Question about iLO (2 GB) MP3 Player
LO MP3 Player Problem
My fm works. but when i load a new book on it played the first chapter and now it will not play - go forward/backward etc. have deleted book and installed again. have tried different book etc. i some times have to take battery out to turn off.
  • 8,596 Answers
Make sure the audiobook is in the correct format, and that it has transfer rights.
This is the worst mp3 player ever invented - i have to tell you this up front. There is no driver, the company does not support the product anymore - I would return it now while you still can.
Either the device is bad, the pc port is bad, or the software is faulty. Try connecting to different usb port, then a usb port on a different pc with a compatible os. If still not recognized, then there is physical damage to player.
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
Posted on Jul 05, 2008
How do I get my audible books on my sandisk clip sport mp3 player to play in the right order
it could be a filename issue. You could number your tracks in a mp3 tag editor. I suggest mp3tag v.2.5.x for your needs.
Sep 20, 2014 | SanDisk Sansa Clip MP3 Player
I cannot get my Sansa Clip MP3 Player to play recorded books. I downloaded the book chapter by chapter and I can see them when I use the computer to explore the player. I cannot get the player give me...
Audio books should be listed within the Music folder on your clip.. just scroll until you see it.
You may have to manually put the audio book into that folder via My computer beforehand.
WIndows media player does not recognize the audio book subfolder and will mix your audio books into the album mix.. but just ignore this
Jan 04, 2011 | SanDisk Sansa Clip MP3 Player
Sanza. Audio book chapters load in crazy order
hi katie.
before you load your audio books onto you device try renaming each chapter to get them in order. your device should order them like your hard drive will
May 22, 2009 | i-Bulldog IMP-90 MP3 Player
I have a Philips GOgear SA5285 and I can load the audible audiobooks and they go to the audiobook file but when I load my library books from Netlibrary.com they load as songs and do not have book marks, so...
If you are a newbie, and you primarily want the mp3 player for audiobooks, then go ahead and take this player back to the store - I'll tell you why:
The deal between Audible and Philips fell through before the latest series of GoGear's was released. Therefore, even though the player has an Audible folder, it will not properly play Audible audiobook files. Sad, but true.
Your post reminds me that I need to write a Consumer Watch article on mp3 players that claim to play audiobooks - 90% of them will not easily allow you to play audiobooks - you will have to jump through hoops.
If you still want to try, here is what you want to do:
1. Delete any audiobooks off the GoGear, but make sure that you have a copy of the audibooks on your computer itself.
2. Open Windows Media Player. Find your audiobook files in your library. If they don't show up, then you will have to move your mouse over the Library tab - a small black arrow should appear underneath the word "Library" - click the black arrow and select "Add to Library". Click "Add" and find the folder in which your Audible files are stored. It may take several minutes, but Windows Media Player will add these files to Windows Media Player.
3. Right-click an Audiobook file starting with Chapter 1 of whatever book, and select "Advanced Tag Editor". One-by-one, manually assign an a track number to each audiobook chapter - Track 1 for Chapter 1, Track 2 for Chpater 2, etc.
4. Now, re-add the audiobook files to your GoGear.
5. You might additionally have to go into the Settings menu of your GoGear, and turn Shuffle mode off - your user's manual can show you how to do this.
Sound like a lot of work? You betcherbottom dollar it's a lot of work. This particular mp3 player is not the best for audiobooks.
-Tha Mp3 Doctor
Mar 11, 2009 | Philips GoGear SA5285/37 Digital Media...
Tracks played in wrong order
The Sony NWZ-S616F (4 GB) sometimes plays the musical tracks out of sequence. To check if the tracks are being played correctly, press the down arrow key ↓ at any time until the name of the book or music is selected. Then press the ► button and the tracks will show up. If they are in wrong order, select track 1 and press ►.
Feb 19, 2009 | Sony Walkman NWZ-S616F MP3 Player
Sansa m250 doesn't continue playing from the same spot after power up
This player will only recognize Audible audiobook files
There is not a fix for the pause/resume issue - it is a major problem for just about every mp3 player that claims audiobook compatibility
Here are some help files:
Audible
1) Adding audible books to your MP3 player using Audible Manager (Windows XP)
Windows - http://mp3support.sandisk.com/audible/xp-audible-add-book.wmv
2) Adding books from an online library to your computer using Audible Manager (Windows XP)
Windows - http://mp3support.sandisk.com/audible/xp-audible-add-books-from-online-library.wmv
3) Adding your MP3 player as a mobile device in Audible Manager (Windows XP)
Windows - http://mp3support.sandisk.com/audible/xp-audible-add-mobile-device.wmv
4) Deleting an audible book in your MP3 player using Audible Manager (Windows XP)
Windows - http://mp3support.sandisk.com/audible/xp-audible-delete-book.wmv
5) Deleting a book from your library using Audible Manager (Windows XP)
Windows - http://mp3support.sandisk.com/audible/xp-audible-delete-book-library.wmv
6) Purchasing an audible book from Audible.com (Windows XP)
Windows - http://mp3support.sandisk.com/audible/xp-audible-purchase-book.wmv
May 13, 2008 | SanDisk Sansa m250 MP3 Player
Playing audiobooks -
Go to the first chapter and play all. For some reason if you go to the author and play all it will mix the order. Hope this helps
Mar 25, 2008 | SanDisk Sansa m240 MP3 Player
Play shuffling when shuffle is off
Hi, that player plays the files in the order they are copied in windows, to avoid random playing, copy the files one by one.
Feb 06, 2008 | RCA TH1101 MP3 Player
Book chapters do not play in correct order
I have this same problem its irritating
Dec 28, 2007 | RCA TH1101 MP3 Player
iLO (2 GB) MP3 Player Logo
Top iLO Audio Players & Recorders Experts
Mohamed Ismail
Mohamed Ismail
Michael Vincent Cruz
Are you an iLO Audio Player and Recorder Expert? Answer questions, earn points and help others
