Question about Mitsubishi VS-5059 50" Rear Projection Television
No picture, no pwr at color guns, no sound, pwr light on
Set was working fine. Turned on in AM and got no picture/no sound although power led is on. Opened the back and am getting no light from any o f the color guns. Set went from working 100% to nothing . . any ideas of where to start?
  • Mitsubishi Master
  • 8,617 Answers
Push in the menu and input buttons on the set and hold them in for 8 seconds together and see if the led blinks a two digit code, then let me know what happens.
Posted on Apr 05, 2008
SOURCE:
Green LED always on, power switch has no effect
if using a box or receiver in line with the set unplug those as well. I assume the red light on the set is not coming on or a light is blinking?
Dec 18, 2012 | Sony Grand WEGA KDF-50WE655 50" Rear...
Set worked fine when turned off. Now nothing happens when pwr button is pressed. Timer light does not come on. If system reset button is pressed, pwr led flashes for 60 secs. System is still dead. Status...
If your tv is around 2-4 yrs or used 6000-8000 hrs,never replaced the lamp before it could be time to replace it.If you hear strange noises like buzzing or humming noises it could be the color wheel which is a little disc that has a gamma of colors and spins at high rpms.When the light of the lamp goes through it creates the colors on your tv.The other most common failure is the board that powers the lamp,which is called the ballast.When its bad it will make a clicking sound or like wanting to turn on. For parts you can find them in partstore.com shopjimmy.com or discount-merchant.com God bless.
Feb 09, 2010 | Mitsubishi WD-65732 65" Projection HDTV
Need to re-attach power button cable, hard drive
The manual for your computer is available from emachines, p.168 shows the info you need (replacing the front I/O panel)
http://downloads.emachines.com/userguides/8511279_eM_NG3_chassis_HW_ref_en.pdf
The good news is that you can't harm the computer by connecting the wires wrong and the bad news is they just won't work the way they are supposed too if not connected properly. The LED's must have the correct polarity to work.
In general, if you look real close (as in magnifying glass and flash light) you will see the ID for each set of pins is printed on the motherboard (pwr,rst,HDD,pwr sw,speaker) Just match what it says on the motherboard to what it says on the wires. Don't worry if you get the polarity wrong. If a light doesn't work just swap the two wires. The colored wires should be positve (+), though. The reset (rst) and power switch (pwr sw) wires don't require polarity.
These instructions are for most computers in general, YMMV.
Nov 30, 2009 | E-Machines eMachines Desktop PC
My 61 inch RCA Scenium, currently has sound but no picture appear
My exact same problem turned out to be the cable box not the TV. Try unplugging cable box for 5 minutes then power up! Solved my problem!
Apr 01, 2009 | RCA Scenium HDLP61W151 61 in. HD-Ready...
17 yr. old 35" RCA loses color intermittently. Picture & sound ok
Three guns Red Blue and Green in the picture tube of an old CRT set. If one of the guns goes out it effects that color. Sounds like one of the guns inside of the tube is going out, To costly to replace for such an old antilog set that will have to have a convertor box next month anyway.
Jan 12, 2009 | RCA 15L500TD 15 in. TV/DVD Combo
OK that means the set isnt going into shutdown for protection. So your problem has to be in the stanby voltages that supply the operating voltages or in the operating circuits themselves. It will need to be diagnosed by the service manual. Do you feel comfortable doing the diagnosis with tech support? If so I will post a link where you can get buy the service manual they email it and they provide free tech support with the service manual purchase. Let me know if you would like the link.
Apr 05, 2008 | Mitsubishi VS-5059 50" Rear Projection...
New installation of mother board
Hi check the cables from the case to the mother board. They should be marked and the book that came with the board will tell you where to connect them. The std markings are HDD [red led] PWR S [powerswitch] RSW [reset switch] PWR LED [case power light] To test if there is no fault in the board or power pack. first visualy check the board to see if you have a red led light on when the power is turned on, if not the problem is in the power pack or the wall outlet. second if the light is on, the bridge the pins marked pwr switch on the board with a screw driver and this should start the computer, if not you have a faulty board. Regards mistyman
Oct 05, 2007 | Select Brands System on board CPU / VIDEO/...
No sound no picture
Does any lights come on led on front of set? Does set make any squealing sound when you press power? If not then open and look at power supply board. This is the board that the cord is attached too. look for open fuse, check 2004, 1000, 1300, 1900, etc. See if fuse blown then look for short in pwr. supply.
Aug 29, 2007 | Philips 60PP9202 60" Rear Projection...
Televison & Video Logo
115 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
