Question about Sanyo PLV-Z3 Multimedia Projector
Blue stain on the image projected by my PLV-Z3
About a month ago my Z3 started projecting a blue stain down the right side of image. It seems to change shape somewhat and sometimes there is some image ghosting. I have cleaned the projector and checked the bulb. I am guessing the LCD panel is starting to go - D'oh!
  • 1 more comment
  • Anonymous May 27, 2008
    I had this problem and yes it was the LCD
    I had it fixed by Sany for about 400.00
    I would get a PLZ-2000 IF I was to do this again rather than spend more money on the PLV-Z3
    They said it was the use of the Keystone
    Good luck to you
  • Anonymous Sep 12, 2008
    yes also my ble panel is out
  • james2911 Dec 22, 2008
    Same thing, but add blue dots on the screen also. Sanyo want 600 to fix now. Thinking about buying a new Sanyo Z60 for 900 out the door. Any concerns with the Z60?
  • 43 Answers
I had the exact same problem with my z3, Turnes out it was the blue filter.
I used the full service manual, and managed to fix mine using the diagrams, and troubleshooting section.
You can get the full service manual here.
http://yama.co.za/forum/index.php?topic=147.0
Posted on Dec 03, 2009
6ya staff
SOURCE:
I have a 42 in Sony HDTV model # KDF-42WE6555. I notice a few months ago a blue line down the left side. TV still wking good. Today I notice a yellow patch on the right side. TV is still wking good except...
i have the same problem but mine has a blue line surrounding the screen the tech took out the fly wheel part from inside this part has the 3 main colors with strips the blue side strip if you look at the glass it has the problem you see on your screen you have to replace that one section
Mar 10, 2011 | Sony Grand WEGA KDF-42WE655 42" Rear...
A blue shadow on the left side of the picture. Do
Hi , it seems you are experimenting a light engine problem.Here's how your tv works: http://www.youtube.com/watch?v=ZLLHnQ4y-wo Basically there's 3 LCD chips that create the colors and image by blending together.When these chips start to melt you will get those blue spots, pixilation even vertical lines.You will need to replace the light engine. Have a blessed one!
Apr 05, 2010 | Sony Grand WEGA KDF-42WE655 42" Rear...
I replaced the main lamp 6 months ago. Now I have blue on the right, yellow in the middle and normal color on the left. I also have a ghost image of tree branches on the whole screen.
Hi , it seems you are experimenting a light engine problem.Here's how your tv works: http://www.youtube.com/watch?v=ZLLHnQ4y-wo Basically there's 3 LCD chips that create the colors and image by blending together.When these chips start to melt you will get those blue spots, pixilation even vertical lines.You will need to replace the light engine. Found it here:http://www.discount-merchant.com/SONY-1-758-484-22-p/1180916.htm Have a blessed one!
Mar 31, 2010 | Sony Grand WEGA KF60XBR800 60" Rear...
Blue images on lcd tv
optical block failure
Feb 22, 2010 | Televison & Video
LOST THE LIGHT BULB [SET ON RIGHT SIDE OF SCREEN] THEN LOST BLUE
I replaced bulb on SOny XBR 60 with sony brand bulb about six months ago. everything was fine, then a week ago it seems that I lost the "red" portion of the color. Any suggestions?
Jul 23, 2009 | Sony Grand WEGA KF60XBR800 60" Rear...
3LCD Projection TV 2.5 years old displaying blue hue/blobs
I would first try a new lamp. If the reflector portion of the lamp has any defects, it could show up this way as the light would not be uniform. The next possibility is a defective light engine. The engine portion if not field repairable and would need to be replaced. Try the lamp first and let us know what happens.
Dan
Jan 13, 2009 | Sony Grand WEGA KDF-42WE655 42" Rear...
TV issue
There are many causes for spots on top of an LCD rear projection tv, you are probably in the first two cases, both require part replacements and repair job.
If the spots are faint blue, green or pink shadows, then it can be a problem with the anti polarization panel placed on top of the LCD.
Similar spots (colored shadows) may be caused by a problem with the light engine, in that case the fix will be expensive.
If the spots are bright lights, like an aura, that is a problem with the color wheel.
Problems on the light tunnel can cause static gray shadows.
If the spots are static dark stains than that is lcd liquid, the LCD panel must be replaced.
Oct 15, 2008 | Televison & Video
Color problems with Hitachi Ultravision 53UDX10BA rear projection television
Blue color has shifted. two months ago it had shifted slightly. Now it has shifted more. All three bulbs are working. Please suggest a solution.
Jul 08, 2008 | Televison & Video
Convergence Problem
sounds like 1 of the convergence chips are gone theres 2 of them and better off replacing both as the other would just go a month down the line there might also be a resister or 2 gone, the price for that kind of job is around 150 +vat.
hope this helps
Feb 10, 2008 | Panasonic PT-47WX51 47" Rear Projection...
Sanyo PLV-Z3 Multimedia Projector Logo
573 people viewed this question
Top Sanyo Office Equipment & Supplies Experts
jasbo
jasbo
Ekse
Are you a Sanyo Office Equipment and Supply Expert? Answer questions, earn points and help others
