Question about Indesit W 123 Front Load Washer
Washing machine My main switch trips when i switch my washing machine on My washing machine has started to trip the main switch. When I switch it back on the machine starts again--sometimes for 1 minute, sometimes for 20 minutes but eventually blows the 13amp fuse in the plug.Is this a big problem or how can it be fixed
  • Anonymous Mar 26, 2014
    ive wrote this out six times now and still have had an answer to my question
    Problem Solver:
  • 12 Answers
The problem you are have there is if the machine is bolwing a fuse becauce the heater element is falty replace the heater and all shall be fine again noffie....
Posted on Apr 08, 2008
SOURCE:
Hi, i go into the test mode and it starts on 18 and when it gets to 14 the house electricity power trips off.Any idea what part do i need to replace?
How can I figure out why my washing machine is tripping the ...
diy.stackexchange.com/.../how-can-i-figure-out-why-my-washing-machi...
Aug 17, 2012 - 110.24872300) washing machine which up to this point has been ...Note what is happening when it trips (is it starting to spin, starting to drain, filling, etc.).... If the outlet trips when the washing machine isn't running and isn't ...
Washing machine tripping RCD « Singletrack Forum
singletrackworld.com/forum/topic/washing-machine-tripping-rcd
Switching on the plug socket that the washing machine's plugged into caused no problems, but switching the machine itself on trips the RCD. ... then its possibly the water fill solenoid as most cycles start with a water fill. ... I've always guessed it is theelectricity/water combo somewhere in the machine so err on the side of ...
Nov 29, 2015 | Washing Machines
Trip switch cuts out when i use washing machine
Main board power circuit fault.disconnect main PCB and reconnect power cable .you can identify the fault. Replace main pcb.
Sep 01, 2014 | Indesit Washing Machines
Hoover primera washing machine keeps tripping electrics when tured on.
Possible that there is higher current drain which trips off the circuit. This can be due to moisture or dampness in the circuit , coils or the motor. You need to remove the top panel and dry using a dryer. check the connectors, check the main line , the motor circuit. Isolation of the motor or the heater can confirm the short if the circuit stays. Check the main power to the panel and allied circuit for possible capacitor leak or short.
Mar 16, 2013 | Washing Machines
I have a beko wm5100w washing machine and it keeps tripping the electricity
Hi, I have just come back from holiday. I turned on my beko washing machine,power comes on and when it starts it switches off the main electric box.before i went away i turned off the main electric box. Is the machine broken and if so expensive job?
Nov 25, 2010 | Washing Machines
Zanussi jet stream iz16s tripping ouy rcd once filled up with
It would seem to me that the heating element needs replacing from the information you have supplied especially as it performs most of the other functions like filling and spin and drain.
Good luck
Mar 17, 2010 | Washing Machines
electrical short in m/c.could be heating element. regards
Jul 30, 2009 | Washing Machines
Washing machine tripped main fuse breaker, now won't work
Yes. It may be an internal safety fuse or switch. RJ
Sep 29, 2017 | Candy Washing Machines
Hotpoint aquarious wd 440 two years old tripping main board
A faulty heater in both a washing machine and dishwasher will trip swithes because they both cause an earth........the chances are you heater needs replacing......the reason its tripping after a short period is probably beacause the cycle doesnt start heating the water until after approx 15-20 mins depending on the cycle chosen
Mar 28, 2009 | Hotpoint Aquarius WD63 Front Load...
Zanussi ZWD1680W Front Load All-in-One... Problem:
With the symptoms you describe i would suspect a intermittent heater element fault as you are getting earth leakage current which is tripping the whole supply rather than a current overload which would just trip the socket circuit breaker. Get the heating element checked over first as this is the most likely cause.
Nov 04, 2008 | Zanussi ZWD1680W Front Load Washer / Dryer
Indesit W 123 Front Load Washer Logo
333 people viewed this question
Top Indesit Washing Machines Experts
Gerry Harvey
Gerry Harvey
jimorris77
Marvin
Marvin
Are you an Indesit Washing Machine Expert? Answer questions, earn points and help others
