Question about Xerox Phaser 7300DN Laser Printer
Phaser 7300N paper jam
The 7300 we have keeps jamming at the fuser, the paper will get 1 inch out of it and there it stays... we have replaced the fuser and the exit senor and have the same problem... is there some where we can get a repair manual or does someone have a print engine test so we can diagnose this problem???? any help would be appricated... Xerox 7300 keeps jamming at the fuser, switch out fuser and no luck, looked for paper and did not find anything.
    President:
  • 2,072 Answers
What code is comming up with the jam? That would help me narrow it down for you.
Posted on Apr 05, 2008
Xerox 7760 paper jam
at which position it will jam it matters tell in detail or send a sanp of it
Apr 10, 2013 | Xerox Phaser 7760/YDX Laser Printer
Take apart hp3005dn
Analyse what type of jam it is...based on that we can shoot the trouble.1. Paper is jamming before entry in fuser and its folds like curl in the cartridge area.. A. Fuser Teflon sleeve not rotating or slow rotation results media(paper)unable to reached the destination in specified interval. Replace fuser assm or Teflon sleeve.2. Paper jamming after fuser assembly crossed little bit ( approx 1-2 inch).A. Clean fuser out paper sensor, check sensor flag & flag spring located in fuser assm.3. Paper jammed after fuser crossed more than 6 inches..A. Check paper pick up roller warn out(tray1 or 2), check registration sensor located under registration assm.How to remove fuser assm: remove back door, see the snap shot...
Registration sensor location:
Pick roller roller tray 2 :
1_9_2012_3_54_49_pm.jpgPl try it carefully..Best of luck...
Jan 09, 2012 | HP LaserJet P3005n Printer
I have a Xerox Phaser 6180 MFP, and it keeps saying paper jam and there is no jam, what can I do?
Check the fuser for paper stuck in it.
Check that the 'paper out' sensor arm (in the fuser) is not broken. If it IS broken, you'll need a new fuser.
Sep 03, 2010 | Xerox Phaser 6110 Laser Printer
FUSER GETTING OVER HEATED IN XEROX PHASER 7400.SOMETIMES A4 PAPER GETTING JAMMED IN FUSER ,WITH A3 PAPER THERE IS NO PAPER JAMMING PROBLEM.
try to clean paper feeding rollers and chek fuser paper sensor, maybe paper comming too late...chek this just to be sure all its OK whit paper path and fuser.
...or replace fuser module!
Aug 23, 2010 | Xerox Phaser 7400DN Laser Printer
Phaser 7300 jamming manual feed
Can you print fine with no jams from the lower tray?
make sure you have clean new paper and start out with the 11"x8.5' letter paper. If you have that then follow the instructions below.
  1. Make sure there is no peaces of paper jammed in the path.
  2. clean the rollers with regular rubbing alcohol sometimes the rollers get way dirty to pick up the paper.
  3. If none of these tricks helped you then you have to change the the manuel feeder. part # 116-1561-00 good luck.
Dec 07, 2009 | Xerox Phaser 7300DN Laser Printer
Xerox Phaser 7700DN jam at fuser
Those rollers are necessary to feed paper from the fuser. Order PN 116-1759-00 which is the 15 inch long shaft w/ 4 rollers
Whit
Item, Inc.
Nov 10, 2009 | Xerox Phaser 7700DN Laser Printer
Phaser 7300 Jam at Fuser
need more info.
Are you printing more than one page documents? or are you printing a single page... because that would help to know.
The fuser is the most likely culprit. But it could also be a sensor somewhere. The printer has "timing" and when that "timing" is off even a milli-second, it will say JAM. Does it only jam on one type of media, or from only one tray?
need more info.
Sep 16, 2009 | Xerox Phaser 7300DN Laser Printer
Xerox Phaser 7300
Check in side the fuser unit there are two latches to release it and the unit comes out as one. check in there also you may have a paper feeding issue try to use the MPT as the paper sourse.
Sep 26, 2008 | Xerox Phaser 7300DN Laser Printer
Problem:
    The Printer's Front Panel Displays Jam At Top Cover; Open Top Cover To Clear (A7)
Cause:
Solution: thumbsup.gif Fixed! thumbsdn.gif Did not fix. TRY FIRST (Solutions without parts):
1. Unsupported media. - Load supported media and set the media type correctly. 2. Dirty exit rollers. - clean the exit rollers. Paper catching on the duplex guide assembly. - Remove and reinstall the duplex guide assembly. Fuser not fully seated. - Reseat fuser
REPAIR/INSPECT/PREVENT PROCEDURE:
1. Clean feed rollers and exit rollers only when dust or
debris is visible.
2. Clean the LED assemblies.
3. Check version of print engine and image processor
firmware; as appropriate.
4. Check cleanliness of interior and exterior of printer,
including fans; if necessary, clean (dust or vacuum) these
areas.
5. Review proper operation of printer using a customer
file, if possible.
6. Review with customer all work that was performed; also
discuss how to properly care for their printer.
Rev DT: 01 22 2003
Jan 23, 2008 | Xerox Phaser 7300DN Laser Printer
Xerox Phaser 7300DN Laser Printer Logo
452 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
