Question about Uniden Cordless Phone
No dial tone
When i push the talk button it flashes for a few seconds then beeps 3 times
then shuts off.
  • Anonymous Apr 05, 2008
    kkyhvcf
  • Anonymous Apr 07, 2008
    Two days ago, I began having exactly the same problem as discgolf1. I'm hoping to learn the cause of the problem before I go to the expense of trying a new battery. They're not cheap. Also, in the past these symptoms never occurred when I've needed a new battery.
  • 85 Answers
The power supply of your phone is shorted,you need to coldsolder the components of your pcd.
Posted on May 13, 2008
How to do conference call
Depends on the phone system or service you are using. On a regular land-line you can do a 3-way call (if you have this option available to you through your service provider). To do this:
1. Call the first party.
2. Once the caller is on the line ask them to hold while to connect with the 2nd party.
3. Flash to dial tone. There may be a flash button on your phone or you may just press talk. In any case you should hear a quick "beep..beep..beep" then dial tone.
4. Now you can dial the 2nd party and click the flash (or talk) again to return to the 1st party and you both should hear the phone ringing for the 2nd party.
There's hundreds, if not thousands, of different phones, phone systems, and provider combinations that have different procedures for making conference calls. This is probably the most basic way. Hope this helps
Nov 27, 2012 | Lands Phones
Have an Emerson cordless phone EM6113-BK. We can
On that model you need to press and hold the FLASH button, after it beeps it will be in tone mode and not pulse.
Apr 16, 2010 | Emerson Smartset Clock Radio
I have a Emerson DECT 6.0 with 3 head sets and i cant get the dial tone back from pulse.
It was easy for my Emerson Dect 6.0 to be switched either rotary / pulse by just pressing the "FLASH" button for 3 seconds until it beeped. Problem solved.
Or if that doesn't work, you have to:
Tone/Pulse
You can switch the dial mode. In most situations the TONE option should be selected.
• Press the MENU button. Select BASE using <FLASH - or - CID> and press the MENU button again.
• Using <FLASH - or - CID> select DIAL MODE and press the MENU button.
• Using <FLASH - or - CID> select TONE or PULSE and press the MENU button.
OR
Press and HOLD the "<FLASH" button for approximately 3 seconds. T (Tone) or P (Pulse) appears in the display.
Feb 12, 2010 | Uniden DECT 6.0 Cordless Telephone...
Hell There, We have a "legacy" GE hands free kichen" phone model: 26730GE1-D Yes, I know it's ancient, BUT I did put a fresh, brand new battery in last week and it rings, when piucked up reads out...
Hi.
The calls are being placed on waiting, try using Flash button before using Talk.
Test the chance on a different phone line , the most likely is that the phone is defective.
If the phone is working on a different line, then it is a configuration problem, and the phone is waiting for a manual call transfer from a different phone in your network.
Try using Flash button instead of Talk, this will answer the call if there is a waiting service programmed.
Try testing with no other phone connected.
Finally try resetting the phone, use procedure below:
  • 1. Make sure the phone power is ON (but not in the “talk” mode by pressing the PWR button.
  • 2. Use the arrow buttons to scroll through the main menu until Handset setup is flashing.
  • 3. Press the SELECT button. A second menu shows on the display.
  • 4. Use the arrow buttons to scroll to Reset phone.
  • 5. Press SELECT.
  • 6. Use the arrow buttons to change NO to YES.
  • 7. Press SELECT to confirm.
If after resetting the calls are still being placed on hold, then again, the phone may be faulty.
Here a manual for your phone.
Jan 15, 2010 | Cell Phones
I have uniden exa 915 . Problem: When you pick up the cordless hand set and push the talk button you get a beep,beep,beep and but no dial tone.I put a new battery in two mo. ago and just to make sure I put...
Its lost its "link" to the base unit, you need to re link them this is either dont thru the menu system on the handset or pushing a button underneath the base unit and THEN re linking it via the menu.
Oct 23, 2009 | Uniden Lands Phones
Radio shack phone c-4210
for my phone I hold down the flash key then the menu comes up and you can press * for tone or # for pulse. Hope it helps!
Dec 06, 2007 | GEH5450 Cordless Phone
Muting the sound
The sound produced by a Motorola radio when the mike is keyed refers to the "Transmitting Call Tone" which is another feature other than the "Interference Eliminator" or the "Roger Beep" feature.
On most Motorola GMRS/FRS TalkAbout radios, setting the "Call Tone" to 0 disables the feature. This is done with the radio ON by pressing on the "Menu" button 3 times which will result in the display showing the current Call Tone setting (flashing) and the letters CA; pressing on the <- or +> buttons will change selection (you will also hear the different Tones), select 0 (it may be up to 5 or 10 depending on the version). Press on the "Menu" or "PTT" button to set, save and exit.
Hope that this be of some help/idea. Pls post back how things turned out or should you need additional information.
Good luck and kind regards.
Nov 25, 2007 | Motorola TalkAbout T5530 2-Way Radio
Ge 900 MHz cordless phone set on rotary dialing
Lisa, If the 900MHZ phone is Model 26928M programming for rotary dial usually goes like below, can't hurt to try on any model. TONE/PULSE DIALING This adjustment allows you to select tone (touch-tone) or pulse (rotary) mode dialing. The phone is pre-set for touch-tone use. To set to tone or pulse dialing: 1. Press and hold the program button for two seconds. You will hear a beep. 2. Press the *tone button to select Tone Dialing or press #pause to select Pulse Dialing. 3. Press the program button again. You will hear a confirmation tone.
Sep 29, 2007 | Uniden Cordless Phone
Tone Pulse
yea.. this happeneded to me aswell.. here's what you do: (this is in the manual btw) TONE/PULSE SETTING 1. Make sure the phone is OFF (not in TALK mode). 2. Press the program button. 3. Press * tone button for tone or # pause for pulse selection. 4. Press the program button again. You will hear a confirmation tone.
Feb 28, 2007 | GE 27990GE3 Cordless Phone
Switching from pulse to tone
I think you would of already saw it if there is one but it should be on the side or bottom of the phone. Hope it Works
Jan 09, 2007 | GE 26939GE2 Cordless Phone
Uniden Cordless Phone Logo
104 people viewed this question
Top Uniden Lands Phones Experts
k24674
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
