Question about Linksys Wireless-G WRT54G Router
Wireless router connection problems
Cannot connect to linksys router directly
  • jgranny May 17, 2008
    bought router at yard sale hooked up according to instructions do i need to go into laptop and change all the old router info i had on netgear when hooked up linksys said router was not hooked up can u please help me
  • Austin Pilz
    Austin Pilz May 11, 2010
    I would love to help you out. But first I will need a liitle bit more information. What are you trying to connect to it with? Have you reset it to factory defaults? Is there a WEP or WPA key?
    -Austin
I need some more information....is that on wired computer or wireless computer
one_hour@rediffmail.com
Posted on Apr 06, 2008
Hi Support team, I use Modem Motorola SB100 with Linksys WAP54G, and DLink Wireless G DWA USB Adapter to connect to Linksys WAP from my PCDesktop. Connection from the PC to Linksys is ok but can't...
peter_picasa:
You cannot use a Wireless Access Point (WAP) to connect directly to your IPS's modem. A WAP does not provide the ability to share a single IP address on the internet like a router does.
Either return the WAP for a refund and buy a wireless router or buy an Ethernet wired-only router and plug the WAP into the LAN side of that router. You would then plug the WAN side of the Ethernet wired router into your modem.
Thanks for using FixYa.
Feb 20, 2011 | Linksys Wireless-G WRT54G Router
Linksys wireless router WRT54GC is not connecting to Internet
check by connecting directly your computer to modem, if still same, then contact ISP, might be a problem at thier end.
Mar 16, 2010 | Linksys (WRT54GC) Router
Can connect to internet directly through modem. When connected through Linksys WRT54GS router, all lights are ok on both modem and Linksys--including internet. (Have had this router for 2 years...no...
As last resort you might want to use a JTAG cable and debricking programming software. If your router is brikced or you want to change the firmware this cable can do it. The cable will connect to your parallel port and your wireless router so you can repair your router. They are about $5.95.
Jan 11, 2010 | Linksys Wireless-G WRT54G Router
My Linksys will connect with a cable but wont connect wireless!
Connect with a cable, and then follow the directions in the manual that came with the router, in order to connect to the web-server "inside" the router. Run the "Wireless Setup Wizard" to configure your wireless network.
Nov 27, 2009 | Linksys Wireless-G WRT54GS Router...
Unable to connect to the internet using a linksys wireless adapter. Connects to the router but can't find the internet.
Isolate the issue by directly connecting the PC to the router via ethernet cable (if possible).
If you were able to get online while hardwired connected to the router, then check the IP address of the wireless network connection, check the wireless security if the network key matches.
If you cannot get online while hardwired to the router, then directly connect the computer to the modem.
If you were able to get online while directly connected to the modem, then the problem is the internet settings on the router. Check the WAN configuration, such as DHCP or PPPoE.
If you cannot get online when directly connected to the modem, then you will need to contact your Internet Service Provider.
Nov 07, 2009 | Linksys WUSB54GC 802.11g/b Wireless...
Assuming "cannot connect to linksys router directly" means you cannot connect to a Wireless Lan managed by Linksys router,
1) try to connect new computer to LinkSys Router using a Lan cable, add new PC to your network.
2) recover protocol (WEP or WPA) and Key of WLAN (Passphrase or Key: TKIP or AES) either from other PC on same network either from your Router.
3) If you missed actual key you must connect to router and reset it to a new key to be eventually used for every connected device.
Call for detail on this possibility
Dec 29, 2008 | Linksys Access Point WAP54GP Wireless-G...
Wireless connection
Possible you did reset the router. Its okay to connect to that linksys network name. But if you want to customize you network name.
MAKE SURE TO USE THE WIRED COMPUTER TO SETUP WIRELESS CONNECTION.
Example : The Desktop computer that is connected to directly to router.
Just follow the steps.
http://linksys.custhelp.com/cgi-bin/linksys.cfg/php/enduser/std_adp.php?p_faqid=3967&p_created=1159257209&p_sid=aNKUFggj&p_accessibility=0&p_lva=&p_sp=cF9zcmNoPTEmcF9zb3J0X2J5PSZwX2dyaWRzb3J0PSZwX3Jvd19jbnQ9ODExJnBfcHJvZHM9MCZwX2NhdHM9MTcyMSwxNzIzJnBfcHY9JnBfY3Y9Mi4xNzIzJnBfc2NmX2xhbmc9MSZwX3BhZ2U9MSZwX3NlYXJjaF90ZXh0PUNoYW5nZSBTU0lE&p_li=&p_topview=1
Hope it will work..
Oct 14, 2008 | Linksys Wireless-G WRT54G Router
I have Verizon Fios install in my home. I use to have Comcast. This is the situation, before the Fios my linksys wireless router was connected directly to a modem. Now my linksys wireless router is...
Your IP address for you linksys router needs to be changed.  More than likely there using the same IP address such as 192.168.0.1.
You have to convert your linksys router to a switch and change the IP address range it uses to on that doesn't conflict with the Verizon router.
10.150.1.1 should work.
Oct 08, 2008 | Computers & Internet
The lights are on but the linksys is not working
Certainly if the conection directly from the router to the computer is not working then the wireless won't work. So that's where I'd start. Cable connections could be an issue. The connection without the router works I assume. Make sure you are connected correctly. You need ethernet cabling to the ethernet, networking connections to and from the internet device to the computer and into and out of the router. When you get the direct router connections working you can solve your wireless problems.
Sep 24, 2008 | Linksys Wireless-G WRT54G Router
Linksys keeps disconnecting
Have you tried different ports on the router? If so have you tried other computers hard wired in? Hard wire in one of your laptops for awhile and see if they lose connection as well. If so then the problem is the router, but if they can stay connected then I would try either updating your network card drivers or getting a new network card perhaps. Let me know if that helps any.
Sep 25, 2007 | Linksys Wireless-G Broadband Router
Linksys Wireless-G WRT54G Router Logo
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
