this, follow these steps:-
I presume you have TomTom Home installed already, if not you can download it from
STEP 1 Make a Backup
  • Connect your TomTom to the computer and switch it on
  • Open TomTom Home
  • Click on 'backup and restore' and make a backup if you haven't done so already
Once the backup has been made, please do the following:-
STEP 2 Remove the existing voice files
  • Open My Computer, you will see the TomTom as two removable drives, one will be the internal memory and one will be for the SD card slot on the device.
  • Click into the Internal memory drive, you should see a whole load of files and folders.
  • You should see a folder called LoquendoTTS or Loquendo, click into this folder and delete the contents (all the files and folders inside the loquendo folder)
  • Go back to the root directory of the TomTom and delete the folder 'Voices'
STEP 3 Download and Reinstall the voices via TomTom Home
  • Go back to TomTom Home
  • Click on Add Maps, traffic and Voices
  • Select Voices. Loacate the voice of Jane and Tim and add them to your device
  • Go back to the main menu of TomTom Home, click on Add Maps, traffic and Voices -> Computer Voices and install the voice of Kate or Simon (UK English computer voices)
  • Close TomTom Home and also Close it from the system tray. (in the bottom right hand corner of your screen down by the computer clock, you should see a red icon for TomTom Home, Right click on it and choose 'exit')
STEP 4 Install the Clear Flash Tool from TomTom
  • Once Home has closed completely, please download and install the clear flash tool from:- http://www.tomtom.com/updates/clear_flash/clear_flash.exe (Home must be completely closed, otherwise it may not install correctly)
  • Accept the license agreement and keep pressing the Next arrow until the clear flash tool has installed.
  • Your device will start flashing to say there is some activity on your device
  • When your device has finished flashing on the screen (might take a minute), use the 'safely remove hardware' feature of your PC to disconnect the TomTom
  • Switch the TomTom off then take it out of the dock.
STEP 5 Test the voices
  • Switch the TomTom back on, but not connected to the dock
  • Let it load up to the main navigation screen
  • Tap onto the menu and tap onto 'Change Preferences -> Voice Preferences'.
  • Select a non-computer voice i.e. Jane or Tim and press test. You should now hear the voice instruction
  • Try selecting the voice of Kate or Simon i.e. the computer voices, and press test, you should now hear the computer voice.
This should get the voices working again, if not it might be worth giving TomTom Support a call and they can talk you through it.
Hope this works for you
regards
The Warlock
Sep 17, 2008 | GPS
TomTom GO700
Hi there
This happens because files on your card are corrupted after an unsuccessful download.
If you have a card backup at hand, put the card into a computer, format it , and restore backup.
After that the TOMTOM will restart working normally.
If you did not make a copy or backup of the original card, or you cannot reach the computer hosting the last backup.Then follow the procedure below to restore your data :
1. Uninstall the application
2. Reinstall the application
attention_25.gif We highly recommend backing up your device before continuing. questionmark_25.gif
This will preserve any maps and voices you may have purchased.
1. Connect your device to your computer.
2. Go to Computer (Vista), My Computer (XP) or your Desktop (Mac).
3. Double-click the TomTom disk drive to open your TomTom.
4. Make sure that hidden folders and files are shown. To do this:
  • Vista: Go to Organize > Folder and Search Options, click on the View tab and select the option Show hidden files and folders.
  • XP: Tools > Folder Options..., click on the View tab and select the option Show hidden files and folders.
  • Mac: With the exception of some system files, your Mac should already show all hidden files and folders on the TomTom drive.
5. Identify the map folders on the TomTom. These are named for countries or regions such as USA_and_Canada, North_America or any other country or geographical region.
6. Delete all files EXCEPT these map folder(s) and the folder titled ASR, if it exists (the ASR folder will not appear on every device).
7. Properly disconnect the TomTom from the computer and exit TomTom HOME, if it is open.
  • Vista/XP: Right-click the TomTom drive and choose Eject.
  • Mac: Drag the TomTom drive to your Trash.
8. When the TomTom boots you should see a screen with the flashing X.
Proceed to reinstall the application (below):
Sep 09, 2008 | Tomtom GO 700 GPS Receiver
Set up voice John Cleese
You need to put the File / files associated with the voice onto your SD card in the Voices folder.
Use an SD card reader and your PC to look on the TomTom SD card. Find the folder called "VOICES". Copy the John Cleese voice files into the "VOICES" folder.
Once this is done put the SD card back in your TomTom. Switch on. When the TomTom starts up , tap the screen and select "Preferences" , then move through Preferences until you find "Lips" icon and under that it will say " Change Voice" . Tap the Lips Icon , then move right or left until you find the required / John Cleese Voice and select that. Your Tom Tom should now give directions with the John Cleese voice.
Please note: Some voices that you can download free of the internet can contain viruses or if you are unlucky they can contain faulty data which can effect the workings of your TomTom.
As a precaution , before you copy or alter or add anything to your TomTom SD card you should make a Backup of your SD card onto a PC. The if anything gets upset on your SD card you can always format it and restore the origonal data.
Good Luck.
Sep 08, 2008 | Tomtom ONE GPS Receiver
Tomtom keeps rebooting by itself soon after being switched on
Here is a solution that worked in my case (constant reboots after voice select)
  1. Plug your tomtom into your PC.
  2. Run TomTom Home
  3. Select the option to run your TomTom through your PC (TT Home)
  4. You should be greated with the select language screen
  5. Then simply select language etc.
  6. When you get to the voice selection: select a voice (here TTHome should freeze) <- also strangely enough notice the cancel button doesn't on the screen (as it does when doing this on the device)
  7. Don't panic TT Home should start working again in a few seconds
  8. Disconnect your TomTom and that should have solved the problem, the normal map screen should show up upon starting up your TomTom
This solved the issue for me, hope it does for you good luck!
Aug 22, 2008 | Tomtom ONE GPS Receiver
Go 710
Hook the Tomtom using the USB cable to your computer. You should see the Tomtom drive under My Computer as a drive letter.
Backup all data from the Tomtom to a folder on your computer. Now select the Tomtom drive and right click, select properties, select tools, and then Check now. Allow the computer to fix any problems with the Tomtom drive. Once this is completed. Remove the USB cable and do a reset. Now turn on your Tomtom and it should work.
Dec 26, 2007 | Tomtom GO 910 GPS Receiver
GPS Logo
1,673 people viewed this question
Top GPS Experts
Marvin
Marvin
Andrew Taylor
Andrew Taylor
Are you a GPS Expert? Answer questions, earn points and help others
