Ref: Seagate Momentus 5400 160GB – ST9160821AS Using this HD as external drive with dual USB connectors. Works great with Vista Home Basic. When connected to Win98SE, I am directed to install "USB to Serial ATA bridge". Is this a hardware or a software issue?
  • 123 Answers
Its a software issue..
Posted on Apr 06, 2008
Vista os does not see hdd on install.
either driver issue, or if it was a new drive, may have to properly formatt and partiion drive prior to installing.
Aug 21, 2013 | Seagate MOMENTUS 5400.3 (ST9160821AS) SATA...
Seagate Momentus 5400.6 500GB ST9500325AS external drive, when plugged in, starts beeping for a short while then Windows 7 detects it, but can't initialize it in the Disk Management screen. I do not...
If you try to initialize it, you will destroy your data.
Try another PC or better still a Mac. You may be able to read it but it should spin up otherwise it could be the usb connector.
Aug 06, 2017 | Seagate Momentus 5400.6 (ST9250315AS) 250...
I pulled the seagate 2.5"
When you use external adapters to plug drives into USB ports the drive needs to be set for mast not slave. The internal drive is one one channel and external drive is on a different channel so neither drive is a slave, both are masters with not slave drive present. Try removing the jumper you installed and try the drive, it should be seen because all windows XP or later do not need drivers for USB drives.
I hope this helps, if so please rate my solution.
May 06, 2011 | Seagate Momentus 4200.2 100 GB Hard Drive
Hi There. I am looking for an Internal Hard Drive to suit a Dell Inspiron 1525 Laptop. Seagate Momentus 5400.3 160Gb ST9160821AS. Where can I get one or is there another Hard Drive that would be OK to use...
I suggest you check the specification of your Dell laptop to see the maximum size hard drive it can support. The maximum size hard disk you can install in the laptop depends upon the BIOS.
Any major brand of 2 1/2" hard drive will work with the Dell.
Oct 27, 2010 | Seagate Momentus 5400.3 - 40GB - 5400rpm -...
PC does not detect Seagate 500GB external hard drive
Try using the device on another PC & see if it works. if it does then you have a issue with your PC. whast the OS you are using? also try another USB port.
May 06, 2010 | Seagate Free Agent Go Small 12 GB USB...
Seagate Portable 250 GB External Hard detected for only 2 secs
u can try some hit and trial...
1 - keep ur USB HD off and switch on the PC then switch on the power on USB HD
2 - try another USB port
3 - try another USB cable connector
4 - check ur Device manager/usb root hub settings/power setting, uncheck the box that says" alow computer to switch off Power Mgt tab
Feb 18, 2010 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
External HDD not formattable in Vista
mark partition or drive as active then you should be able to, delete every partition on disk then using the wizard to create a simple volume and then it will be formatted
Oct 21, 2009 | HP Computers & Internet
Hard Drive Failure
OK, at the link below you will be directed to a tip i wrote on this exact error.
Click HERE.
Feel free to let me know if you have any further questions.
Kind regards
Apr 15, 2009 | Seagate MOMENTUS 5400.3 (ST9160821AS) SATA...
Seagate 80 GB laptop hard drive not appearing in My Computer
i suggest u to re instal u r
remember- dont keep 2 operating system on u r hardisk man
dont forget to tell me u r problem solved or not
best regards & best of luck..
Oct 26, 2007 | Seagate Momentus 5400.3 Hard Drive
Computers & Internet Logo
147 people viewed this question
David Payne
David Payne
