Purchased a venturer tc to
Purchased a venturer tv to use now for analog stations and for digital stations but what and where do i buy the antenna that needs to be connected to the tv as indicated in the manual?
  • elaine1 Apr 06, 2008
    does not indicate a name, just says to connect an indoor antenna to view television channels correctly
    it says the tuner in this tv receives tv signals from an antenna. the digital tv can receive standard (sdtv) and high definition (hdtv) over the air broadcasts.
    next it reads the tuner in the tv receives NTST tv signals, analog cable signals or the rf output from satellite receiver, vcr or cable box.
    I am in Houston Texas
    Genius:
  • 3,422 Answers
The first thing i'll say is to clear all your doubts go HERE and HERE
I will post you the details for buying an antenna shortly.
Goodluck..
Posted on Apr 06, 2008
  • Priya darshan Apr 06, 2008
    I also want you to check THIS LINK out.It has very usefull info.
    I believe THIS LINK will solve your problem.You will know which one to buy.
  • Televison & ... Master
  • 19,396 Answers
Which is the name for the antenna in the manual?
  • 1 more comment
  • Ginko
    Ginko Apr 06, 2008
    Additionally I will need your location, to find a retailer distributing in your area
  • Ginko
    Ginko Apr 06, 2008
    This one should work on your system.
    Here is a different option.
    Here is a retailer in UK
    Both antenna work on digital tv, they should be ok on your portable system.
  • Ginko
    Ginko Apr 06, 2008
    Any indoor antenna (aerial ) should do, you will have a better signal with a digital amplified antenna, similar to the ones a posted above.
    Here is a list of indoor antennas, best ones are the digital models at the end of the list.
    If you tell me in which country you do live I can find models and distributor in your area.
    Regards
SOURCE:
What kind of tv antenna do I need for local stations?
plase tapon the crosslines firmly the crosslines will continue to move until the screen is aligned
Apr 22, 2018 | Televison & Video
The analog tv picks up a lot more stations and correct channels than the LED TV. Is it possible to set the Insignia LED NS-19E320A13 to analog? Is there a device available?
.YES IF ITS A DIGITAL TV U WILL GO TO MENU GO TO ANTENNA CHANGE FROM DIGITAL TO ANALOG OR AUTO ENTER THEN SEARCH ANOTHER WAY GET AN ANALOG TO DIGITAL SET TOP BOX FIX YA ANTENNA TO IT CONNECT TO TV BY HDMI.OR AV CABLES GET THE SET TOP. ON GO TO SCAN OR SEARCH AND YOU WILL HAVE ANALOG CHANNELS ON YOUR LED TV
Oct 08, 2015 | Insignia Televison & Video
My out door TV antenna stopped receiving 1 of 8 channels, this station is 20 miles away, the station said they weren't having any problems transmitting, do I need to replace the ohms device?
Is the antenna digital? If not its analog. Most stations are going to digital HD and dropping analog. The other 7 are still broadcasting analog. Ask station if they are still broadcasting analog if antenna is digital. If no, do a rescan of stations in menu of tv. Let me know.
Feb 19, 2013 | Electronics - Others
Does this product have a built in digital to analog converter?
This tv incorperates a full digital PLL tuner. It does not need a digital to analog coverter since analog signals is no longer used. All tv stations now broadcast with digital signal. It will receive local broadcast stations just connect a goood quality antenna to the tv. You will need to do a scan and the tv will store all of your local broadcasting stations within range. An outdoor antenna works best for digital signals.
Sep 13, 2012 | Samsung LN32B460 32 in. LCD HDTV
I'm wanting to drop my satellite service. Will my projection tv pick up stations with a digital antenna?
Sorry but I've never heard of a DIGITAL ANTENNA, ALL antennas are ANALOG NOT DIGITAL, and yes you will be able to tune in some TV stations if you live close enough of TV stations that still transmit ANALOG signals, with a GOOD VHF/UHF antenna you can have good reception and viable TV time... (best of all it's FREE)
Good Luck!
Mar 25, 2011 | RCA R52WM24 52" HDTV Projection Television
I'm wanting to know if this TV is one that is Digital or analog? Will I need to buy a converter box for it if it isn't hooked up to cable or direct TV? I believe it was purchased in 2006.
No.It is a digital tv.Just require a good digital antenna for a better and a longer ranges for the tvs broadcasting stations incommming signals.After a digital antenna is hook up.When u go in to the tv menu go to Setup.go down to CH. pick AIR and enter and tv should be automatically be scanning for DTV free air broadcasting tvs stations.
Dec 05, 2010 | Sanyo CLT1554 15 in. EDTV-Ready LCD...
New TV doesn't register being HD ready during test TV stations do
Try going into the setup menu and make sure it is set to antenna then do a channel program. You don't need to wait for a test there are plenty of channels already there. Both digital and analog channels are still available so you will still a message that you are not receiving digital if you are putting it on an analog channel. The channel number has to have a dot(.) in it like 8.1, 24.1 If there is no dot you are on an analog channel
Mar 13, 2009 | Westinghouse Electric W1603 15.6 in. LCD...
Can't get all digital channels
There are several possibilities assuming you have an outdoor antenna with the amplification. You are too far from the transmitter or the station is still on a low power digital transmitter until the analog broadcasts end. Additionally, there may be buildings, hills or trees in the way. The first one is called the digital cliff - you either have enough signal for your tuner or you don't. Some stations may need to add transmitters to cover the secondary areas that could still receive the analog signal. The second possibility will either resolve on Feb 18 or June 12 or anywhere in between. (It will depend on your station and the Digital TV transistion delay bill. Some stations are changing frequencies with the transistion and can't go to full power until another analog station moves its frequency.) The last one can't be resolved.
If you have an indoor antenna, you can try moving it around to get better results. My household has an amplified outdoor antenna with a rotator to get the antenna to line up with the signal. We have two analog stations that give problems when we look for their digital signals. We hope the issue will resolve with the changeover since we have seen the signals on both stations improve when they wanted to broadcast football games.
Feb 07, 2009 | Initial HDTV-320 32 in. LCD TV
Televison & Video Logo
71 people viewed this question
Top Televison & Video Experts
Ekse
