FixYa.com
Tags:
Kitchen Hoods
Generic problem for all Kitchen Hoods
Light doesn't work on Kenmore Model 55022 Range... (by 4 users)
posted by dfbpa on Apr 05, 2008
I have a Kenmore Elite model 55022 range hood that is about 2 years old. Recently both lights stopped working. So I did what any one would do went and bought 2 replacement bulbs. When I put the new bulbs in the lights still wouldn't work. So I took my meter and did some troubleshooting. I found that there is 120VAC at the light socket. I know that the bulbs are good, I tried them in another light fixture. Also the fan on the range hood still works. Do you have any suggestions.
I have a Kenmore elite range hood approx two years old. one light was bad and the other good. Neither of them burned when replaced. Is there a fuse that controls the light switch. the fan works.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
3 Other Users Have The Same Problem
Comment by arghargh, posted on Jun 08, 2008
I have same problem.  One light stopped working like a year ago. Now both are out.  Changing bulbs doesn't help.
Also have same problem one light stopped working about a year ago.  Now they are both out.  new bulbs don't help.
Comment by Nina James, posted on Jun 04, 2008
Both our lights dont work. It is not the bulbs. The light button wont push in and stay.
Solution #1
posted on Apr 05, 2008
Not Rated (0)
zeusfaber
Rank:Guru Guru
Rating: 85%, 247 votes
If you're getting 120V at the lampholders, yet it's not lighting lamps that still work perfectly well in other fittings, two possibilitiesspring to mind.
One is that the cap on the bulbs isn't quite compatible with the fitting. Assuming they're some variant of Edison Screw, make sure that the centre terminal in the lampholder is sticking out far enough to touch the terminal on the bulb. Also check whether the lampholder achieves it's outer connection just with a small tab, rather than with the whole of the threaded ring. If so, make sure that this is going to touch the appropriate part of the bulb.
The other possibility is that you've got a high resistance connection somewhere - not enough of an open circuit to drop the 120 V when feeding the Megohm load presented by a meter, but more than enough to kill the supply when you have a lamp load. Only way to chase this is to use the meter on ohms range to bell out all the wiring between the lampholders and bits of the system which do work properly.
A.
Was this solution helpful? Show your Appreciation by rating it:
This Problem Also Relates To: GE Profile JVB98SHSS Kitchen Hood Bosch DAH9505 30in Traditional Wall Updraft, Stainless Steel, Half-Round Bullnose Style Kitchen Hood Kenmore 59940 Kitchen Hood Kenmore Italian Design 50303 Kitchen Hood KitchenAid Pro Line KWCU360JSS Kitchen Hood Viking VIPR101 Kitchen Hood Zephyr Pyramid ZPY-E30S Kitchen Hood
Can you Help with these Kitchen Hoods problems?
Miele Designer DA230-2 Kitchen Hood
would like to view whirpool
would like to view whirpool... Answer This...
Frigidaire HC8830 / HC8830W / HC8830S Kitchen...
Fan's fine, but I'm in the dark
no lights. Period. What I've... Answer This...
LG Corbel A- Accessory Range Hood
plasma screen flashing
plasma screen is constantly... Answer This...
Kitchen Hoods
Installation instructions for...
I bought a display model... Answer This...
Kitchen Hoods
Looking for Installation...
We bought an open box... Answer This...
Repair Service
Find Kitchen Hood Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
