SOURCE: amp turns on and stays on but no sound
are you shure you not connect the amplifier in a wrong connection ...B+,GND,ACC.....ok...then checkif the speakers wires stay in good condicions, some times when we intalled the spk wires for the border of the doors a few times skrewered too.check if it hapen. another ....check if the terminal spk is not going at ground whit the chasis another to....4 ohms per channel ,anny voice coil spk burned...in short. good look.
SOURCE: sony xplode 1000w amp has green light puts out no power to subs
check the speaker, the subs. i had same problem, same reading on volt, its correct as way it should be. if its not the rca plug then it has to be speaker, i replaced the amp and it wasnt that, it was the speakers after all...
SOURCE: Sub not working and red light on amp stays on?
the amp is under to much pressure get a bigger 1
SOURCE: i have a sony xplod 600 amp,hook it up,but the
this is caused because the remote wire isnt unhooked. u either have to turn the remote wire off or connect the wires to the blue wires on the back o your radio for the light to turn off. that light WILL drain your battery fast!
