Question about Samsung HLR5667W 56" Rear Projection HDTV
Thanks . . . but
I thought you only needed ballast on submarines.  What does it do in my tv and how much would it cost to fix?
Thanks again for your help!
  • Samsung Master
  • 8,617 Answers
The ballast is what lights the lamp installing yourself is going to be about 200 a shop maybe 400 to 600 depending on where you have it done.
Posted on Apr 05, 2008
SOURCE:
I thought I had a bad bulb. Took out the old one and it was black and melted looking on the inside. Bought a new bulb and put it in the 61 inch DLP and the lamp light is still blinking yellow. I have no...
The tv have clicking noises sounds too?Yes?The board that call Ballast board it is dead too.This Ballast board only job are to ignite the tv projection lamp only.Tries websites like Partstore.com,Ebay.com to buy a new Ballast board for the replacement.
Aug 12, 2011 | Mitsubishi WD-62827 62" Television
I have a Samsung HLP4663wx xaa that I just replaced the color wheel to fix the buzzing noise and then had to replace the lamp after 16541 hours so definately got my moneys worth. Had to remove the jumper...
I would assume you need to replace that ballast. Usually the bulbs out live the bulb's ballast (from previous experience)...I've seen DLPS do this type of thing when the bulbs are slow to turn on due to a new ballast being needed.
Thanks and hope it helps!
Jul 07, 2011 | Samsung HLP4663W 46" Rear Projection HDTV
My 50in LCD has had a green tint to it for several months, was told by Best Buy that it was likely that a mirror got misaligned when we moved. Friend had the exact same tv...thought that the bulb went...
Good luck with that.... But if you really want to try,... look at where the bulb makes electrical connection when it is plugged into the set. You should see two thick wires leaving a connector and going to a circuit board. this board is the ballast. You'll have to disassemble until you can get the board along with the wires and connector.
Aug 14, 2010 | Panasonic PT-50LC13 50" Rear Projection...
KF42WE610 bad lamp... and ballast?
DLP Lamp has electrodes inside and ballast generates high voltage that makes spark on these electrodes thus got high bright light. New lamp wont die due to bad ballast so replace lamp and see tv works or not.
This tv has self diagnostic feature, turn On tv and let it shut down, now check standby light that would be blinking in specific order, for example 3 or 4 times blink then pause for 3 seconds and again blinks.
Let me know how many times standby light blinking in this tv to help you with more info.
Thanks.
May 16, 2010 | Sony Grand WEGA KF42WE610 42" Rear...
Insignia IS-LCDTV32 LCD TV with no image and buzzing sound.
Before you throw it in the trash, check the supply voltage to the panel ballast. You should see 24v coming off the power board... this is what you want to check. Second, check to see is the ballast is being given an "ON" signal.. you will find this signal on the same connector or one of the others going to the ballast (some models have 2 connectors from power supply to ballast. The "ON" signal will come on shortly after you press the power button. If you have both, you either have a bad ballast or a bad lamp inside the panel assembly. The lamp.. no fix, junk the TV; the ballast.. you could search high and low for one or try to fix it yourself; no 24v, check with MCM Electronics for a power supply; no, "ON" signal, your main PCB is suspect. I hope this was helpful, best wishes.
Apr 22, 2010 | Insignia IS-LCDTV32 32 in. Television
Buzzing sound, resets 8 times, and then turns off. Bulb replaced
Actually ballasts run between 60-80 dlls. It does sound like you doi have a ballast issue, everytime a TV resets the ballast is the issue. Go to discountdashmerchantdotcom you'll see the ballast prices. Plus they also have free troublehsoot.
Aug 25, 2009 | Toshiba TheaterWide 52HM84 52" Rear...
Samsung 46inch Slim DLP - No Power, buzzing/crackling
Well, you definetly right...... The driver of the ballast is busted, now the ballast is to weak to maintain on that lamp. I will recommend to stop trying to turn ON tv since this could damage the bulb by blowing it from inside. I will recommend to change ballast and the old lamp should work for a little while (since I am quite sure that this bad ballast is consumming faster that lamp). Or change lamp and ballast as well that shouldnt cost you more than 200 in booth things.
you can have the ballast from samsungpartsdotcom or i also had purchase some from discount-merchantdotcom (excellent service)
Jun 24, 2009 | Samsung HLN5065W 50" Rear Projection...
Mitubishi WD 62725 - Ballast Problem??
the capacitors on the power board are the most likely the cause of the problem.
Jun 21, 2009 | Mitsubishi WD-62725 62" Rear Projection...
Need verification of potential ballast issue and to be directed to step by step fix it directions
After lamp replacement, TV worked 4 days and now TV gives 3 blinks error. right?
If yes, please recheck lamp door / cover and fix it properly.
May 09, 2009 | Sony Grand WEGA KF50WE610 50" Rear...
Ballast or Lamp?
Its not the lamp or the ballast board. In either case, you would lose picture (going blank or black) and sound would soon follow then the LEDs in front would blink if at all.
Odds are its either the DMD board or the digital board.
michtech
Feb 02, 2009 | Samsung HLN5065W 50" Rear Projection...
Samsung HLR5667W 56" Rear Projection HDTV Logo
57 people viewed this question
Jerry Greenberg
Jerry Greenberg
Ekse
