42wh36p - wavy lines
Hi i Have a 42wh36p with wavy lines all over the screenm what would be the best way to fix this?
Thanks
  • 4 more comments
  • derwon Apr 05, 2008
    I thought a video might be better to show the problem.
    Thought a video might show the problem better
    Video of the problem
    Picture ( not the best sorry)
    Thank you for your help
    i may just have to buy a new tv.
  • 8,617 Answers
Can you post a pic of the screen? Its hard to diagnose that type of problem with out seeing as it could be a deflection or a signal issue.
Posted on Apr 05, 2008
  • 1 more comment
  • Sonny Berry
    Sonny Berry Apr 05, 2008
    your video didnt post
  • Sonny Berry
    It says video no longer available when I try to play it.
  • Sonny Berry
    That looks to be a problem in the horizontal deflection, possibly a bad capacitor making the set become drawn in and distorted. You would need the service manual and a few pieces of equipment such as a ESR and digital volt/ohm meter to even attempt diagnosing the problem. But if you want to attempt it I can post a link where you can get the Service manual with free tech support, but this could be a rather involved repair with the diagnosing alone.
How do I fix wavy lines on Hauppauge Wintv hvr950q?
Are they wavy lines throughout the picture or are they just wavy on the side? Waving picture is usually caused by poor power supply filtering. Wavy lines throughout the picture are caused by interference. Try moving the device away from the computer with an extension USB cable it may be picking up interference from the surrounding electronic devices. It could also be defective.
Oct 19, 2014 | Hauppauge WinTV-HVR-950Q (1191) TV Input
Wavy colored lines of captioning at all times, can't turn off
Try first unplugging the power cord for fifteen or twenty minutes , see if this can reset and fix the problem.
Sep 11, 2008 | Panasonic PT-47WX49 47" Rear Projection...
Green and pink wavy lines throughout. Picture
I am having the same problem and so far unable to fix,
Jan 22, 2010 | Pioneer SD-582HD5 58" Rear Projection...
Wavy coloured lines on the screen all the time & hue
Tv repairman. the green picture tube has an intermittent short in it. This is an expensive fix.
Mar 30, 2009 | Sony KP-51WS500 51" Rear Projection...
I which on my ps3 is loads up but online the wavy lines appear
That's not too hard to fix.
Check out my guide here:
Pay attention to #3.
http://rescuetechla.blogspot.com/
Please feel free to email me any other questions and please don't forget to rate!
Thanks!
RescueTechLA
Feb 26, 2009 | Sony Playstation 3 (PS3) Console
Dash warning light????????????
Hi if your battery was flat or ca non charging battery, is alternator fault, but replace battery and if happen again, u have byuy alternator, u can buy used, that fine, hope this help thanks
Dec 18, 2008 | 1993 Toyota Celica
Wavy Lines which clear up after being on for 10 minutes - Toshiba 50H82
It will cost about $300 to fix. The Hyperboard has to be replaced. I had it repaired over 2 years ago and it works great.
Sep 06, 2008 | Toshiba 50H82 50" Rear Projection...
Toshiba 42WH36P rear projection TV has wavy lines
the problem is going to be a bad NEXT HYPER UNIT module. this is the digital scan card in the tv. try using the componenet inputs and if the tv works ok then you know that the HYPER UNIT is the problem. the reapir process for a "do-it-yourselfer" is too involved and would recommend a serivce center for this repair.
Dec 29, 2007 | Toshiba 42H83 42" Rear Projection...
Wavy lines, goes black during video games.
It sounds to me like the monitor's refresh rate is too low to support your current settings, and the demands of the game. Have you tried adjusting the refresh rate? If I'm right, you should be able to fix the wavy lines that way. I'm not sure how much control over the refresh rate the game takes, but if you can fix the wavy lines and the game still doesn't work, I think you're not likely to get the game to work on this monitor.
Aug 28, 2007 | Proview PL926WBi 19" LCD Monitor
Toshiba 42wh36p
Please define line tearing or line hold drift==Do you mean horiz. or vertically?? Is the problem the same on all sources?? Any change hot to cold?? more diagnostic observation needed.
Aug 05, 2007 | Toshiba 42H83 42" Rear Projection...
Televison & Video Logo
211 people viewed this question
Top Televison & Video Experts
