Purchased a mirco sd card and its write protected. How do I remove it?
  • 37 Answers
There may be a switch on the side of the SD card. You need to move that to the other position. Also, some SD cards come with software on them that allow you to write-protect them. If so, you need to disable this as well.
Posted on Apr 05, 2008
Will sandisk mirco sd cards work?
You didn't buy a microSD card at all, you bought a microSDXC card.
The Eclipse 180 works with microSD cards (2GB or smaller) and microSDHC cards (32GB or smaller). It does not work with microSDXC cards.
Jul 26, 2014 | Mach Speed Eclipse 180 MP3 Player
Mirco SD card shows free space 0 bytes and used space 0 bytes
Click on the drive and then in windows select tools then folder options, then view and select or unselect hidden files or folders, plus hide protected files.
This should show all files on the card.
The only other thing I can think of is that the camera uses a different format to Windows. So it can't read the card.
Jun 07, 2017 | SanDisk Electronics - Others
How can i remove write protection from a SD card that I just purchased?
SD and SDHC cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Aug 06, 2012 | SanDisk 16gb Sdhc Sd HC Flash Memory Card...
I PURCHASED A KINGSTON MMC MOBILE SD CARD, AND INSERTED INTO THE SLOT OF MY PHONE AND WAS NOT ABLE STORED ANY DATA ON IT, SUGGESTING THAT MAY BE THERE IS A LITTLE PROBLEM WITH MY PHONE, SO I DECIDED TO...
SD cards allow you to store digital information; you can use SD cards with most electronic devices like digital cameras and computers.
An SD card will become write protected if the switch on the card is placed on the "Lock" position. This prevents any information on the card from being altered or deleted.
If you wish to add, delete or change any of the information, you must remove the write protection.
Remove the SD card from the computer or digital device.
Locate a switch on the bottom or side of the SD card.
Move the switch to the "Unlocked" position to remove the write protection.
If you do not have a switch, you will need to remove the write protection with your computer.
Insert the SD card into your computer's card reader or back into the digital device.
You can now save and change information on the card.
Apr 07, 2011 | Kingston 1 GB microSD Card with USB 20...
I added a 2gb mirco SD card to my Sansa e270 6.0gb player, but the memory is still only showing 10mb of the original 6.0 gb available for use. How do I get the Sansa to recognize and use the 2 gb mirco SD...
Hi,when you purchase a new micro SD card before use, youwill need to format the memory card so that you will be able to know the actual size of the Micro SD card by checking the details after formatting it.
After formatting the micro SD card and checking the details, if you still do not see the accurate size which is about 1.88mb or the about, that means the micro SD card you bought needs to be replaced. Not a good one.
Have a nice day.
Feb 18, 2011 | SanDisk Sansa e270 MP3 Player
Pls sir i lock my memory card with password, unfortunately i forget it pls help me out because i have an important things inside
Hi if u have a password on the mirco sd card on your phone the password is only only on the phone not the sd, so you can take the card out of the phone. and put it into a mirco SD card to usb adapter
http://cgi.ebay.com/Micro-SD-TF-M2-USB-adapter-card-reader-up-16gb-/220718102304?pt=PCC_Drives_Storage_Internal&hash=item3363d2f720
put it into your usb on ur pc and take all the files you want off. then you can do a master reset on your phone to reset all the setting on you phone and then u can put the sd card back into ur phone
Jan 15, 2011 | Nokia 5130 Cellular Phone
Why cant i put music on my lg env3 from my mirco sd card?
You can, just hook your phone up to your computer vie USB cord. When hooked in, open phone go to 9. Settings & Tools then 2. Tools then 9. USB Mass Storagethis will connect the mirco sd card. PC under My Computer>removable drive open you should have folders listed go to My_Music, drag your mp3's to that folder. If using a Mac it needs to be a new Mac to recognize the mirco sd card, do the same steps as above and the mirco sd card will show up on the desktop as a drive.
jh3:16
Jan 20, 2010 | LG enV3 VX9200 Cell Phone
How to download photos from my LG phone to my
You can, just hook your phone up to your computer vie USB cord. When hooked in, open phone go to 9. Settings & Tools then 2. Tools then 9. USB Mass Storage this will connect the mirco sd card. PC under My Computer>removable drive open you should have folders listed go to My_Pix, drag your .jps from/to that folder. If using a Mac it needs to be a new Mac to recognize the mirco sd card, do the same steps as above and the mirco sd card will show up on the desktop as a drive.
jh3:16
Oct 19, 2009 | LG enV3 VX9200 Cell Phone
It won't recognize the sd card adapter for mirco
THERE is a tweak with the cards you insert on your picture mate, to be honest these things dont recognize memory cards that are above 2 gig. they also dont recognize some brands. the most compatible as per experience is sandisk
Jun 23, 2009 | Epson PictureMate 500 InkJet Photo Printer
Micro sd **** write protected
The adapter that you put the MSD card into should have a little slide on the side of the adapter that says lock or protect. Just slide that piece and that should solve your problem.
Mar 08, 2009 | LG enV VX9900 Cellular Phone
61 people viewed this question
 Grubhead
Grubhead
