Question about Philips 42PFL5332D 42 in. LCD Television
Can't turn my tv on
My tv won't turn on. I tried unplugging and plugging it back into the socket, but it still doesn't work. any suggestions?
    Scholar:
  • 72 Answers
Ok first question do u even get a blue led glowing in the bottom left front of your tv ? More than likely you have a cracked power supply ! Its one of those things that was a design flaw. If your lucky and its a small crack it can be soldered back together. If not you will need a replacement. There is a diode and a FET that will more that likely be replaced also.
Posted on Apr 29, 2008
  • whiskersmcge Apr 01, 2011
    what diode and FET? I have almost the same problem... a red standby light ( no flashing) and wont turn on.
SOURCE:
Tv will not turn on
This sounds like it might be a main board issue. Depending on the television brand there are different replacements you can get at different prices. I would try unplugging the tv from the wall first then try plugging it back in while holding channel up/volume up on the tv as you are plugging it back into the wall. If this doesn't change anything it is most likely a problem with your main board.
Jul 23, 2012 | Vizio VO47L 47 in. LCD TV
Plasma TV-power light does not come on
have you tried a completely different wall socket altogther/
Mar 03, 2008 | Samsung HP-S5053 Television
TV won't turn on
It sounds that, the memory IC to your TV has damaged. This IC can be located very near to main system control IC. A very small one, with 8 solder terminals. Even though it is very small, function of it while the TV works is great. The work is a semi-skilled one, and you must have some knowledge in electronics to proceed.
Jul 09, 2012 | Akai Televison & Video
** TV won't turn on.** No picture or sound. Please Help !
If the red light won't come on it is not getting power.First,try plugging it in to a different outlet,or unplug one of the gadgets you know is working and plug the tv in there.You are simply switching.If you know that there is power coming from the outlet and it still won't come on then you'll have to check the cord;don't go much farther than that without expert help.
Apr 04, 2012 | Televison & Video
When power went off and then came back on, screen on micro wave continually shows demo and I cannot set time
The first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
If that doesn't work, leave it unplugged for about 5 minutes and try again.
If it still won't work, then you may have a bad membrane keypad / DP circuit.
If your model is NN-P295SF, the service is here.
Parts can be ordered from Encompass here.
Aug 19, 2011 | Panasonic NN-P295SF Microwave Oven
Go to turn on tv and all I get is flashing red light and tv won't turn on. Was working the other day.what do I check?Sharp LC-26GA5U
Try unplugging the TV from the power point and leave unplugged for 5 min.
Or the batteries in the remote may be flat, try replacing the batteries.
If this doesn't work the TV may have a fault.
I hope this helps
MobileJB
Jul 13, 2011 | Sharp LC-26GA5U 26 in. HD-Ready LCD...
My gateway profile 5 won't turn on. Checked plugs
Try to power drain it. Unplug all the power related devices that are connected, like a monitor data cable or external printer, just unplug all the cables in the back after you shut down your computer, press the power switch of your computer and keep it pressed for about 45 secs, release it, plug everything back and check it if its working. As well double check if that particular socket is usable, plug something else in to see if its working.
Jun 30, 2011 | Gateway Computers & Internet
MojogiMy GHD1621F2 freeview recorder is frozen on one programme, won't respond to the remote at all (have new batterys) and won't respond to buttons on front. Turning off and on doesn't work...
Hi mojogill,
It sounds like the receiver may be locked up. If the buttons on the front do not work, then try unplugging the receiver for 5 seconds and plug back in then check to see if everything is working fine.
If you need any further assistance with this, feel free to contact me at [email protected] Thanks!
Tommy Faust
DISH Network
May 25, 2011 | DISH Network ViP722 DTV Receiver /...
When I turn on my set, light turns green, then after 30 seconds turns red won't come on
Sounds like there is a problem with the power supply. Try unplugging the T.V. and hold the power button for 30 seconds. Plug the T.V. back in and see if that helps. If it doesn't try switching to another outlet, and if that doesn't work then you may need to replace the power supply which would probably cost anywhere from 140 to 200 for one.
May 05, 2011 | Fujitsu PlasmaVision P50XHA40US 50 in....
Tv clicks when trying to plug it in and won't turn on
begins working for alomentacion source that can be damaged or filteos the same regulatory
Jan 05, 2010 | Apex Digital AT2002S 20" TV
Philips 42PFL5332D 42 in. LCD Television Logo
257 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Steve Allison
Steve Allison
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
