Question about Microsoft HP Pavilion DV6276US Notebook PC
Problem with HP computer, help me please!
My HP Pavilion Entertainment PC Laptop won't work. I had an application running, did not realize the battery power was out, and the computer turned black. I plugged it in and I turned it back on, and it said "Resuming Windows" or something like that. My application was restored, but I could not get ex out of it or start another program. I turned the computer off again, and then turned it back on. The screen was all black, but all the little blue lights were lit and the "on" light was lit, too. The moniter was still black. I repeated this process, but no luck with the moniter. I tried unplugging it and it still did not work. I also tried removing the battery and putting it back in. That did not work, either. If you know what to do, please help me! I really need this computer. Help!
  • 1 more comment
  • ronanddebbi Apr 13, 2008
    my grandson was playing an hp game which froze up. I turned off the computer and have had the same thing happen, all the blue lights are on but my screen stays black. Tried everything already stated. any suggestions?
  • glittering May 17, 2008
    I have the same problem with my new HP Pavilion Entertainment laptop. It froze on startup when I double clicked on Firefox before startup was complete. After it froze, I did ctrl-alt-del, but nothing happened, so I turned it off manually. Then I tried to turn it on again, but the screen stays black. The blue lights are all on.
  • Anonymous Aug 20, 2008
    Screen blank when I turn the computer on and all lights showing blue etc...!
    How annoying?
I tried that, the additional monitor had the normal "can't detect connection" message, then the second i plugged it into the laptop it turned black. So i know its my laptop, it works, but its just like locked up or something because it is sending a message to the monitor.
The blue LED lights are on, but none of the buttons work. They are frozen. The mute button is on, but when i click it, nothing happens.
Posted on Aug 27, 2008
  • Anonymous Aug 27, 2008
    Hey, i just fixed the problem i had. All you have to do is:
    Turn off the laptop.
    Take out the battery.
    Unplug everything (even the ac wall adapter)
    Hold the power button for 10 seconds to drain all residual power
    Connect the ac adapter again, and voila. Its fixed :)
    If that doesn't fix it, then it might be a more serious problem. Which they also help you with here.
    http://h10025.www1.hp.com/ewfrf/wc/docum...
Try hooking an external monitor up.
Posted on May 27, 2008
SOURCE:
HP Pavilion Entertainment PC issues. Laptop loads with 4 of the same screen. Won't startup so I can check the settings. Any help would be greatly appreciated!!
i think u have problem with the cable that connect motherboard to the screen ... go to closer computer and laptop-repairing office
Feb 17, 2013 | Computers & Internet
Hp pavilion 2915nr entertainment laptop won't start
start your PC press F8 and goto recovery !!
else goto BOOT settings reset and then try again.
else insert installation disk then start laptop and press F8
goto recovery and recover your computer to earlier settings !!
Jan 23, 2013 | Computers & Internet
Hp pavilion DV4 won't start up
It doesn't start at all. Can you see something on screen ? Have you tried to remove the battery and charger and press power buton for 30 seconds ? And put back the battery ? Try also to check RAM Memory
Oct 14, 2012 | HP Pavilion dv4-1280us Notebook
HP Pavilion Entertainment PC Laptop DV2000
when you say some times it keeps going does this mean the unit turns off ??,,,,this model has the gpu problem,,,dry solder joint of the graphics card, of which you can have the board repaired or replace the board
Oct 06, 2012 | HP Pavilion Computers & Internet
Instruction manuel book for the HP Pavilion dv4-2145dx AMD/ATI Entertainment Laptop And initially the switch on buton for this laptop
For HP Pavilion dv4 Entertainment PC - Maintenance and Service Guide
http://h10032.www1.hp.com/ctg/Manual/c01963667.pdf
For other manuals for HP Pavilion dv4-2145dx Entertainment Notebook PC http://h10025.www1.hp.com/ewfrf/wc/manualCategory?lc=en&dlc=en&cc=us&product=4121133&
If you satisfy with my solution please rate/vote for me.
Rating/Voting will encourage me to help others
Jun 09, 2011 | HP Tablets & eReaders
Hi. I have a HP laptop pavilon dv 4t Entertainment pc. frequently its interactive log on process fail. Also it seems too slow to boot and I think in all processes it is slow working while its fan works...
the is overheating, ever get the lent cleaned out.
all CPUs run slower if overheated, all do, or halt. of too bad.
run it with no battery yet, see if all is ok, first.?
batteries are #1 failure point items.
no pc can run too long, and not pack full of lent.
why not just get the PC serviced by a tech, he knows all this magic.
cleans it, tests it, etc..
Jun 27, 2017 | HP Pavilion dv4t Entertainment PC - 2.4...
Screen black computer laptop not starting ,hp pavillion entertainment pc,power lights on but screen black screen black computer laptop not starting ,hp pavillion entertainment pc,power lights on but screen...
hi,
if nothing(even hp logo ) is not coming on the display then please try this.
1.remove the battery and then press the power button for 30 sec.Again refix it and check.
2.If windows sound is there then this mught be the issue with display.
3.If there is no windows sound might be the issue with RAM so please get it checked.
May 29, 2009 | Microsoft HP Pavilion DV6276US Notebook PC
Compatibility between HP Quickdock 2.0 Docking Station KN745AA and HP TouchSmart tx2-1020us laptop for external monitor viewing
Your tx2-1020us is not compatible with the KN745AA as this device is only compatible with the following:
  • HP Pavilion dv2700 Entertainment Notebook PC series
  • HP Pavilion dv6700 Entertainment Notebook PC series
  • HP Pavilion dv9700 Entertainment Notebook PC series
  • HP Pavilion dv2600 Entertainment Notebook PC series
  • HP Pavilion dv4-1000 Entertainment Notebook PC series
  • HP Pavilion dv5-1000 Entertainment Notebook PC series
  • HP Pavilion dv5-1100 Entertainment Notebook PC series
  • HP Pavilion dv6-1000 Entertainment Notebook PC series
  • HP Pavilion dv6-1100 Entertainment Notebook PC series
  • HP Pavilion dv6600 Entertainment Notebook PC series
  • HP Pavilion dv6800 Entertainment Notebook PC series
  • HP Pavilion dv6900 Entertainment Notebook PC series
  • HP Pavilion dv7-1000 Entertainment Notebook PC series
  • HP Pavilion dv7-1200 Entertainment Notebook PC series
  • HP Pavilion dv7-2000 Entertainment Notebook PC series
You can find the compatibility chart by clicking here
You can find the compatibility information for the ES631AA by clicking here
To resolve your issue you should purchase one of the following:
To dock your notebook you need the HP QuickDock KN744AA#ABA or
You could get HP Notebook Media Docking Station
May 15, 2009 | Computers & Internet
HP Pavilion dv4-1151TX Entertainment Notebook PC price in india
http://h10025.www1.hp.com/ewfrf/wc/prodinfoCategory?lc=en&dlc=es&cc=mx&product=3824509&lang=es
Please find complete details for HP Pavilion dv4-1151TX Entertainment Notebook PC in the above link.
The price for the same starts from HK$9,980
Thanks
Have a nice day.
Mar 20, 2009 | Computers & Internet
Microsoft HP Pavilion DV6276US Notebook PC Logo
111 people viewed this question
Top Microsoft Computers & Internet Experts
Ekse
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
