Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
The convergence is way off on my projection rca tv - i lost the manual but i have set it before in a menu but caint remember how to get to it Was watching a movie, tv shut off and powered back on by itself...when it did it seems as though convergence is way out of watching 3d movie. It does this on all channels now and I can't remember how to access the auto convergence feature in the anyone? It's an RCA D52W26 HDTV
  • RCA Master
  • 8,617 Answers
It should be in the options menu. If not often RCA will drop the option when the convergence ICs go out and often the set will shut down. Heres alink that should be able to help you get a manual and parts if needed. If they dont have your manual leave an email and they should be able to get one quckly usually within an hour or two.
Posted on Apr 05, 2008
My R56WH78 tv has lost convergence overnite,I can not access any convergence menu with the remote control,What should I try next.
This RCA tv model have a dead convergence fuse at FL231 at the right side of a FBT- a big black plastic block with a wire hook to a board.Must resolders the FBT-(Flyback tranformer too).U have all the tools and also can do basic soldering work too?Yes,try website like to by the RCA tv convergence fuse to replaced at location FL231 and and also resolder FBT-Flyback tranformer too.Will solved this tv RCA model convergence problems.
Aug 02, 2011 | RCA R56WH76 Projection Television
Screeen is bowed and i have a ghost or 3d effect on the screen. the tubes may need to be converged, but not sure how.
This RCA DLP tv model have auto convergence at it menu,lost it from the menu or can't get to converge,this tv have a convergence fuse mean the convergence fuse FL(231) near the FBT-flyback tranformer is dead.U have a soldering iron,a roll of desodering braid or a desoldering pump and a roll of solders,also can do basic soldering.Try website like to buy a convergence fuse(FL231) to do the replacement.
Feb 07, 2011 | RCA HD52W59 HDTV Projection Television
How do I access the menu to get to the auto convergence setting. My screen has lost its autoconvergence.
Than this RCA DLP tv have convergence fuses.Convergence fuse is dead.U have a soldering iron, desoldering pump or desoldering braid and can u do basic soldering? Replaced convergence fuse FL231 that near the right FBT.The one in the Middle out of the three useally dead.Try to buy the FL231 convergence fuse.
Jan 21, 2011 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA hd52w67 analog convergence problem.
with Tv off press and hold ch- and vol- at same time untill tv turns on then release and you should be in factory settings service mode.
May 26, 2010 | Televison & Video
Lost bulb convergence and all input except for digital
With TV turn off Press and hold Vol- and CH- at same time ,wait untill TV turns on then you should be in service menu adjust convergence,BUT if when TV is on and you Go to menu then setup and you do not see convergence listed in menu ,you have a blowed fuse FL231
Apr 14, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
Lost convergece and not on the tv menu
Simple problem to fix for a professional; pretty hard to do yourself. There are bad connections on the flyback transformer and a fuse is open. Where do you live; i'm due for a road trip.
May 12, 2009 | RCA R56WH76 Projection Television
My screen to my RCA 56" HD TV is messed up. The picture seems to be bowed inward and the colors are all mixed up. I tried to do the convergence but it is not on the menu and I remember it being there...
t is the problem of convergence setting or convergence IC.
Comment by ready2helpu, posted on Oct 21, 2008 IF THE PROBLEM OF CONVERGENCE SETTINGS then check out this link
if the problem of convergence IC THEN check out this link
you can do it manually.
Oct 21, 2008 | RCA R52WM24 52" HDTV Projection Television
RCA HD52W59 Projection Big Screen TV
This problem is commonly refered to as a CONVERGENCE problem. Question 1 do you have convergence seting in setup menu...if you do NOT it could be a special small fuse. 2 if you go into setup then convergence. then can you move crosshairs in setup. Since you have a arcing picture this indicates convergence power supply which has to be replaced or repaired,
May 09, 2008 | RCA HD52W59 HDTV Projection Television
Rca rear projection hdtv lost color convergence
Projection sets have two very common problems.
The first common problem is convergence
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya
Mar 07, 2008 | RCA MM52110 52" Rear Projection HDTV-Ready...
Rca r52wh74 projection 52" tv
Convergence in this unit can be one of 3 possible boards. can you adjust any the crosshairs move in customer setup convergence menu
Jan 04, 2008 | RCA HD52W58 52" TV
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
245 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
