Question about Kenmore 83142 Electric Dryer
Dryer is shooting sparks and making a scraping sound
I figure I can start by cleaning out the dryer and see if something is stuck in the back becasue it's making a scraping sound when I turn the drum manually. that might be causing the white sparks, too.
The heating element comes on when the door is open, that has been distressing my dog! I heard the sound from the dryer and my dog started shaking!
So of course, I turned the dial to off - and haven't used the dryer.
I am trying to figure out how to fix it, but can't get the back off to see what might be scraping inside, and to clean out the lint...
Can you help me?
  • edavydenko Apr 08, 2009
    I got exact same problem and do not know what to do :(
Hoover washer drier is making a scraping noise and a spark from the bottom of the machine everytime the drum spins, does anyone know what this cold be. thanks.
Posted on Jan 09, 2010
Frigidaire Laundry Center GLEH1642FS1. 4 years old. The dryer was making an awful sound, sounded like something was stuck behind it while it was running making a scraping sound. Today in the middle of a...
there is a bearing at the back of the drum that gets dry and sometimes the ball part wears down causing the noise you are hearing i would check that first
Jan 25, 2018 | Frigidaire Washing Machines
My whirlpool thin twin ltg6234dq0 dryer does not start it makes a motor hum then shuts down. I opened it up and cleaned it out it was full of lint. I then sprayed some lubricant all around it and it...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Jul 19, 2011 | Whirlpool LER4634J Electric Dryer
Maytag performa electric dyer makes dragging noise drum turns but acts like something catches and makes a dragging or scraping sound
assuming nothing is stuck around drum pull off the front and check the fan. If it is noisy for a few seconds after you stop the dryer then the fan may be stripped on motor shaft. while off you can check the front glides and the rear rollers
Nov 17, 2010 | Maytag Neptune MDE4000 Electric Dryer
Suddenly without notice, the dryer makes a very loud sound when i turn the start dial but when i release it, the noise stops, but the dryer won't run. It's like it's stuck on something? Tried different...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
The motor is fried...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
heatman101
Aug 11, 2010 | Dryers
Hotpoint tuble dryer, Aquarius, VTD20 makes scraping sound
sounds like the back drum shaft has worn and dropped through back[plate ... there is a fix for this by buying a new drum shaft and support kit comes with front bearing also .. can be a tricky job tho ....
Mar 30, 2009 | Hotpoint NWXR473EV Dryer
Tiller won't start
You may need to perform a rebuild or possibly a good cleaning on the carb. any questions on it feel free to ask
Mar 17, 2009 | Yard Machines Tecumseh 148cc Front Tine...
Wire Scraping sound and sparks inside rear dryer drum area.
Probably the rear bearing has failed and caused the drum to rub against the heating element. Hey, is this the guy that said he heard a noise last month? LOL
Feb 01, 2009 | Frigidaire GLEQ2152ES Electric Dryer
Scraping noise with burning smell
You quite possibly have something like a penny or a paper clip stuck at the heat duct. ***First-shut off the electric to the dryer***. From behind the dryer, remove the heat tunnel and clean it out. You will be surprised how much lint gets past the filter. It's an easy repair, just a few screws. While you're back there, look around for any buildup in other areas.
Jan 03, 2009 | Whirlpool LEQ8000JQ Electric Dryer
Loud Grinding noise in Dryer
I know this prob is old, but I had the very same prob with my dryer (very loud squeaking noise). The prob was that there was a screw stuck between the rotating part and the stationary part. Meaning - look inside the dryer (main area - where the clothes go) and rotate it by hand. You may hear and see something causing the friction. Gerard
Dec 29, 2008 | GE DSXH47EGWW Electric Dryer
Kenmore 83142 Electric Dryer Logo
644 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
