Question about Miele WT945 Front Load Washer / Dryer
WT945 Is it a straightforward job to defluff the fan?
    An expert who has written 3 tips or uploaded 2 video tips.
  • 8 Answers
I've just published some 'Tips' on the WT945's dryerWT945 - 2_bing.gif problems. Apparently they won't appear on's Tip List for another 24 hours, so here are the URLs. Hope this helps - Stage 2 is particularly relevant.
Posted on Feb 21, 2010
  • rangie1 Sep 14, 2010
    Great explanation and easy to follow solution. Carried out stage 2 fix and drier is now perfect! A little patience with a dental pick to move some hard deposits but now perfectly clean. Many thanks for saving the cost of an engineer call out!
Miele WT945 drier removal
Hi dear.
It is very complicated work. I can suggest you should not involve doing that but if you know what you are doing try that out. See if it helps.
Common problem: Stuck drying air fan shaft.
1- Unplug machine from power. Remove top cover.
2- RHS at the back,on outer drum horizontally mounted motor,drives a belt.
3- Try to rotate motor shaft (impeller) by hand, see if it's hard to rotate. Try to make it free to rotate.
3- If you have a capacitance meter, check value of capacitor should be in range of 2.5 uF if not replace capacitor.
Beyond that you need to get tech. to assist your machine. I hope that helps so far. Thanks.
Feb 25, 2016 | Miele WT945 Front Load Washer / Dryer
Miele WT945 Dryer Problems - stage by stage fixing (Introduction)
After two years of regular dryer fan seizure, and having called out a Miele technician to fix an unrelated problem on the WT945 (main water heater shorted), I pumped him for more information on the dryer side of things. I have to say he was extremely helpful and straightforward with his advice. So – with much help from the expert – I’ve attempted a complete summary of the dryer problem and its various solutions, which hopefully may be of interest to fellow sufferers. Good luck!
Dryer fan seizure seems to be a common problem with the WT945 as it ages. The symptom is (usually) a flashing ‘dryer’ light on the front panel and wet, cold clothes instead of a good drying cycle. If you’re familiar with your Miele sounds, there is also the absence of the high-pitched fan motor noise when drying (although the main drum still ‘tumbles’).
Before you attempt a fix, please be aware of safety issues. If you’re not confident about working on mains appliances with large, heavy moving parts, I would not recommend moving beyond Stage 1. In any case, always work with the power off, and beware of the heater (the long rectangular box sitting on top of the drum) – it can get very hot indeed.
First understand your components. When you take the top off the machine (screws under white plastic caps on each side of the top, about 5 cm in from the front), you will see a very obvious electric motor at the top rear right corner of the unit. This is the fan motor, which (through a rubber belt) drives a shaft that goes into a much larger, flattish unit bolted onto the back of the drum. This larger unit is the ‘fan box’, and hidden within it is the dryer fan that moves the air that does the drying (similar to a hairdryer). The small nylon ‘fan’ mounted on the front of the motor shaft (which cools the motor itself) is a red herring – this isn’t the fan we’re concerned with.
You will undoubtedly drop tools into the machine at some stage. Don’t panic and don’t mess about with magnets on strings etc – it’s far quicker to open the whole front panel which hinges on the right like a door. Take out the detergent tray, undo three Torx screws revealed around the edges of the tray holder, undo the three bolts behind the main door of the machine (these aren’t as fundamental as they look – nothing is going to fall off!). Open the filter flap and unclip the filter drain outlet from the inside of the flap. Open the door by breaking the seal and overcoming the spring clip at the base of the left hand side (can be quite stiff). Access is now pretty easy to the ‘floor’ of the machine to retrieve your tools. When closing the front again, don’t forget to feed the emergency door release plastic tab through the hole at the top of the filter flap aperture, otherwise it will be hidden inside the machine next time you want to use it.
See my next tip 'Stage 1 fix' to start work.
on Feb 21, 2010 | Miele WT945 Front Load Washer / Dryer
The narrow fan belt next to the wider one under the shroud is broke. Bobcat overheats. What is that belt called? How easy to fix?
Hi Ken:
If it's overheating then the water pump and / or the fan are not turning. Should be quite straightforward to replace, especially if you have the broken one to match for the new one.
Mar 30, 2015 | Cars & Trucks
How do I change the blower fan in a ford 2003 supercab
Blower motor in engine compartment passenger firewall area, you may have to remove the cruise control servo to get motor out, very easy and straightforward job, be careful transferring the blower motor wheel over to new motor, remove lockclip first on motor shaft.
Oct 15, 2014 | 2003 Ford F350 Super Duty DRW SuperCab
Belling oven xou592 bottom fan oven not heating up fully. Fan works and orange thermostat light on but does not heat up. Before this happened it tripped mcb in consumer unit.
You need to fit a new oven element.
This is located at the rear of the oven behind a removeable cover, where the fan is
It is a fairly straightforward job to replace.
Hope trhis helps with your problem.
Dec 15, 2009 | Belling XOU592 / XOU593 Electric Double...
Melie washer/drier wt945 dryer not working
the motor which controls the movement of the fan is either gone cracked or getting faulty or gone weak.needs to be checked and cleaned or replaced.
Jan 29, 2009 | Miele WT945 Front Load Washer / Dryer
Tumble dryer blower not working
The fan gets stuck because of the build up in the condenser itself. £400 will fix it damn them. I should have bought a Candy. Am sure that there is a service mode that can flush the condenser, because it is fitted as standard on new models. The reset of the micro switch should do it and try to free off the fan manually. Miele should be more forthcoming about this, taking into account the price of the damn thing in the first place.
Nov 11, 2007 | Miele WT945 Front Load Washer / Dryer
WT945 Dryer doesn't dry
check that the lack of air flow hasn't tripped out the thermostats. bypassing them will confirm the element hasnt blown out. but do not keep them bypassed as a "repair"
Jun 06, 2007 | Miele WT945 Front Load Washer / Dryer
Miele WT945 Front Load Washer / Dryer Logo
592 people viewed this question
Top Miele Washing Machines Experts
Gerry Harvey
Gerry Harvey
Are you a Miele Washing Machine Expert? Answer questions, earn points and help others
