Question about Sony Handycam DCR-HC14E Mini DV Digital Camcorder
Error code What does C:32:11 mean? I am unable to close the cassette compartment with or without cassette. Many thanks
  • 1 more comment
  • Benkat Apr 06, 2008
    Thanks but it did not work
    Unable to remove small battery under LCD screen.
    Sorry this did not work
    Genius:
  • 1,447 Answers
Remove battery, re-attach it, & power it up
Posted on Apr 06, 2008
  • Edgar Allan Pagayona
    Edgar Allan Pagayona Apr 06, 2008
    Check for physical damages and foreign objects as well, i think there is sumthing on the sensor mechanism causing that error
    Genius:
  • 3,422 Answers
HI,
To fix your problem please follow the below steps:
1. unplug camcorder AC cord
2. remove fat battery from back of camcorder
3. remove slim battery from under the LCD (it's the size of a nickle coin)
4. wait 2 minutes
5. plug AC into the camcorder
6. flip the camcorder into VTR mode
7. tape should automatically eject
This is another method:
1) Put camera in record more
2) push door shut and hold it shut while removing battery
3) While still holding door shut, reinstall battery. do it twice, but within 45 seconds it will work fine.
Goodluck,
Please don't forget to accept the solution.
  • 1 more comment
  • Priya darshan Apr 06, 2008
    If your problem is solved then please don't forget to accept the solution no.2 as fixya..
    For whom was that comment?Did you try my solution which i told you.
    was that comment for me?Did you try my solution which i told you.
    President:
  • 1,944 Answers
I believe this means that there is condensation in the tape mechanism.
  • Damen Wong
    Damen Wong Apr 06, 2008
    Leave the unit in a dry area to get rid of the condensation.
  • Damen Wong
    Damen Wong Apr 08, 2008
    Try leaving the battery out overnight to fully reset the unit.
How do I fix the tape holder system on my camcorder? The door won't lock, and the cassette won't get inside the compartment.
hi,
is it close without a cassette ? if so the reel sensor in the cassette compartment may be faulty. if the head drum not rotates the cassette drive will not work correctly, if so please loosen the head drum with a plastic rod or some tools like that. do not put your finger in hence sometimes will jam your finger. remember don"t touch the scanning chip of the head.
Oct 26, 2015 | Panasonic Palmcorder PV-GS12 Mini DV...
Mvx200i didn't load cassette
Are you putting the cassette in the correct way round ?
Jun 17, 2017 | Canon MVX200i Mini DV Digital Camcorder
I have a sony cassette handycam. After inserting the cassette the compartment does not close,The cassette is not pulled in to go back to its place.Tel me the solution thanks
The mechanism of the cassette compartment is misaligned and it need mechanical adjustment, Please contact any repair man nearby to resolve the issue, No part is required in mechanical adjustment.
Thanks
May 14, 2011 | Sony Handycam DCR-TRV103 Digital Camcorder
Sony dcr-trv350 tape wont close
there is a risk of hardware damage.make sure you dont force the tape into the cassette compartment to avoid damage to the unit or tape.here's what you can do.
1.remove the tape from the compartment.
2.ensure proper type and size of tape is used.
3.ensure no packaging material or foreign material inside the compartment.
4.if attempting to record, make sure cassette tape rec/save switch is set to rec position.
5.reinsert the tape, make sure it's properly inserted.
6.if still won't close or tape ejected again,remove tape.
7.reinsert a diff tape.
8.attempt to close compartment.
9.if issue unresolved, press the tiny reset button while cam is powered on (located in the panel where the lcd screen goes to,just below all the other buttons). you may also do a power reset procedure: remove batt, remove ac adaptor,set power switch to vcr, leave the cam without power for at least a minute, switch power back to off, reinsert ac adaptor/batt and turn cam on, attempt to close tape compartment.
if issue persists, service would be needed. hope this helps.thanks:)
Mar 26, 2010 | Sony Handycam DCR-TRV350 Digital Camcorder
I have a canon zr 100 camcorder. the problem i am having is that it keeps ejecting a cassette when i am trying to load a cassette.it will close without a cassette in the compartment.please let me know what...
Usually caused by a nearly dead battery or a bad cassette. However...before proceeding, make sure there are no foreign objects, such as filament paper that cassettes are wrapped, in cassette slot.
1) make sure battery is fully charged
2) try using a new cassette
Jul 11, 2009 | Video Cameras
Loading tapes
I have the same problem. If I remove the battery for a few seconds, then replace the battery and wait about 5 seconds, the tape compartment closes.
Dec 10, 2008 | Sony Handycam HDR-HC7E DV Digital...
Problem with SONY DCR-HC90E
Reinsert cassette message comes when mechanism doesnt load cassette properly. If this error message comes again n again, means mechanism has some problem and unable to do task.
Aug 07, 2008 | Cameras
Cassette compartment cover blocked
have you try to open it and see for any loose spring parts.?
thanks
Apr 23, 2008 | Cameras
The cassette holder isn't closing......and the tape is not loading
Hi
See if this works--If you are on battery there may not be enough power .Charge the battery or use the the mains power through the transformer and see if it works.
Hope this helps
Jay
Nov 17, 2007 | Sony DCR-PC55E Mini DV Digital Camcorder
Sony Handycam DCR-HC14E Mini DV Digital Camcorder Logo
241 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Jerry Greenberg
Jerry Greenberg
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
