Question about Belkin (F5D7050) 802.11a/g/b Wireless Adapter
Drivers won't install
I have tried to install my Belkin usb network adapter, but it just does'nt work. When I click the icon, it just flashes one. When I go to the device manager there is an exclaimation mark telling me no drivers are installed. Everytime I try to re-install the drivers they just cant be found from the cd, even when I steer it straight to the driver folder. Ive tried everything. Im running XP.
Thanks.
  • sv650s Apr 06, 2008
    Hi. Yes this is what I thought, the only problem is that the pc which is a bit old was given to me minus the installation discs. Do you think I should just buy a new operating system, I can get one on ebay for about £58.00?
    Regards Roy.
  • 1,183 Answers
Two possibilites here
1. the driver CD is corrupt , though belkin is a plug n play adapter, there is no need to install the cd
2. Since you getting an excalmation suggests , windows recoganises the new hardware but fails to install.
The best option is either change the manufacturer of the adapter or reinstall windows , it should fix your problem
Posted on Apr 06, 2008
  • Mandeep  Singh
    Mandeep Singh Apr 06, 2008
    Before you buy or reinstall windows foryour computer , just make sure you download and burn all the other drivers needed for the machine from the maufacturer website. Like sound drivers, video and network.
  • Mandeep  Singh
    Before yoou buy and reinstall windows xp on your system , make sure you download and burn the rest of the drivers ,like sound, audio, video and network drivers from the manufacturers website
    Thanks
    Mandeep
6ya staff
SOURCE:
Belkin n150 wireless adapter- after installing software and plugging in the usb adapter my hp (running win xp pro sp3) will not display the desktop icon to open the wireless network manager. The hp sees...
Click on the start button on the lower left corner of your screen and go to "All Programs". Look for the wireless utility there of your Belkin wireless USB adapter.
Aug 30, 2011 | Belkin Basic Wireless N150 USB Adapter
F5d5050 Belkin USB 10/100 Ethernet Adaptor - Does it work with Windows 7 64 bit OS? I have spent hours trying to install a Swann and a Digitech product but none seem to work with the above OS. Any...
You cannot install this adapter in a Win 7 computer because the drivers are not compatible with Win 7.
So far Belkin haven't updated the drivers for win 7 OS. The latest drivers for this adapter is compatible only with
" Windows 98SE, Windows Me, Windows 2000, Windows XP 32-bit, Windows Vista 32-bit "
Click here to see the belkin compatible drivers in the website.
With Regards,
Prema.
Jan 06, 2011 | Belkin Ethernet Adapter F5D5050 Network...
Setup assistant won't run!
This dongle ahould auto detect and auto install. Shut down your PC, plug in the dongle and re-boot. If the dongle is ok, windows will detect it and install the drivers. If you have an early copy of XP, you may have to download and install USB drivers.
Apr 13, 2010 | Belkin N150 (F6D4050) 802.11g/b Wireless...
Belkin f6d4050 v2 - how to make it work with windows 7?
Most Probably this Will Work
Download the Drivers For Vista 64 Bit From
www.belkin.com/support
Step 1 : Right Click on the exe File And select Properties
Step 2 : Click The Compatibility Tab
Step 3 : Select Run this Program in compatibity mode For Win Vista SP1
Step 4 : Click Apply
Step 5 : Now try to install it
Jan 09, 2010 | Belkin N1 Wireless USB 2.0 Network Adapter...
Windows 7 driver update for Belkin F5D9050
Im Not sure this will Work
But in most Cases it will So I think its Worth a try
You will need to find the version of the Adapter
And After that Goto www.belkin.com/support
On the top right hand side on the search type F5D9050
On the results select the Link that has the Drivers
Download the Driver for the version of your Adapter
Right click on the downloaded file and select Properties
Click on the compatibility tab
Select Run this Program in compatibility mode for Windows Vista SP1
Click Apply
Now install the Drivers
Dec 29, 2009 | Belkin F5D9050 Wireless G Plus MIMO USB...
Belkin n adaptor will not work with windows 7
Download the Drivers For Vista2_bing.gif 64 Bit From
Step 3 : Select Run this Program in compatibity mode For Win Vista SP12_bing.gif
Nov 08, 2009 | Belkin N1 Wireless USB 2.0 Network Adapter...
Wireless adapter used to work, then stopped, then worked again, now can't be detected...
you mean that the adapter is not being recognised by the pc as a usb device, this adapter works better on a usb2.0 port, not as well on a usb1.0 port, depending on how old your pc is, try other ports., but you must uninstal the belkin driver from add/remove programmes, then install the driver again and inset adapter in a different usb port than before.
the adapter should then be found and click install driver automatically, but leave the cd in the drive as it normally picks the driver up again from the disk on it's own even after installing it yourself.
When installed i would recommend using windows wireless zero configuration (windows own software) instead of the belkin software, to do this right click on the network icon and select enable WZC (windows zero config), as this is a more stable programme for connecting your adapter signal to the router
Personally Belkin is poor in my opinion, netgear has better software and drivers, but it's belkin you have, so follow the above and it should be ok.
Sep 09, 2008 | Belkin (F5D7050) 802.11a/g/b Wireless...
Utility not displaying to select network
I don't know what it is with Belkin and their drivers, I have the same problem with their USB adapter. It usually takes a couple of goes to get their utility to work. When you are installing it make sure Windows is installing it from your cd and not the generic one. If you cannot uninstall it; it has not installed itself correctly. If you are unable to remove it, search the Belkin folder and manually delete, then download this free excellent programme to remove all traces of Belkin then try again. http://www.filehippo.com/download_ccleaner/ If Windows 2000 driver doesn't work for you try Windows XP driver.
Dec 13, 2006 | Belkin (F5D7010) 802.11a, 802.11g/b...
Belkin (F5D7050) 802.11a/g/b Wireless Adapter Logo
187 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Ekse
Pamela Bates
Pamela Bates
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
