The start/reset button is flashing, dishwasher will not start, there is water in bottom of dishwasher
Sounds like your drain pump may be blocked.
check to see if waste drainpipe is blocked,
if not try and see if your can get machine to drain into a bucket.
if not drain pump may have something blocking it internally if machine has a filter clean it out, if no filter remove drain pump a clean it out or replace if faulty.
i
SOURCE: dishwasher will not run. clean light flashes seven times
I had success with the "Hi-Temp Wash - Normal - Hi-Temp Wash - Normal" sequence of button selections. This must occur within 6 seconds and initiates an internal diagnosis of the machine. The process runs for about 19 min. and shuts off. During the process several LED's light up and several funtions start and stop. If the machine has no broken systems, you should be able to open the door add some soap and the usual dirty dishes and carry on with normal operation. Thats all I have done and the wife is no longer on the war path. Good Luck
SOURCE: dishwasher not draining
if you hold the start button in it should reset,possible cause could be a blockage in the pump or drain outlet under the sink where the drain hose connects.hope this helps.
SOURCE: No power to dishwasher; checked breakers they seem
you need to check the power only:
1- check the power come to the wall right ,if not
get elecricity man to bring it to plug in the wall
2- check the cord of m/c if it has fuse check it
and replace with same values ampers,....so on
3- if problem still check electricity reach at end of cord if not ,chang cord
4- if you still have problem inform us
>be ware of electricale chock it is your your life> thanks from me m abba
SOURCE: My BF162 dishwasher won't start
it might be flooded in the tray underneath due to a blockage, try loosening the bottom panel (3 screws) and emptying it of water and re setting. Clean out all the traps etc in the dishwaser to make sure nothing is blocked
SOURCE: why is my dishwasher flashing on the eco 45 button
This doe seem that the anti flood system has triggered. This device puts the machiene in pump out mode and shuts off the input water supply.
The device is a safety device that triggers once it detects a water leak (pipe / clamp) and consists of a polystireene float and micro switch at the floor of the washer. First check to see if the float has activated the micro switch and then dry the machiene floor and check for leaks.
start reset button flashes on and off
start reset button flash on and off a adora dishwasher
