Question about Canon MultiPASS MP390 All-In-One InkJet Printer
MultiPASS Problem What to do when "Waste Ink nearly full" flashing on Canon MultiPASS MP390?
  • Anonymous May 05, 2008
    I got the cleaning part down pat ... the resetting is another issue! It's still printing fine, although Canon tells me that it will stop any MINUTE!! Yikes. Thanks for any tips that you can offer. AB
WASTE TANK ALMOST FULL ERROR MESSAGE PROBLEM
This is true with many Canon Ink Jet Printers: Eventually, you'll get an error message "Waste Ink Tank Almost Full, Contact Your Canon Repair Center". Canon is totally sly about this, and is actually a pretty ridiculous design flaw that they should be ashamed of- planned obsolescence. Anyway, don't let this problem discourage buying an otherwise fantastic Canon printer. Here's the fix:
The waste ink take is actually just a felt pad that sits under the printer mechanism inside the case and absorbs the ink from your cleanings. From what I gather, its both a time consuming and expensive proposition to take to Canon to fix. And they won't tell people how to do it themselves. Well, I WILL. And this works.
Remember of course, you've got to cycle the cleaning process a huge amount of times to get this to occur.
But when it does, there is a fix-it-yourself solution that is both safe and effective for the printer, and free. You have to be slightly mechanical to do this. If you get this message and you've never used a screwdriver and are all thumbs, well, Canon gotcha. But give it a shot even then, or give it to someone halfway coordinated to do this for you.
1) Figure out how to open the printer by removing the side and inside top plastic panels. Just look at the thing and use your brain. Its all pressure clipped in place, no screws (at least on the S900 and similar models, probably still the same on this years models.) Look for slots and triangles on the 960.
2) No need to remove the ink cartridges in this process- so don't. The mechanism is held down in place in the case by two screws at the very bottom on the outside bottom of the metal chassis inside. Remove these screws then lift up the mechanism. It should lift out fairly easily, but remain attached by wires-- just place it on the top edge of the case.
3) You'll see the blackened (from waste ink) felt pads on the bottom. WEAR GLOVES-- this is skin indelible ink, the only thing that will get it off your hands is CLOROX. Period. There are two skinny pads that sit on top of a larger pad. Note how they fit together.
4) Lift the pads out and rinse out thorough in a sink until very little or no ink comes out. There's no need to use chemical or soap cleaners, just use plain water from the tap and the spray nozzle. Keep rinsing and squeezing the pads, but don't twist them like a towel, squeeze and fold in half however to really get the ink out.
Lay flat in the sun for a few hours to dry. Use a hairdryer to get the last bit of moisture out then replace in the printer, and put everything back together.
5) RESET the printer electronics, so you won't get the stupid "waste ink tank full" message any more. Do an online web search if this doesn't work for your model, although this works (or slight variations0 for many, including the 8200, the S800, and S900 series. Two main buttons on the top of the printer- Power and the Resume:
1) Power off printer
2) Hold RESUME button then press and hold POWER. (The beeper MAY sound once, or may not depending on your model.)
3) Hold POWER and Release RESUME.
4) Press RESUME twice then release both POWER and RESUME buttons.
5) When the indicator lights steady, press RESUME 4 times (for the S900, 3 times for the 8200 apparently).
6) Press power to set data.
7) Print away!
Posted on Apr 21, 2008
How do I reset waste ink tank full on Smartbase mp390?
Issue: Alarm / Power light flashes orange 8 times consecutively (Waste Ink Nearly Full Error)
Solution: Press the <RESUME/CANCEL> button to clear the error (1700)
Waste ink absorber error 1700
The printer has a built-in waste ink absorber to hold the ink used during print head cleaning. Eight flashes indicates that this absorber is nearly full.
Press the <RESUME/CANCEL> button on the printer to clear the error, so you can continue the print job. The printer will need to be serviced as soon as possible.
Jan 05, 2010 | Canon SmartBase MP390 All-In-One InkJet...
I have a Canonmp390 printer & a message keeps
Error "Waste Ink Near Full"
Cause : The waste ink tank (which holds the ink used for print head cleaning) is nearly full.
Action : Contact the Canon Customer Care - Center.
Have a good day.
Dec 03, 2009 | Canon MultiPASS MP390 All-In-One InkJet...
Canon Multipass390 Waste Ink Tank near full
Have a look here
http://resetters.blogspot.com/2009/04/reset-waste-ink-tank-canon-mp390-and.html
Apr 29, 2009 | Canon MultiPASS MP390 All-In-One InkJet...
Waste ink near full error
Canon's a little shady when it comes to this, since any waste ink pad I've seen never has been more than 30-40% full. You can reset that status without cleaning the waste ink out and the printer should return to normal.
1) On the printer, press Additional Functions, Scan, Copy, Scan. This will put you in service mode.
2) Select Test mode at the bottom
3) Select #8 Printer Test, wait for more options. It should say 8-2 or 8-3; push the + or - button until it says 8-3 then hit Select. The menu will now say EEPRON Clear
4) Select Ink count which is option (0) and press set
5) Press Stop/Reset, then the power button and wait for it to restart.
I hope this helps!
Apr 15, 2009 | Canon MultiPASS MP390 All-In-One InkJet...
Waste Ink near full
Manual Reset procedure Waste Ink Tank for Canon MP390:
  1. Start with printer on, press additional functions, Scan, Copy, Scan. Now you should be in service mode.
  2. Select Test mode (must be the last available selection).
  3. Select #8 Printer Test, it will start cleaning then it will come up with some other option: push the + or - button until it says 8-3 then hit the select button
  4. The menu will now say EEPROM Clear
  5. Select Ink count which is option (0) and press set
  6. Press Stop/Reset Followed by the power button and then wait for it to restart.
hope it helps
cheers
Apr 01, 2009 | Canon MultiPASS MP390 All-In-One InkJet...
Printer screen says waste ink near full
hope it helps
cheers
Mar 31, 2009 | Canon MultiPASS MP390 All-In-One InkJet...
Waste ink near full
Basically you open the printer .Remove the ink jets and soak up as much ink for the try as you can.
Mar 10, 2009 | Canon MultiPASS MP390 All-In-One InkJet...
Waste ink near full message
Take paper towels and absorb the excess ink. Make sure that the electricial contact  that tell it is full are clean.
Dec 27, 2008 | Canon MultiPASS MP390 All-In-One InkJet...
Message code on cannon copier
You need to have the waste ink absorbers replaced, the cost of the absorbers should be around $20.00 and service is usually around 50.00. That is a very messy job, you must disassemble printer removed used/ waste ink pads in the bottom of machine reset ink counters and the reassemble printer.
Oct 24, 2008 | Canon MultiPASS MP390 All-In-One InkJet...
Canon MP390 Waste Ink Near Full message
Sep 11, 2008 | Canon MultiPASS MP390 All-In-One InkJet...
Canon MultiPASS MP390 All-In-One InkJet Printer Logo
147 people viewed this question
old marine
old marine
