I checked the batteries and they're fine. I got a new remote and it seems to be working, but the tv won't respond. I'm wondering if there's something wrong with the tv or maybe a setting has been changed.
Normal
0
false
false
false
MicrosoftInternetExplorer4
/* Style Definitions */
table.MsoNormalTable
{mso-style-name:"Table Normal";
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-style-noshow:yes;
mso-style-parent:"";
mso-padding-alt:0in 5.4pt 0in 5.4pt;
mso-para-margin:0in;
mso-para-margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:10.0pt;
font-family:"Times New Roman";
mso-ansi-language:#0400;
mso-fareast-language:#0400;
mso-bidi-language:#0400;}
Try the following: use an air-can and dust the multiple component input/output
slots everywhere on the TV itself. If this doesn't solve the problem, connect
standard 1/8" headphones into the remote control OR the headphones jack on
the TV. Then unplug the TV for a minute. Plug it back in, turn it on, and see
what happens. Hope this helps,...it may not seem relevant, but it works for
some reason.
Good luck...
SOURCE: Remote won't work. Tried new
To confirmed if the remote control is working fine, aim the remote control sensor(IR emitter) directly to your cellphone camera. While pressing any button key on the remote control, you can see the flash of an infrared emitted by the remote control if it is working fine.
If you've confirmed that the remote control emitted an infrared but still the tv won't communicate with it, this is an indication of faulty IR sensor board of the TV. Check if there's an obstruction from the IR receiver in front. Keep away all of it, clean the plastic window of the IR receiver with soft clean cloth.
If the symptoms still persist, you have to replace the IR sensor board. Check the actual part no. of the board before ordering.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
