Question about Logitech Quickcam Chat Webcam
Video sound problem
When I answer a video call the other person can see and hear me no problem, I can see them but I can't hear them, all I get is a load of noisy squealing and when I turn down the sound at my end, they can still hear me fine but without the noise, and when I speak I hear an echo back, any ideas?
  • poonlyn Mar 07, 2009
    I just download window life 7.5 version. I cannot hear or speak to the other party on line. But we can see each other very clearly. As for trying to drag the icon on the volume also does not work. I cannot drag the volume control at all. Before downloading this version I can chat without any problem at all. Please help me. Thank you.
  • 818 Answers
Durring video conferencing with MSN Messenger, I can't hear my friend and he can't hear me. Or I can hear them but they can't hear me. What's wrong? video sound problem - trnsp.gif Answer This article applies to the following products:
All Logitech Web Cameras with MSN Messenger Support
This article applies to the following software:
Windows XP
Test the Microphone in Sound Recorder
  1. Click "Start," > "Programs" ("All Programs" for Windows XP) > "Accessories" > "Entertainment" > "Sound Recorder."
  2. Click the Record button and speak into the microphone of the camera. You should see the green line move, indicating the application is picking up sound.
  3. Click the Stop button.
  4. Click the Play button. If there is no sound at playback, check to make sure the correct device is selected.
    1. Click "Edit," then "Audio Properties."
    2. Make sure Logitech is listed as the Preferred device for "Sound recording."
If the microphone does not work in Sound Recorder, click here for help in determining the problem with the mic.
While using MSN Messenger it is the messenger program, not the camera software, that negotiates the audio streams between two MSN Messenger Clients. Although we cannot directly support audio issues in MSN Messenger, the following steps have been known to resolve and improve audio issues in MSN Messenger. For further information, please consult the help documents associated with MSN Messenger.
Test Your Networking Router
You can also test to see if your router is causing audio issues by either physically bypassing your router and connecting directly to your cable/DSL modem or by setting up your computer as the DMZ (de-militarized zone). If you are a novice networking user, it is not recommended that you leave your computer in the DMZ state for extended period as that may leave your computer vulnerable to attack. However, you may briefly configure your computer as the DMZ to determine if your network settings are causing the audio issues. For DMZ setup instructions, please consult your router's documentation.
Enable Universal Plug and Play (UPnP) on both Windows XP and Your Router.
If either of the above steps resolves the no audio problem, try the following steps.
  1. Open Add or Remove Programs in Control Panel. To open Add or Remove Programs, click Start, point to Settings, click Control Panel, and then double-click Add or Remove Programs.
  2. Click Add/Remove Windows Components.
  3. In the Components list, select the Networking Services check box, and then click Details.
  4. Make sure the Universal Plug and Play box is checked.
Notes: If you used a CD to set up Windows, you will be prompted to insert it into your computer.
If your router does not support UPnP or you still get no audio after enabling UPnP on both Windows XP and your router, you must manually open all UDP ports between 5004 and 65535. This is because the audio streams are sent dynamically using that range of ports. Without a dynamic way to open those ports like UPnP, there is no way for MSN Messenger to successfully negotiate the audio stream. Consult your router's documentation for instructions to manually open these required ports.
If you are still experiencing audio issues within MSN Messenger, and you have verified that the microphone is working in Sound Recorder, contact MSN Messenger Support.
This article covers Accoustic Echo Canncellation (AEC) and how it works.
QuickCam 10.x and RightSound supported cameras
QuickCam 11.x and RightSound supported cameras
Call Central and RightSound support audio devices
This article applies to the following platforms:
Windows® 2000 Professional
Windows® XP Professional
Windows® XP Home
Windows® Media Center Home
Windows® Vista
Accoustic EchoCancellation (AEC)'s purpose is to prevent sounds from your computer's speakers to be picked up by your microphone. This can be a significant problem with audio or video calling applications where the voices or sounds from other parties of the call is being inadvertently picked up by the microphone and fed back into the call, creating echo and other sound distortions. Without AEC, this echo can detract from the quality of a call and in extreme situations, the echo can degrade the audio experience to the point where the audio is useless.
To prevent this from happening, the AEC component monitors sounds being played by your computer's speakers while monitoring the incoming sound picked up by your computer's microphone. The AEC module takes the outgoing and incoming sound signals and compares them to determine if echo is present. If echo is found, it is subtracted before the audio from the microphone is sent to the requesting application. This will result in the remote party only hearing you speak, without being distracted by hearing their own voice echo back to them.
When enabled, echo is eliminated for the recipient of the audio/video message. For echo free chatting, both parties need to have a RightSound technology enabled web camera that supports the AEC feature.
Posted on Apr 05, 2008
Skype can t connect?
At any issues any time you contact our technicians to sort problems via remotely and convenience to use. Just dial our Skype tech support number +1-855-676-2448 to acquire the immediate response to your call to remove risks. Skype Technical Support Number 1 855 676 2448
Feb 08, 2018 | SKYPE Computers & Internet
Using medion md 96340 with built-in realtek hd audio sound card. in skype video calls the caller can hear very well but called person does not hear at all. skype echo test says-cannot find sound...
Analysis- The call can gear very well - indicates that the speakers / head phones are working fine and the audio drivers are working well
The called person doesnt hear any thing - it indicates that the caller is not able to transmit sound. This can be a microphone related issue. It can also be skype settings issue.
Please answer following questions to analyze the issue better
1. has this ever worked before?
2. Have you tried using the microphone for some other application like recording some audio?
3. Have you tried audio / video calls using some other chat program like gtalk?
4. Are u using any external microphone attached to a head set or is it the laptops inbuilt microphone?
Aug 18, 2011 | Medion MD 96340 Laptop
I am using google video chat and the other person can see and hear me but i cant see them. i can hear them though.
CONTACT WITH THIS PERSON ON PHONE: +919855261366, +919256023943.
Mar 20, 2011 | HP Pavilion dv6000z Notebook
When I answer a call, I cannot hear my caller as they speak.
the problem is seems to be with the earpiece. the connection to the ear piece may be please give for service in near by sony service centre.
Jul 14, 2010 | Sony Ericsson Cyber-shot C905 Cell Phone
I can make and receive calls, but I cannot hear anything.
Check Windows Sound mixer for application volume. Down in system tray at right side of taskbar double click sound icon for XP or click sound icon once and click Mixer for Vista. Look through volume settings for your phone application. Make sure it is not muted and volume is up.
Aug 21, 2009 | Google Android
They can't hear me?
Check you microphone settings in you audio mixer and make sure it is enabled for the web camera and not your sound card.
Aug 08, 2008 | Logitech QuickCam Communicate STX Personal...
i can see them but cant hear them
Jun 06, 2007 | Logitech QuickCam Communicate STX Personal...
Logitech Quickcam Chat Webcam Logo
448 people viewed this question
Top Logitech Computers & Internet Experts
micky dee
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
