Question about Cell Phones
Forgot my lock code
I forgot my lock code, i can't open my mobile, what will i do?
  • nasehr786 Oct 06, 2008
    i forgot my simlock code on my samsung D900i mobile. now i want to give my phone to my brother, but it wont accept any other simcard apart from my number. pls help.
    thanks
  • Anonymous May 02, 2009
    my phone needs a sim lock and i have tried all the codes and it dos'nt oppen
Remove the sim and enter *2767*3855# then wait for 1 minute your phone gone restart him self then your phone is free
Posted on Mar 26, 2009
LG kg110 network lock
Posted on Jun 10, 2009
Samsung Codes
*#06# demonstrated the international mobile equipment marks the IMEI code
#*1200# AFC DAC Val
#*1300# IMEI
#*1400# IMSI
#*5111# status
#*2565# (BLOK) no blocking general defense
#*3353# (DEKE) general defense code erased
#*7222# (SCAC) - Class C GSM
#*7252# (SCLB) Class B GPRS
#*7271# (SCS1) Multi slot Class 1 GPRS
#*7274# (SCS4) Multi Slot Class 4 GPRS
#*2787# CRTP on/off forces to examine the battery temperature to open/the pass
#*3737# status, AFC val
#*5132# (L1DA) status
#*5133# (L1DE) status
#*7288# (SATT) GPRS attached/detached the GPRS supplementary/relieves
#*7287# (SATS) GPRS att/det status GPRS attaches belt-shaped @
#*7666# (RNMO) status
#*7284# (SBTG) Set Class B to GPRS
#*2256# (BALO) Calibr. -info
#*2286# (BATA) Databattery battery data
#*7352# BVMC set 0h debug battery
#*2558# Time ON for debug battery
#*2474# cmd set debug battery
#*2527# GPRS switching 4,.8,9,1 million
#*2679# Copycat feature ON/OFF
#*3940# ext.looptest 9600bps
#*3941# ext.looptest 115200bps
#*4263# (HAND) Handsfree mode ON/OFF exempts proposes the function to open/the pass
#*4700# (HR00) Half Rate opens/Guan Yushe for to open the suggestion to open, increases the handset continuously to converse on the telephone the time
#*3370# (EFR0) EFT on/off Enhanced Full Rate opens/Guan Yushe for to open, suggests to open, enhances the telephone conversation acoustic fidelity
#*7462# (SIMA) SIM phase SIM card function type
#*7983# Voltage/Freq ON/OFF
#*7986# Voltage ON/OFF
#*7693# (SMXD) Sleep Act/Deact province electricity pattern switch
#*8462# Sleeptime status province electricity pattern condition
#*7683# (SMVE) Sleep variable
#*5176# (L1PN) L1 sleep status
#*7632# (SMDB) Sleep mode debug relieves the province electricity pattern
#*7673# (SMRE) Sleep mode reset province electricity pattern reset
#*8466# old time - sleep, SMReq, awake
#*2255# call failed mode...
#*5187# (L1TR) L1C2G trace
#*5376# ------------------ reboot?
#*6837# Official Software Version / official software edition?
#*7524# KC GPRS
#*7562# LOCI GPRS
#*7638# RLC ON/OFF
#*2337# Parmanent Registration Beep
#*2834# Audio Path opens the audio frequency way
#*3270# (DCS0) DCS support on/off supports 1800M to open/the pass
#*3282# Data on/off
#*3476# EGSM on/off
#*3676# Flash volume formatted must delete the complete telephone directory with after
#*4674# IMSI
#*4760# GSM, active/deactive
#*5171# (L1P1) status
#*5172# L1P2
#*5173# L1P3
#*7326# Accessory: ********
#*7762# (SSMB) SMS Bearer CS, active/deactive
#*8465# (TINL) Time in L1
#*9795# Wtls key Reset
#*2252# (CALC) Current CAL
#*2836# AVDDSS Management ON/OFF
#*3877# Dump of SPY trace
#*2677# (AMRS) AMR status: None/Half Rate/Full Rate
*#2255# (CALL) Call Log demonstration telephone conversation diary
*#8999*324# (DAG) Netmon network receive condition
*#8999*377# (ERR) Error Log handset wrong record
*#8999*636# (MEM) memory status handset memory condition
*#8999*8378# (TEST) Test the Mode test pattern demonstrated the edition (hardware edition, software edition, IMEI), the hardware test (the vibration test, the audio frequency hypothesis (the speaker increases, the microphone increases, the music increases, the speaker volume (normal, handset, exempts raises, earphone), the pressed key sound (is normal, handset, exempts raises, earphone), the tonality calibration increases, the speaker volume (earphone)), battery information), locks the condition, the SIM card information (SST, CPHS, telephone directory, withdrawal, short information, language, IMSI) as well as information and so on product.
*#4777*8665# (GPRS*TOOL) GPRS hypothesis
*#8999*523# (LCD) in Main LCD Brightness host screen luminosity adjustment
*#8999*3825523# (ETALLCD) outside External LCD screen luminosity adjustment
*#9999# Firmware version software edition
*#8999*8376263# Firmware detail detailed all software edition
*#8888# H/W version demonstration hardware edition
*#8377466# (VERSHNO) S/W & H/W version
#*6420# (MIC0) MIC off
#*6421# (MIC1) MIC on
#*6422# (MICA) MIC dep Rxdata
#*6428# (MICT) MIC measurement
#*3230# TRACE, enable
#*3231# DCD, enable
#*3232# Show DCD/TRACE mode DCD/TRACE condition
#7263867# RAMDUMP opens/the pass
*#7465625# All lock the status handset locks the condition
Below the instruction does not suggest the use, otherwise needs to carry on relieves the handset lock!
*7465625*638# (SIMLOCK*NET) Network Lock enable opens the network lock
#7465625*638*# disable network lock with the password pass eliminates the network lock
*7465625*782# (SIMLOCK*SUB) Subnet Lock enable
#7465625*782*# relieves Subnet lock
*7465625*77# (SIMLOCK*SP) opens the SP lock
#7465625*77#
*7465625*27# (SIMLOCK*CP) opens the CP lock
#7465625*27*#
*7465625*746# (SIMLOCK*SIM) opens the SIM card lock
#7465625*746*#
*7465625*228*# (SIMLOCK*ACT)
#7465625*228*#
*7465625*28638# (SIMLOCK*ATNET) the network locks automatically opens
#7465625*28638#
*7465625*28782# (SIMLOCK*ATSUB) Subnet lock automatically opens
#7465625*28782#
*7465625*2877# (SIMLOCK*ATSP) automatically opens SP lock
#7465625*2877#
*7465625*2827# (SIMLOCK*ATCP) automatically opens CP lock
#7465625*2827#
*7465625*28746# (SIMLOCK*ATSIM) automatically opens SIM lock
#7465625*28746#
#*7728# RSAV, handset hypothesis reset, retention telephone directory
*2767*3855# E2P Full Reset telephone EEPROM always repositions (repair software breakdown)
*2767*2878# E2P custom the Reset telephone current hypothesis replacement (handset solution locks)
*2767*927# E2P wap replacement
*2767*49927# Germany wap preset
*2767*44927# England wap preset
*2767*39927# Italy wap preset
*2767*33927# France wap preset
*2767*86927# China wap preset
*2767*852927# Hong Kong wap preset
*2767*73738927# RESETWAP
Posted on Jun 02, 2008
3 Suggested Answers
SOURCE: recorvery mobile lock code
download nokia unlocker from google search........
Posted on May 06, 2008
Murphybanton
  • 2004 Answers
SOURCE: I forgot my security code of my Nokia 6300 phone my mobile my mobile serial no is 353932016116813
Visit http://www.unlockme.co.uk/master.php
enter your imei number and get a master code for resetting your phone.
rate fixya
Posted on Jun 03, 2009
How to reset security password cherry mobile D17tv
How to unlock cherry mobile input lock code? - Ask Me Fast
www.askmefast.com > ... > Mobile
... lock code? I forgot the password and i cant open my phone ..... Someone said: my phone is D17tv. Was this ...... Cherry mobile p8 security code reset · If my htc ...
Cherry mobile restore factory password [Solved] - CCM
ccm.net > Forum > Mobile
Aug 5, 2010 - Please refer to the following FAQ regarding your phone's unlocking : http://en.kioskea.net/faq/1038-kioskea-does-not-help-for-mobile-unlock Cherry mobile T20 factory reset code
Oct 24, 2013
How to master reset cherry mobile z11. [Solved]
Aug 26, 2011
More results from ccm.net
How do i unlock my cherry mobile d17tv i forgot the password
www.fixya.com/support/t25417435-unlock_cherry_mobile_d17tv_forgot
Feb 12, 2015 - how do i unlock my cherry mobile d17tv i forgot the password fbsgd - Cell Phones question. ... Default 6 Digit Security code: 123456 or 000000
cherry mobile c2 (change password tutorial) - YouTube
? 1:27
https://www.youtube.com/watch?v=i9eDQO8m
Feb 04, 2016 | Cell Phones
Forgot my screen lock password for my huawei u8350
ur defalt phones codes is 12345 or 00000 u can use it
Default 4 Digit user code: 1234 or 0000
Type *#06# at the mobile screen to know IMEI no of your mobile.
send the IMEI no to me and i will reply you with unlocking code.
IF Problem not Solved So
Please New Software install in the Phone Problem will Solved
If For puk & pin cod problem So Please
Very Best Solution:You Go To Service & Sim Office and Get The Puk code And Pin code From Office oprator
Enter The Puk code and Yes
Enter The pin code and Yes
So Puk code Open and Problem will Quickly Solve
Sep 03, 2012 | Huawei u8350 unlocked gsm phone
Forgot security code and cant open it
hi try default security codes like 0000 or 1234 to reset your mobile if it dint help you to unlock visit onlinegsmunlock.com here they ask you the mobile model and the imei number of your mobile.finally they send you codes to reset you mobile .they provide master reset codes for some nokia and alcatel mobile models.
Jun 03, 2012 | Cell Phones
My samsung gt 19000 is loked as my son put wrong pattern so please tell me how to open the lock
Unlocking Phone Don't worry there isSolution to Unlock the Mobile Phone from the Security Lock....Use the MasterReset Code and Unlock the Mobile....I unlocked my mobile Nokia 6600 using theMaster reset Code,I got the Master Reset Code here http://www.superunlockcodes.com/unlocking-services/rs12wp6/and Unlock it........You Check Master Reset Code for Your mobile in the List.
Apr 05, 2011 | Samsung Galaxy S GTI9000 Smartphone
How to reformat using code in cherry mobile p3
i forgot my phone lock code.. my unit is Q6i . how can i reformat it.. to open my phone.. please help..
Mar 04, 2011 | Cell Phones
Forgot my security code and i cannot open my mobile on...
You can Unlock the Mobile from the Security Lock or Password Lock using the Master Reset Code,You can get the Master Reset Code at http://www.superunlockcodes.com/unlocking-services/rs12wp6/ and Unlock it.I unlocked My Nokia and Alcatel Mobile from the Security Lock using the Master Reset Code...
Nov 21, 2010 | Nokia 5310 Cellular Phone
Unlock code for micromax mobile phone
i forget my phone lock password
Apr 06, 2010 | Cell Phones
I forgot my unlock code lg kg 195 plz solve my problum
plz tell me what can i do i m forgot my phone lock.how i un lock my mobile
Dec 08, 2008 | LG KG320 Cellular Phone
Lock Code Recover
i am trying to format my n70 it asks for the lock code, how do i find it thanks
Jun 21, 2008 | Nokia N70 Cellular Phone
Recorvery mobile lock code
May 06, 2008 | Nokia N70 Cellular Phone
Cell Phones Logo
1,165 people viewed this question
Top Cell Phones Experts
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
