Question about Xerox DocuColor 3535 Copier
Error code 009-349
Funzioni di stampa disabilitate
  • publidea Apr 07, 2008
    Non riesco ad aprire le immagini initial actions and procedure
    President:
  • 2,072 Answers
The 1st BTR did not reach the retract position.
Error code 009-349 - arrwup.gifInitial Action
  • Clean the 1st BTR Retract Sensor ( PL 5.4) and check for damage.
  • Check the 1st BTR Worm Gear and Retract Shaft ( PL 5.4) for breakage.
arrwup.gifProcedure
Posted on Apr 05, 2008
  • Rick Kasper Apr 05, 2008
    In sequence, enter the following: dC330 [009-054] then dC330 [009-055].
    The 1st BTR contacts and retracts.
    Yes No Unanswered
    There is +24VDC from P/J533-A16 on the I/F PWB to GND ( Figure 2).
    Yes No Unanswered
    Go to the +24 VDC Wirenets ( Figure 2) and troubleshoot the problem.
    Check the wires between P/J533 and P/J237 ( Figure 2) on the 1st BTR Retract Motor for opens, shorts, or loose connections. If the wires are OK, replace the 1st BTR Retract Motor ( PL 5.4). If the problem continues, replace the MCU PWB ( PL 13.1). If the problem continues, replace the I/F PWB ( PL 9.1).
    Stack dC330 input codes [004--014] (1st BTR Retract Sensor Power) and [009-203] (1st BTR Retract Sensor). Then, in sequence, enter the following: dC330 [009-054] then dC330 [009-055].
    The 1st BTR Retract Sensor changes state.
    Yes No Unanswered
    Go to Figure 1.Check the circuit of the 1st BTR Retract Sensor ( PL 5.4).
Where is the reset button on the ricoh 1600?
Buondi' la macchina non riconosce il formato a4 in fase di stampa
mi dice sempre di mettere la carta nel by pass cosa posso fare?
grazie
May 14, 2014 | Ricoh Aficio MP 1600 Black and White...
Errore scs545
Sulle stampanti lei tiene giu le SU e frecce in giu per almeno cinque secondi, la liberazione e la stampa ENTRANO rapidamente. Usare le frecce per scegliere #2 SP di Motore ed ENTRANO. Le frecce di nuovo di scegliere #5 Modi ed ENTRANO. Le frecce di nuovo finche #810 Ripristino di SC ed ENTRA. Controllare la mostra, lei fara probabile deve colpire ENTRA di nuovo per eseguire il ripristino. Dovrebbe indicare il ripristino e completo. Spegnere e SU. Se ci sono delle questioni no ulteriori dovrebbe essere funzionale di nuovo. C e un secondo metodo per entrare il modo di SP ma mi elude attualmente.
Aug 04, 2011 | Ricoh Aficio SP C410DN Laser Printer
2003 Honda VT 750 DC Black Widow pressione gomme
Ciao, Vincenzotolo per questo scenario avrai bisogno del tuo manuale di servizio, della scheda di ricambio e del manuale del proprietario se non riesci a trovare lo strumento migliore che hai mai acquistato per la tua Honda, non disperare, per un semplice zero $ puoi scaricarne un altro. Per ulteriori informazioni sul tuo problema e sui preziosi download GRATUITI necessari per la visualizzazione o la stampa, fai clic sui link blu di seguito. Buona fortuna e buona giornata. Maintenance Specs
tire pressure
Honda 1998 VT750C Service Manual
https://www.partsfish.com/page/oem-parts-for-honda
Honda VT750C Owner Manual
May 24, 2011 | 2003 Honda VT 750 DC Black Widow
2003 Honda Silverwing 600 manuale di manutenzione gratuito
Ciao, Brambillaott la maggior parte del servizio, parti fiche e manuali proprietari su internet sono "GRATUITI" per il download e tutti i manuali di servizio contengono schemi elettrici nelle pagine posteriori. Il resto di solito paga una modica cifra di $ 15 e c'? una manciata di modelli oscuri, rari, obsoleti e molto vecchi che non sono pi? o non sono mai stati disponibili e alcuni non sono mai stati stampati in inglese. I mercati indiano e filippino sono di solito solo in formato E-book, per queste rare occasioni guarder? su eBay e trovo il pi? economico disponibile. La maggior parte dei manuali coprir? la tua marca, modello e anno, altrimenti verr? fornito uno che si avvicina il pi? possibile alla tua bicicletta e avr? la maggior parte delle informazioni che avrebbe un manuale esatto. Se non c'? nessun segno $ dopo il collegamento manuale ? scaricabile gratuitamente. Per scaricare il manuale per la visualizzazione o la stampa, fare clic sui collegamenti blu in basso. Buona fortuna e buona giornata Honda FJS600 Silver Wing Owner Manual
Honda 2002 2003 2004 2005 2006 Silverwing service manual Download Manuals... $27
2003 Honda Silverwing 600 Motorcycle Specs
Honda Silver Wing scooter
Feb 09, 2011 | 2003 Honda Silverwing 600
Un amico possiede una Minolta AF Big Finder Date. Come può fare per ottenere la data sulla stampa delle foto? Grazie Francesco Galasso
Premi il tasto mode , premilo varie volte per scorrere i vari tipi di data e scatta la foto, secondo manuale la data dovrebbe essere stampata automaticamente nella foto quando vedi la data nell'immagine inquadrata nel mirino. Magari sacrifica un rullino per fare delle prove prima.
Ciao.
Oct 04, 2010 | Minolta AF Big Finder 35mm Point and Shoot...
Cambio olio motore e anche quello di trasmissione
Ciao, Andux_t per questo scenario avrai bisogno del tuo servizio, dei tuoi pezzi di ricambio e dei manuali dei proprietari se non riesci a trovare il migliore strumento che hai mai comprato per la tua Honda, non disperate, per un minimo di $ 15 puoi scaricare un altro. Per ulteriori informazioni sul tuo problema e sui preziosi download "GRATIS" necessari per la visualizzazione o la stampa, clicca sui link blu qui sotto. Buona fortuna e avere una giornata meravigliosa. How to Change Transmission oil on Crf150r
Honda CRF150F Oil Change
CRF150F service manual repair 2003 2013 CRF150 Download Manuals Technical $15
Honda 2004 CRF150F Owner Manual
Aug 07, 2010 | 2005 Honda CRF 150 F
Kodak easyshare5300
salve,
è sicura di aver rimosso la pellicola protettiva dalla cartuccia?
altrimenti potrebbe essere la cartuccia difettosa.provi a richiedere una sostituzione.
Spero di esserle stato d'aiuto
Riccardo
Jul 08, 2008 | Kodak EASYSHARE 5500 All-In-One InkJet...
Not Printing.....
Dovrebbero essere le testine di stampa intasate dall'inchiostro essiccato (succede soprattutto con cartucce non originali). Prova a smontare le testine, e tenerle a bagno per una nottata in un solvente specifico (io ho usato del semplice acetone ed ha funzionato). Quindi imbevi nell'acetone un capello (non è molto elegante, ma funziona) e cerca piano piano di inserirlo nei micro fori presenti sulle punte che forano le cartucce di stampa fino a che non risulteranno pulite. Quindi rimonta il tutto ed in bocca al lupo.
Max
Dec 19, 2007 | Epson Stylus CX3200 All-In-One InkJet...
1,164 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
